Saw chain common cutter types used by wood cutter here.
Discussion in 'Chainsaws and Power Equipment' started by bogydave, Feb 16, 2014.
Which is your most favorite chain?
  1. Stihl RS
    25 vote(s)
    52.1%
  2. RS3
    0 vote(s)
    0.0%
  3. Oregon LGX
    13 vote(s)
    27.1%
  4. Oregon LPX
    4 vote(s)
    8.3%
  5. Stihl RM
    6 vote(s)
    12.5%
  1. Machria
    Machria
    Long Island, NY
    Aren't the first two choices the same? RS and RS3 RS3 is "Single-Humped drive link" version of an RS chain, right?
    I find the chain docs very confusing... and apparently so do the dealers! I also wish they would include a file size code with each. So the below chain SHOULD be: 25" 84 3/8" 0.05" Rapid Super 13/64" (file size)
  2. DexterDay
    How do I go about getting one of these? ;) I want one..
  3. bogydave
    RS3 has a safety hump to reduce kick back
    RS no safety hump
    RSF is RS full skip tooth chain.
  4. Sunfish
    Sunfish
    Success Mo
    From the folks I know using sq, it does not dull faster. Takes practice to be able to file it right, I'm not there yet.
  5. Machria
    Machria
    Long Island, NY
    Can't wait to try that chain out to see what it is all about.
  6. bogydave
    I'd think the 362 would run a full comp chisel 25" chain just fine.
    Skip tooth will be no problem.
    I tried a skip tooth on the 20" Husqy 359.
    Went back to the full comp chisels, RS & LGX.
    Much faster cutting, & no problem with rpm.
    This year , I actually found that somewhere near 3/4 throttle was more efficient cutting for me.
    I was getting bigger chips & faster cuts at lower speeds.
    No idea why, but I could feel & hear the difference.
    Maybe it was just me, but when you're out in the woods with no one around,
    having fun cutting , you seem to notice the small things. :)
    CTYank likes this.
  7. MasterMech
    Why monkey with PS3 when you could have PS? ;)
  8. MasterMech
    Running a saw at less than full throttle under load can be bad for it. Saw carburetors are just not sophisticated enough to guarantee proper tune at less than WOT conditions. Lower RPM's will tend to lean out the mixture as well. Sounds like you could use a little lower raker on the chain. ;)
    Sunfish likes this.
  9. bogydave
    Thanks
    Saw is on the list for PM & winter storage .
    Needs cleaned , sharpened & fuel dumped
    I'll check the rakers, chain looks almost new, rakers not filed on it yet.
    Sure fast cutting green birch . :)
  10. Freakingstang
    Freakingstang
    still 3/8 chain has always used 13/64 although the oregon and carlton use 7/32"... also stihl changed their bars slightly this year and the 84DL 25" chain is now a 85DL... that will be interesting in a few years...
    MasterMech likes this.
  11. Moparmyway
    Moparmyway
    New York
    How many DL's ?
  12. Moparmyway
    Moparmyway
    New York
    How much of that roll is left ?
  13. MasterMech
    Lots. :D
  14. Moparmyway
    Moparmyway
    New York
    Want to swap a 56dl of the PS3 for 56dl of PS to see if there is a big difference ?
    Off the roll this PS3 is pretty sharp !
  15. DexterDay
    Pretty sure it's 60 DL? Not home to look..
    MasterMech, 60 is correct? No?
    I will PM you later. I have a loop I can send. Or I would buy the loop and your time (and shipping).
  16. Machria
    Machria
    Long Island, NY
    What's the "C" stand for on the side of the Stihl chains?
  17. bogydave
    Why?
    I can see it if you use the nose of the bar a lot, but even then , the hump just reduces
    the size of the bite the cutters take. Reducing kickback energy, but not stopping it.
    On the top & bottom of the bar, there's no real difference in performance.
    Cutting speed should be the same.
  18. MasterMech
    See the following....
    Cutting speed is very close until the nose of the bar comes into play as the same cutter is used. The only difference is in the drivelinks. But I can most certainly feel the difference once the nose of the bar is buried. So felling using bore cuts or bucking up wood beyond the bar length, PS really shines over PS3. And on a top-handle saw, With the bar buried in a trunk 20, 30, 40 ft up, I'm sure the tree jockeys appreciate the extra speed.
  19. bogydave
    I've run some LPX before I knew much about saw chain.
    Have a couple new ones. Gonna try to remember to run it next Oct.
    For my type of cutting I don't remember much difference between
    the LGX & the LPX for general cutting speed.
    Rare for me to bore cut but I sometimes use the nose when undercutting
    while bucking. I use the energy of the kick back to pull the saw into the cut.
    Might be a little safer & a tad slower with the LPX, not racing speed.
    I'd think safety chain would be a good thing when up in a tree. But
    I don't do that type of cutting to know , but I did it done on TV
    & I've seen some of Scotty's pictures :) LOL
  20. Moparmyway
    Moparmyway
    New York
    Any confirmation of how many DL's ?
