440/460 hybrid
Discussion in 'Chainsaws and Power Equipment' started by Kg461, Feb 11, 2015.
  1. Moparmyway
    Moparmyway
    New York
    Keith.
    I have no doubt that you a fantastic job on that hybrid cylinder, but I am happy to see that you will look at that spot one more time to see if its something to be considered or if its just an ugly spot. Is the cylinder aftermarket ?
    Kg461 likes this.
  2. mdavlee
    mdavlee
    You see spots like that from time to time in cylinders.
    cgraham1, Moparmyway and Kg461 like this.
  3. Kg461
    Kg461
    Provencal, La.
    Oem 460 jug. Im sure its nothing as I ground the heck out of it and kept lookin at it and thinkin how hard it was. I kept tkinkin dang ill knock that shiny spot out but its solid through whatever it is
    mdavlee and Moparmyway like this.
  4. Kg461
    Kg461
    Provencal, La.
    Okay fellows I was worried so up early and took cylinder off!!! :DIt was hard as a rock and shiny but I took a diamond ball burr and cleaned her up!! Gave me an excuse to take cylinder off and see how things were wearing in anyway!!:) Thanks for the input,help, and concern fellows!!:thumbs:
  5. Kg461
    Kg461
    Provencal, La.
  6. Moparmyway
    Moparmyway
    New York
    :thumbs: :thumbs: :thumbs: :thumbs: :thumbs: :thumbs: :thumbs: :thumbs: :thumbs: :thumbs: :thumbs: :thumbs: :thumbs:
    Kg461 likes this.
  7. prell 73
    prell 73
    ia
    Casting defect maybe?????
    Kg461 likes this.
  8. Kg461
    Kg461
    Provencal, La.
    Ya I think so. Looks good now plus gave me a chance to look how the rings were wearing on the port edges
    Moparmyway likes this.
  9. prell 73
    prell 73
    ia
    That looked good no Knicks or anything .
  10. Kg461
    Kg461
    Provencal, La.
    Thanks
  11. Unicorn1
    Unicorn1
    Amarillo, TX
    Nice work!
    Kg461 likes this.
  12. Ralphie Boy
    Ralphie Boy
    Rabbit Hash, Kentucky
    They don't call it the "wild" west for nothing! :rootintootin:
  13. Kg461
    Kg461
    Provencal, La.
    Got the Cannon 22" Superbar in and a Oregon CK semi skip square chisel. Will try to make some cuts this week
  14. prell 73
    prell 73
    ia
    :dex:damm that's a sweet saw.
    Chvymn99 and Kg461 like this.
  15. Chvymn99
    That's Sweet! :dex:.... And one heck of a rockin' setup....:rootintootin:
    Kg461 likes this.
  16. Unicorn1
    Unicorn1
    Amarillo, TX
    Very nice work on the Stihl. A member here has a 044 that he wants to rebuild, do you recommend the piston/cylinder upgrade? Could a novice do this work? Thank you.
    Edit: If base material needs to be removed, no way I'd be comfortable doing/helping.o_O
    Kg461 likes this.
  17. Moparmyway
    Moparmyway
    New York
    I run 32" full comp on my self ported 044.............. no problems
    That hybrid saw wont need any type of skip chain, unless you plan on running lengths greater than 32-36
    mdavlee, Kg461 and concretegrazer like this.
  18. Kg461
    Kg461
    Provencal, La.
    I like semi skip square on most my bigger saws
  19. Kg461
    Kg461
    Provencal, La.
    Its worth the effort no doubt but not for a beginner! The cylinder around the base has to be clearanced on each side as well as each side of the outer transfer housing to clear flywheel and clutch side. Then center the cylinder and work the mounting holes in the cylinder to fit the crankcase mounting holes
  20. DexterDay
    cgraham1, Chvymn99 and Kg461 like this.
