So I bought a 660
Discussion in 'Chainsaws and Power Equipment' started by JoshC, Nov 17, 2014.
  1. JoshC
    JoshC
    Culloden, WV
    I did. I was just posting back after my tune up with the results. I'll end up putting some rings in it i'm sure.
    mdavlee-it's got a brand new Oregon 72LGX chain, rakers haven't been touched on it.
  2. JoshC
    JoshC
    Culloden, WV
    Ok, someone let me in on the secret. How do I get to the head bolts? Find are in the way on each corner and its tight.
  3. JRSDWS
    JRSDWS
    Central Illinois
    There should be holes cast into the cylinder that allow you to go through the top. I can vaguely see one in the pictures just left of the spark plug.
    mdavlee and JoshC like this.
  4. JoshC
    JoshC
    Culloden, WV
    Thank you! I thought about that right after I posted that and walked to the house from the barn. Headed that way after dinner.
  5. DexterDay
    Your gonna need a 5"-6" long T 27 torx bit. Or a screwdriver with the T-27 bit to remove, but having a way to properly torque it down on reassembly helps. Rather than just getting it "tight".
  6. JoshC
    JoshC
    Culloden, WV
    Yeah that's going to be tricky. I don't have the size so I'm going to have to find one.
  7. trx250r180
    trx250r180
    I use the t-27 snap on t-handle for jug bolts
  8. 94BULLITT
    94BULLITT
    Frederick County, VA
    Home Depot has a set of t handle torx on sale now for $9.99. I'm not sure if it has a T-27 though.
  9. Moparmyway
    Moparmyway
    New York
    Those 4 bolts are tight, you have a 50/50 chance of snapping those $10 sets
    mdavlee, JoshC and Evanrude like this.
  10. JoshC
    JoshC
    Culloden, WV
    Finally got a tool from Stihl. Couldn't find anything else locally. Rings are in and saw back together. Exact same compression as before. I bought it to resale, so that's what I'm going to do.
  11. Kg461
    Kg461
    Provencal, La.
    Checkk ur gauge with regulated compressed air
    bigbarf48 likes this.
  12. JoshC
    JoshC
    Culloden, WV
    Anyone know for sure what the compression should be? I've read different numbers different places. And it varies widely.
  13. Kg461
    Kg461
    Provencal, La.
    Around 150 and up
    94BULLITT likes this.
  14. mdavlee
    mdavlee
    160-170 is common
    94BULLITT and Kg461 like this.
  15. 94BULLITT
    94BULLITT
    Does the compression gauge you are using have a Schrader valve in the end of it? It should look about like a tire valve.
    Kg461 likes this.
  16. JoshC
    JoshC
    Culloden, WV
  17. cnice_37
    cnice_37
    Compare your reading with a known good saw. Some gauges aren't very accurate (like mine.)
  18. Kg461
    Kg461
    Provencal, La.
    Id get a good gauge
  19. 94BULLITT
    94BULLITT
  20. Moparmyway
    Moparmyway
    New York
    Something aint right !!
    Is there any way that you could video the saw bogging out in the cut ?
    mdavlee and Kg461 like this.
