New SS combustor installed last night.
Discussion in 'Modern EPA Stoves and Fireplaces' started by bogydave, Nov 14, 2014.
  1. Todd
    Todd
    NW WIS
    Woody Stover likes this.
  2. fox9988
    fox9988
    NW Arkansas 72717
    Todd, you're not monitoring cat temp this year?
  3. fox9988
    fox9988
    NW Arkansas 72717
    I installed a DuraFoil SS cat last Dec. It works much better than my original SS cat ever did IMHO.
    concretegrazer likes this.
  4. Woody Stover
    Woody Stover
    Southern IN
    Dammit, man, you're making me want to spend more money! :rofl: :lol:
    concretegrazer and fox9988 like this.
  5. BDF
    BDF
    That is exactly what I have found: they do not actually fail outright but they deteriorate in performance exactly as you describe. My yardstick of when it is time to get a new combustor is when one lights off and starts the burn only to stall as soon as the draft is cut back any amount at all. The combustor still works but it has to be used a lot harder to maintain the catalyst function.
    Brian
  6. Woody Stover
    Woody Stover
    Southern IN
    Did you ever try simmering one out at that point? I've done it with ones that were OK, but never one that had seriously declined in performance. I'm wondering how much I can stretch the life of one. But I guess I won't know, if I rinse all of them every couple of years...
  7. Todd
    Todd
    NW WIS
    Not yet, my cat probe only lasted one year so I'm a little Leary of buying another.
  8. weatherguy
    weatherguy
    central massachusetts
    Wow, that thing is really glowing, does that kind last longer?
  9. BDF
    BDF
    I did not try that until last year and it did seem to perk it up somewhat. It was in the old stove though and so got very little time on it and very late in the year so I did not really get a chance to get a decent idea of how much it improved.
    I will probably do it again at the end of this year though. Combustors really are critical to the performance of a cat. stove and running a stove with a sluggish or under- performing combustor leaves the stove a lot less efficient and puts a lot of creosote into the flue in my experience. One of the critical things for me in choosing a new stove was the cost and ease of installation of the combustor; the I.S. cat. is $125 new and it would certainly be worth it to me to buy one every other year if that is what it takes to keep the stove running at high efficiency. I believe a correctly operating cat. is easily worth a cord of wood or more per year and it is well worth $65 annually for the cat. I am hoping the cat. lasts much longer than that in this new stove of course, just sayin' that it is pretty easy to put a value on changing out the combustor IMO.
    Brian
    papadave likes this.
  10. fox9988
    fox9988
    NW Arkansas 72717
    It glows all the time. Well, not all the time but it glows a lot. If it's glowing you know it's working, but it is often working great with no glow as per my cat probe, WS ,BKVP and others. I'm sure your Princess insert cat glowed often, the Keystone just gives a nice cat view from the recliner.
  11. Woody Stover
    Woody Stover
    Southern IN
    I looked on the Woodstock site, but could only find the cats for the Fv and Ks, not the IS or PH?? I knew the others were $125 but thought maybe the hybrids had a different or more expensive one.
  12. fox9988
    fox9988
    NW Arkansas 72717
    Last longer? I don't know but I think the technology is moving forward.
  13. fox9988
    fox9988
    NW Arkansas 72717
    What happened to it?
  14. Woody Stover
    Woody Stover
    Southern IN
    Maybe it melted! o_O But seriously, yeah, it should have lasted longer than a year I would think. Heck, I'm pretty sure the probe in the Buck 91 is 5 yo or more and still works well. I think Todd had the probe bent around the shield...or was that his previous setup?
  15. Todd
    Todd
    NW WIS
    It was a Auber 10" thermocouple probe that was inserted into the cat probe hole in the back of the stove. When I fired up the stove the first couple times this year it was reading hundreds of degrees low and if I wiggled the wire it jumped all over the place. Maybe there was a short or break in the wire?
    After last years data from the cat probe I'm pretty confident what the cat temps are just by looking at the surface temps and the glow. Usually they were just over double the stove top temp. I don't think I ever went over 1600 CT even with a 700 STT.
  16. Highbeam
    Highbeam
    125$ is a great price. That really makes all this cleaning and monitoring for deteriorating performance a waste of time. Just pop a new one in.
    I wonder why it is so cheap. The IS cat looks huge! much bigger than my princess cat but my princess cat is just under 300$.
  17. BDF
    BDF
    The price given to me back in the spring was $125 for the I.C. and $175 for the P.H. If I remember right, I think the I.S. uses the same combustor as the Fireview but the P.H. combustor is different.
    Brian
  18. BDF
    BDF
    That was a significant part of my stove purchasing decision: how much the cat. cost, how hard it was to clean (vacuum or blow off) and how hard it was to remove and reinstall. The I.S. won by a huge margin because the cost is low, the access and removal extremely easy and require no tools; just lift the stove top, reach in and pick it up.
    Just as a reference: the Blaze King princess seems to use a round combustor, 7" dia. X 2" thick. The I.S. uses a rectangular combustor with a flange on the outside, 10" X 5 1/4" X 2 5/8" thick.
    Also the placement of the I.S. combustor is ideal in my opinion: directly above the firebox, with the cells facing 'up' so they tend to stay cleaner and not collect ash. It is easy to light and keep lit even with a very low fire because it is directly above the firebox and the exhaust temp. of the firebox is hottest there.
    Brian
  19. Todd
    Todd
    NW WIS
    I've wondered this as well, looking at Keystone cats from other sources are almost twice as much as Woodstock. Maybe WS just sells them at cost to keep their customers happy?
  20. BDF
    BDF
    Well, I assume any / all commercial businesses make a profit on the things they sell, and Woodstock Soapstone should not be an exception. Besides, I believe they weld the flange on that specific combustor or have the combustor mfg. do so, so the combustor is unique to them as far as I know.
    I suspect Woodstock is making a reasonable profit and others are making a larger profit is what we are seeing here. I have to believe the cost of making a full production run of combustor material is quite low; we are simply used to the inflated prices from others because that has been the norm. before. At least in my opinion of course.
    Brian
