having trouble with my Harman TL300
Discussion in 'Modern EPA Stoves and Fireplaces' started by swamp, Jan 6, 2015.
  1. swamp
    swamp
    Altoona
    Should've seen the writing on the wall when I purchased it....on clearance from $2500 down to $1250 with the stainless steel cooking grate
    fox9988 and wildwest like this.
  2. fox9988
    fox9988
    NW Arkansas 72717
    On the bright side, you didn't pay $2500.
  3. jdonna
    jdonna
    MN
    Well its hard to blame yourself for getting a good deal on something. Maybe it is something simple and it will work out well for you, if not there are plenty willing to take on a stove that needs work on craigslist.
    Pallet Pete and wildwest like this.
  4. wildwest
    Wyoming high plains
    Hopefully you and Scotty can figure something out this weekend!
  5. jdonna
    jdonna
    MN
  6. swamp
    swamp
    Altoona
  7. swamp
    swamp
    Altoona
  8. swamp
    swamp
    Altoona
    These temp pics were taken around 1130 pm (as soon as I got home from work)....approx 1" of coals left in the firebox after filling it up before I left for work at 1030am......currently trying to get a bigger base of coals as I just filled firebox up with oak split into 1" x 2" pieces and air intake fully opened
  9. jdonna
    jdonna
    MN
    Sometimes you have to sacrafice a 1/4 load of wood to get that 3 to 4" coal bed. I used to rake a pile of coals near the shoe brick at the back of the stove, seemed to help light it off.
  10. wildwest
    Wyoming high plains
    Any way to try an OAK on your stove?
  11. swamp
    swamp
    Altoona
    An OAK??
  12. HDRock
    outside air kit
  13. swamp
    swamp
    Altoona
    I have the option for outside air on the back of the stove but really don't feel like punching another hole in the block foundation plus I'm another step closer to buying my first house and it has a fire place which is a bonus so the TL300 will probably be for sale and an insert is in the future. .....
    For now I picked up a moisture meter and a magnetic flue thermometer....the majority of my wood is between 9% and 18% (hopefully this is ok) and my flue temp is not quite 500°....so it looks to be good for now. ..fingers crossed 14206987974721512151045.jpg
  14. Certified106
    Certified106
    In The Hills
    My buddy has a Harman and he has to burn it HOT to get and keep the secondary to light and stay lit.
    swamp and wildwest like this.
  15. wildwest
    Wyoming high plains
    How did things turn out?
  16. JA600L
    JA600L
    Lancaster, Pa
    I almost bought one of those stoves.... until the guy behind the counter told me not to? Haha anyway glad I dodged that bullet.
    concretegrazer likes this.
  17. weatherguy
    weatherguy
    central massachusetts
    Too bad they're so finicky, its a good concept and gets long burn times when running properly, the only problem is getting it to run properly.
  18. swamp
    swamp
    Altoona
    UPDATE........my TL300 is working fine. ...I've been burning really hot in fact the magnetic burn indicator on the pipe is reading in the red (over fire) Around 600°...this is the only way I can get the secondary to light and stay lit, burn, and put off heat....all of my wood is between 8% & 19% moisture. ..which I'm thinking is decent.....still going to unload it come spring and look for a coal/wood stove
    Pallet Pete and fox9988 like this.
  19. fox9988
    fox9988
    NW Arkansas 72717
    Did you find a problem or just change your burning habits?
    :thumbs: Most people consider anything in the teens as optimal.
    Glad the stove is working for you now. A good stove is a pleasure to run, hopefully next winter goes much better for you.
  20. concretegrazer
    concretegrazer
    Southwest MO
    Are you sure the thermometer is readind true?
