How much compression does a MMWS have???
Discussion in 'Chainsaws and Power Equipment' started by Evanrude, Jan 11, 2015.
  1. Sunfish
    Sunfish
    Success Mo
    Randy does build some good comp into the saws he does...
    I read on the interwebs that Stihl plastic was "less plasticy" than other brands? Seriously!
    o_O
    concretegrazer, Hedgerow and Evanrude like this.
  2. Evanrude
    Evanrude
    Byron, MI
    Keep prying, Don :chef:. For what it's worth, comparing my Jred to the Stihls, the Stihl saws do have thicker, more rigid covers.
    DexterDay and Sunfish like this.
  3. Sunfish
    Sunfish
    Success Mo
    OK, OK, I'll stop now...:cheers:
    Evanrude and DexterDay like this.
  4. Moparmyway
    Moparmyway
    New York
    Another Hybrid customer with a smile !!
    I love me a Hybrid !!
  5. DexterDay
    This is my little 261.. It's about 190 psi :dex:
    Never tested my 460...
  6. cgraham1
    cgraham1
    Nor Cal
    Just tested today... both around 180 psi. I thought they would have more. Like I said before, the 288xp I got from Neal Murphy has 183 on the same gauge and it's a real pain in the butt to pull over. image.jpg
    Dolmar 7900...
    concretegrazer and Evanrude like this.
  7. Evanrude
    Evanrude
    Byron, MI
    Here's my 260 done by Randy a couple years ago. What's your elevation, Clint?
    concretegrazer likes this.
  8. cgraham1
    cgraham1
    Nor Cal
  9. mdavlee
    mdavlee
    Clint I had 3 of those gauges not read correctly before I give up and bought a snap on off ebay.
  10. Evanrude
    Evanrude
    Byron, MI
    It is kinda funny how they all say 180
  11. clemsonfor
    Ha, , I didnt even notice that.
  12. cgraham1
    cgraham1
    Nor Cal
    They're not all 180. I do have a SnapOn tester somewhere. I guess I'll have to dig it out.
    044 w/ new Meteor piston... image.jpg
    288xp w/ base gasket delete... image.jpg
    concretegrazer and mdavlee like this.
  13. Hedgerow
    Hedgerow
    SW Missouri
    My fastest saws have less than 200psi... All in the 170 - 190 range... The smaller saws seem to handle higher comp better than the bigs..
    Though I have seen some @ 210+ that really hauled the mail..
    Sunfish, concretegrazer and cgraham1 like this.
  14. Evanrude
    Evanrude
    Byron, MI
    I built a small saw recently that had an unexpected comp reading. I used an 026 cylinder and Meteor piston in an 024 Super case. After almost 3 tanks of fuel, it is showing 185 psi already.
    Do you mean they run better with higher comp, or the lower end can take a better beating?
  15. Hedgerow
    Hedgerow
    SW Missouri
    A. I think the smaller saws' lower ends can take a bit more comp. Also, the higher comp "small" saws I've run seem "Stronger" as in more low end push...
    B. Above being said, the fastest saws are not working at lower rpm's. In a race, chain speed is king... And there are no corners to come out of in a chainsaw race, it's all straight forward full throttle...
    In developing high rpm power, port timing is more important than sheer compression, but for a work saw, the higher compression may give you the feel you're looking for. The "I stop for nothing" feeling...
    Then, of course, there are some exceptions to the rule... As always..
    mdavlee, Sunfish and Evanrude like this.
  16. MasterMech
    These engines only have 3 moving parts in 'em ya know, how complicated could they be? :faint:
  17. Hedgerow
    Hedgerow
    SW Missouri
    For simple minds like mine, they can cause you to think yourself in a complete circle and end up back where you started...
  18. Unicorn1
    Unicorn1
    Amarillo, TX
    You can hardly notice the damage.:D
    clemsonfor likes this.
  19. Mastermind
    Mastermind
    Tennessee
    That's an ouchie.....
  20. nmurph
    nmurph
    Hey fellows...I forget this place exist. Maybe ya'll liked it that way!!
    Clint- NDBGD 288's are nasty. I have one in the shop I just finished and am waiting on my test log to get from under the water (well, just where you stand, it's up on logs). I dread starting it. I'm no shrinking pansy, but I use the decomp every time on every saw that has one (OK, I skip it on the 401!). I've had 3 shoulder surgeries and one elbow surgery. They aren't fun and I do everything I can to avoid having problems in them (only the elbow was caused by saws...the others were sports related).
    Just remember, Dr.'s love hero's- it keeps them in boats and planes.
