Gunk in bars
Discussion in 'Chainsaws and Power Equipment' started by crzybowhntr, Dec 18, 2014.
  1. crzybowhntr
    crzybowhntr
    WV
    Is it normal to get a fair amount of junk out of a bars grooves between filling the tank? I`ve started flipping the bar between fillings and noticed a lot of junk needing to be removed.
    Thanks
  2. MasterMech
    Depends on the wood mostly. I've had more build-up in hardwoods with thick bark or cutting standing dead trees than something like Maple or Oak.
    Drvn4wood and CTYank like this.
  3. crzybowhntr
    crzybowhntr
    WV
    `nough said. I`ve been cutting standing dead locust. :saw::tree::fire:
    Chvymn99 and MasterMech like this.
  4. Guido Salvage
    Guido Salvage
    The heart of the Bluegrass
    Some of it is determined by how sharp your chain is. Sharp chains pull chips, dull ones create dust which can pack the bar grove.
    CTYank and Bluelou like this.
  5. crzybowhntr
    crzybowhntr
    WV
    does chain tension have anything to do with it?
  6. MasterMech
    Some, you will get more junk in there if the chain is really loose. A slightly loose chain shouldn't matter much.
  7. bogydave
    I seem to have gunk in there every time I
    clean the saw. I put a piece of stiff wire in the toolbox the right size to
    clean it out.
    I clean & turn the bar after every cord or 2.
    Maybe it should be left in there, it's soaked well with oil ?
  8. Carbine
    Carbine
    Wet or dry, sharp chain or not.. you will get plenty of crud that will build up in the bar groove. I dont have a routine, but clean it out when I have the chain off. Stihl makes a depth gauge (non progressive), with a nice little bit on the end for getting down in the bar channel.
    crzybowhntr and mdavlee like this.
  9. mdavlee
    mdavlee
    It happens. Just clean it with a jig saw bale when I think about it.
    $ooline, crzybowhntr and CTYank like this.
  10. NH_Wood
    NH_Wood
    I clean my saws after I cut - I run compressed air down the groove (away from the sprocket) and most of the build up gets blown out - also run air through the oil hole in the bar - they get build up pretty quick. Every once in a while I'll take a piece of broken piston ring and run down the groove, but normally not much there - the air does a pretty good job. Cheers!
    $ooline, Ron660 and crzybowhntr like this.
  11. $ooline
    $ooline
    WI
    A dime is just about perfect for stihl .325 .063 gauge bars to clean em out fwiw
    Drvn4wood likes this.
  12. MasterMech
    Isn't there some kind of rule of thumb with coins? The dime is .050", penny .058 and a nickel for .063?
  13. mdavlee
    mdavlee
    A quarter is used for one.
    $ooline likes this.
  14. MasterMech
    You know I'm mic-ing pocket change in the shop tonight..... :rofl: :lol::picard:
    $ooline and mdavlee like this.
  15. mdavlee
    mdavlee
    Here you go courtesy of Baileys.
    Quarter = .063 gauge
    Penny = .058 gauge
    Dime = .050 gauge
    MasterMech and $ooline like this.
  16. $ooline
    $ooline
    WI
    Sounds good:thumbs:. Just checked and although the quarter fits in .063, the penny slides through better
  17. mdavlee
    mdavlee
    The change was actually to check what gauge without measuring tools.
    MasterMech likes this.
  18. $ooline
    $ooline
    WI
    Gotcha, ya one day last year i grabbed a dime to clean the grooves just to try and it worked pretty good. Penny works great too for .063
    mdavlee and crzybowhntr like this.
  19. bigbarf48
    bigbarf48
    Stone Mountain, GA
    I get build up in mine, just scrape it out with a pocket knife every so often
