Using a Stove Pipe Damper
Discussion in 'Modern EPA Stoves and Fireplaces' started by Grizzly Adam, Nov 20, 2014.
  1. Certified106
    Certified106
    In The Hills
    Very nice! I used to have access to a flue gas analyzer and used it to tune boiler systems. What flue temps do you usually run and what stove do you have?
  2. Certified106
    Certified106
    In The Hills
    I am a geek about data.... blame it on being an engineer I guess.......lol
  3. My IS heats my home
    My IS heats my home
    Albany, NH
    I saw the writing on the wall, just sitting back and enjoying the ride :)
    NW Walker likes this.
  4. NW Walker
    NW Walker
    Olympic Peninsula
    Well, my stove is a homemade mass heater, so it's a very different beast than the rest here. Here's a graph from the machine from a run on Tuesday, I'm playing with some new air settings and trying to dial it in. My flue temp is bouncing around about 15°F due to the way the gasses are routed through the mass, but average is about 110°F.
  5. NW Walker
    NW Walker
    Olympic Peninsula
    I saw what you did there IS! I'm taking the bait anyway.
  6. My IS heats my home
    My IS heats my home
    Albany, NH
    Been there, done that...
    you came up with a nice chart with numbers, that will work
  7. Certified106
    Certified106
    In The Hills
    That is impressive and something to be proud about! Great job tuning that thing in.
  8. Grizzly Adam
    Grizzly Adam Guest
    Me too, but I know Matt and wasn't worried for a second.
    How did he come up with that? SCIENTIFICALLY!
  9. Certified106
    Certified106
    In The Hills
    That's what gas analyzers do you select the fuel type and it provides that info. You can do the hand calcs also but it takes more time.
  10. golf66
    golf66
    I agree with this. On my prior 2010 EPA tube stove, I partially blocked off a permanent draft opening with a magnet and the stove went from being absolutely uncontrollable to being ornery. The Ideal is spoiling me compared to the old stove.
  11. Grizzly Adam
    Grizzly Adam Guest
    60 when we got home.
  12. Grizzly Adam
    Grizzly Adam Guest
    Day 2. 64 degrees in the house this morning. 7 degrees outside.
    papadave likes this.
  13. DaveGunter
    DaveGunter
    Sounds like it's working for you. What's your chimney set up, do you have good draft?
    I disagree with the woodheat.org advice, for my setup. I think more control is always better. My draft is very strong. On a full load with the flue damper open I can shut the air all the way and still have an active fire with blazing blow torch like secondaries, with a flue/stove delta of about 250. Close the damper almost all the way and open up the air a bit and I still have an active fire with secondaries that look "lazier" the stove temp goes up and the flue temp goes down.
    Chestnut likes this.
  14. Grizzly Adam
    Grizzly Adam Guest
    We have a 2 story installation, 10 foot ceiling on thd downstairs, two 30 degree elbows. Draft is good.
  15. oldspark
    oldspark
    NW Iowa
    My guess is you are slowing the fire down some but that's just me, I do not think the air control is all that precise on the Drolet and maybe the damper is giving you more control of the fire.
    It might work for me me also, I would like to get longer lower burns at times (a lot actually).
    I will add for the first time is 3 years my house is warm again.
    papadave, DaveGunter and Grizzly Adam like this.
  16. Grizzly Adam
    Grizzly Adam Guest
    What Im wondering is if im slowing convection up the pipe.
  17. Trilifter7
    Trilifter7
    Waynesville, OH
    I played with my damper some last year and had the same problem. It helped slow the draft down during peak blaze but seemed to stall the fire box out towards the end of the burn. Every time I tried it I came home to a cold stove and cold coals. I think if I could increase the airflow after the peak burn or have the damper open back up it would work great, but just one setting for the entire burn just doesn't seem to work with my setup.
    I've got better wood this year so maybe I'll play around with it again.
    Mitch Newton likes this.
  18. Trilifter7
    Trilifter7
    Waynesville, OH
    I forgot to mention my setup is double wall pipe with a flue probe. My temps normally stay between 400-600F as well. Soft wood and I can keep it around 400-450F and hard wood loads always burn around 600-650F.
  19. DexterDay
    If it gets under 70° in this joint, the wife and kids are complaining. . :D
    As for the damper? It's still a restriction. So whether you close the air more on the primary, or close the damper more? Should yield the same amount of air through the stove.
    What I have noticed using the damper. Is the coals do not burn down as well, because you restrict the flue, and don't allow the intake to pull in what it would if it was open.
    Current temps here. It's only getting down to 30° tonight. As the outside temp goes down, the inside temp goes up. Below 15° outside and it's normally 73°-76° throughout. :thumbs:
    Sam likes this.
  20. Huntindog1
    Huntindog1
    South Central Indiana
