Hopper Slide Issues
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by IHATEPROPANE, Feb 23, 2015.
  1. IHATEPROPANE
    IHATEPROPANE
    So yesterday I put some aluminum tape and dry graphite to the hopper of the 55-TRPEP. I won't have results until this weekend at best. Pics to follow.
    Ps 15ft of Aluminum tape goes fast.....
    imacman, slvrblkk and ivanhoe like this.
  2. Lousyweather
    Lousyweather
    well. not wanting to rain on your parade or anything, but I am divorced! :eek:
    Knowledge of an item doesn't necessarily mean one practices it.
    Margaret Fuller said: "If you have knowledge, let others light their candles in it", sooo, just trying to help you guys out! :cool:
    so, ladies, here I am, come and get it! :popcorn:
  3. Triple A Arsenal
    Triple A Arsenal
    New Haven, CT
    Well knowledge is power.
    Horkn and ivanhoe like this.
  4. ironpony
    ironpony
    Mid Ohio
    :like:
    all the more reason to have one.....:like:
  5. imacman
    imacman
    Denver, NC
    or 2 or 3 :cheers:
  6. imacman
    imacman
    Denver, NC
    :popcorn:
    ivanhoe and IHATEPROPANE like this.
  7. ttdberg
    ttdberg Pellet Pig
    CT
    I have had hopper slide issues in the past with AWF WPs, Heat'rs and Vermonts. I tried a number of different techniques to solve it, but nothing really made an impact because the pellets aren't really sticking to the hopper. OK, maybe they are - but the real issue for me is they are sticking to themselves which creates that bridge effect. Once the gap forms down the middle of the hopper, the pellets at the ridge stick to the ones behind them and won't slide down. In the end, I gave up trying and settled on making sure the hopper is 100% full to the brim before I go to bed at night, otherwise I wake up to a cold house despite the fact the hopper is still half full of pellets! Recent seasons of Vermonts no longer do this, they must have found a way to bake them that eliminates the "tacky surface" issue.
    Interested to know if the aluminum tape helps your situation!
    PoolguyinCT, ivanhoe and IHATEPROPANE like this.
  8. Skier76
    Skier76
    CT and SoVT
    I have an insert so it's more of in issue for me when trying to go for a long burn. I have found that during a weekly cleaning, "dusting" off the hopper liner helps quite a bit. I've found the AWFs tend to stick more and leave more fine behind. Once those are clean, things move along better in the hopper.
    ivanhoe, wildwest and IHATEPROPANE like this.
  9. IHATEPROPANE
    IHATEPROPANE
    So after running it out twice the verdict is........no difference. As some have alluded to I think these MWP are part of the issue. Currently I have a 18-20 lb real use hopper. I probably will not be trying any other pellets this season but will be sure to update this thread when I do and report the results.
  10. smoke show
    smoke show
    Pittsfield, Wi
    That sucks. Hope you find a cure.
  11. IHATEPROPANE
    IHATEPROPANE
    It definitely would suck. But this stove is a part timer. 5 hrs a night. Max of 12 on the weekends. So, it doesn't effect me much. But it definitely wouldn't work as the full time option.
    ivanhoe, ttdberg and smoke show like this.
  12. don2222
    don2222
    Salem NH
    How about what the grain farmers use in their grain silos?
    Slip Plate ! ! ! :)
  13. jtakeman
    Have you used this don?
    ivanhoe likes this.
  14. slvrblkk
    slvrblkk
    Northampton, PA
    I tried Slip Plate on mine...didn't work as good as Dry Moly lube.
  15. don2222
    don2222
    Salem NH
    Yes it does help. Those are my pics.
    I like it better than dry moly.
    ivanhoe, slvrblkk and IHATEPROPANE like this.
  16. Lousyweather
    Lousyweather
    FWIW, graphite, any other dry lube, ok, give it a try. Not sure I support the aluminum tape though. Eventually the adhesive fails, then the tape heads south into the drive assembly. Not sure what the tape might do inside the feed assembly system, so, I think I'll pass on the tape fix, thankyou.
    ivanhoe likes this.
  17. imacman
    imacman
    Denver, NC
    I've used the tape since back in my Astoria days ('08 - '09). The surface has to be cleaned well...... I used alcohol on a rag. And I only used the tape in the corners where I'd seen pellet hang-ups. Never had an issue with it "failing".....I ran the end way up to the very top of the hopper so there wasn't any edge for the pellets to pull on as they slid down, and used just 1 continuous piece. It was furnace tape, so I never had an issue with the adhesive failing.
    ivanhoe likes this.
  18. PoolguyinCT
    PoolguyinCT
    AWFP great heat but were my big "sticker" started to really pizz me off
    wildwest, ttdberg, slvrblkk and 2 others like this.
  19. IHATEPROPANE
    IHATEPROPANE
    Green Supremes slid a bit better. Was able to burn 30 lbs before the stove ran out. At about 25 lbs you could tell that the auger was no lo get feeding a full load.
    wildwest, ttdberg and slvrblkk like this.
  20. T-Stew
    T-Stew
    I tried tape on my Englander PAH and it helped with Somersets but these TSC Equine bedding pellets (white pine, high amount of fines) really stick still. I've come home from work many times with a stove the went out with nearly a full bag of pellets still in the hopper. :headbang: Happened two days in a row last weekend, house dropped to 58 the first day then 52 the next day. Took a whole day just to get it back up in low 60's and a second day to get mid/upper 60's running just the pellet stove. My fault though since I didn't check and top it off before leaving for work.
    will711, IHATEPROPANE and wildwest like this.
