Notch or not
Discussion in 'The Wood Pile' started by Woodrat1276, Feb 4, 2015.
  1. Firewood Bandit
    Firewood Bandit
    I agree. You want as much holding wood as possible to avoid the chair.
    Horkn likes this.
  2. Scotty Overkill
    I can tell you from first hand experience that I've done dozens of trees like that and you most certainly do NOT want to cut it without a notch. The triangle method is good, but I still trust the bore cut method the most. Steep angle face notch only 1/5 or so into the tree, plunge cut to make your hinge and work your way towards the back of the tree. But as with any cut, different variables can affect the outcome. Make sure the tree isn't hollow.....
    One of the many reasons I like to take the top weight out of leaners......takes a lot of the force out of the tree....
  3. Ralphie Boy
    Ralphie Boy
    Rabbit Hash, Kentucky
    I agree with RParrotte and the others that said to notch and the bore cut. I took Scottyoverkills's recommendations dropped a couple of leaners like yours using that method.
    Horkn and Scotty Overkill like this.
  4. Ralphie Boy
    Ralphie Boy
    Man that's ugly!o_O
    Horkn likes this.
  5. Ralphie Boy
    Ralphie Boy
    How is the left and right side of the triangle cut? Is it similar to cutting the face cut? What's the angel of the cut? I've found lots of pictures and diagrams but no cutting instructions. But I'm A.D.H.D and surfing for long periods of time turns me into a werewolf. :rofl: :lol:
    Horkn likes this.
  6. Ralphie Boy
    Ralphie Boy
    You took that picture before last night's snow didn't you....:cool:
    Horkn likes this.
  7. jetjr
    jetjr
    Pa/Md line
    I worked with a guy that almost got killed by a barber chaired tree. Couple more variables were in play but still very dangerous.
    Horkn, Stinny and Scotty Overkill like this.
  8. mdavlee
    mdavlee
    It's just the start of the back cut. Then you finish the strip of the TmT faster since it's not as wide.
    If the hollow part isn't right where the notch would end at 30-40% depending I would go that way with a Humboldt and back it up quickly with a long bar. I did one a few weeks ago almost like that and faced it normal and had 2 little strips of hinge left.
    Sam likes this.
  9. Woodrat1276
    Woodrat1276
    Ky
    Yeag but there isnt much snow there today though. I messesd around piling up some if the limbs today didnt feel like cutting any today
    Ralphie Boy likes this.
  10. Backwoods Savage
    You have a couple leaners in the picture but apparently you are talking about the one in the center.
    1. Always notch!!!!! But on hard leaners I tend to not notch as deep.
    On how you do the back cut, there are many ways to do it and most will lean to the bore cut. I simply cut as normal, sort of but will lean a bit toward the triangle cut. Not all the way on that triangle but somewhat like it. When you are ready to cut the center, use the best saw you have and cut it fast and get out fast. Any sign of movement (keep your eye on the kerf), stop the saw and get out fast.
    Horkn likes this.
  11. mdavlee
    mdavlee
    I watch the top as it will show movement before the kerf usually. You can hang a wedge in the kerf loosely or an axe to show movement.
    Gunn and Horkn like this.
  12. Ralphie Boy
    Ralphie Boy
    As far outside I got today was the front porch to bring in 5 splits for the 80 at 0830. Guess I'll do it again at about 2030 tonight. Tomorrow is another day....
  13. ansehnlich1
    ansehnlich1
    Man I ain't feelin' good about this one.....kinda like the little fella that peeks through his hands.....fearing to peer out through his fingers at what's going on.
    Big tree, big top, sheesh, I've seen SNAP, BANG, WHISTLE PAST, THUMP on a small scale.....would hate to see flyin' shrapnel on that thing.
    Horkn likes this.
  14. mike bayerl
    mike bayerl
    Horkn likes this.
  15. Horkn
    IMG_20150124_111103398.jpg IMG_20150124_111057844.jpg Absolutely Mike. That one you just referenced had me VERY leery of this one I cut several days after your post.
    Heavy leaner, rotten center. The only thing for certain was which direction the top would go. I called my buddy before, and after I had it down with texts in between to let him know I was ok.
    mike bayerl likes this.
  16. mike bayerl
    mike bayerl
    Nice work!
    Horkn likes this.
  17. Horkn
    It took more work to get it all the way to the ground, but I was too tired to get more pics of it when it gave up the ghost.
  18. Mag Craft
    Horkn and mike bayerl like this.
  19. gunny100
    gunny100 Banned
    lebanon,pa
    looks dangress
    Horkn and ansehnlich1 like this.
  20. bert the turtle
    bert the turtle
    I got into a hollow ailanthus that I didn't know was hollow. Big and near my barn. Got the notch in and discovered the hollow on the back cut. Nothing to do at that point but keep going and it scared hell out of me.
    I agree with everyone who advised a shallow face cut. What do people think about wrapping a tractor-trailer size binding strap a bunch of times around the part just above the cut to reduce the chance of a barber chair? Seems it has a good chance of helping with no downside, but there could be something I'm not thinking about.
    Horkn likes this.
