Picked up a MS290 on CL last night
Discussion in 'Chainsaws and Power Equipment' started by lknchoppers, Oct 21, 2014.
  1. clemsonfor
    I dont see the link welder?
  2. Chvymn99
    DexterDay likes this.
  3. DexterDay
    No link. Dave specifically said to search..
    Thanks Chvymn99. . Search function is great here. :thumbs:
    bigbarf48 and Chvymn99 like this.
  4. clemsonfor
    I thought he meant go to "link suppose to be here" I could not help my self.....
  5. lknchoppers
    lknchoppers
    Lincolnton, North Carolina
    OK here are some pictures of it I took last night. It came with the case too. I have to get some acetone to remove his initials all over the saw. This guy had two saws stolen prior to owning this one.
    fox9988 and WeldrDave like this.
  6. Jon1270
    Jon1270
    Pittsburgh, PA
    Use alcohol, not acetone. Neither is friendly to plastics, but the acetone could do real damage. I'd use rubbing alcohol (which is diluted) rather than straight solvent alcohol.
    WeldrDave likes this.
  7. clemsonfor
    Yea I would be care full with the solvents and plastics. Might dull them or partially melt them. Make sure you google that one close or get some more opinions from the experts here.
  8. lukem
    Make sure you test in a small area too. Acetone will take the plastic off along with the marker, most likely.
  9. bigbarf48
    bigbarf48
    Stone Mountain, GA
    I'd just leave the marker. Looks like a clean saw :thumbs:
  10. clemsonfor
    The top plastic can be replaced with huztle plastic cheap but I see he marked the handle up in the front n rear so thats a no go :(
  11. lknchoppers
    lknchoppers
    Where? Can you post the link? Thanks
    As far as the alcohol and acetone goes I have used it on plastics. It will take a small amount of plastic off if you use it sparingly. I would rather have a dull spot rather and just put my initials there. Put a little on a rag and wipe it quick and get more aggressive as needed. 3M adhesive remover is good too and doesn't harm surfaces.
  12. WeldrDave
    "If" you have a marine store near you or a boat shop of some sort, you can get an item made by interlux called 333 special thinner and it "won't" eat or harm the plastic. It may take a bit of elbow grease but it will take off the marker. As some said, I would just make black squares over the initals and call it a "designer saw" :p:D.
    lknchoppers likes this.
  13. Chvymn99
  14. clemsonfor
    Thank you I was not the only one thinking
    that he meant to post a link in this reply. Or was looking for the link.
  15. lknchoppers
    lknchoppers
    To remove the marks I will start off least aggressive with the alcohol and then acetone on a q-tip would be my last resort or I may color them in. Thanks for the link to the mod. For this weekend I will have to use it as it is, I have 3 cords to deliver and 6 to buck up and haul.
  16. lknchoppers
    lknchoppers
    Thanks for link to the muffler mod. I would like to do it soon along with retuning the carb.
    WeldrDave and Chvymn99 like this.
  17. clemsonfor
    You will realize cut times that are 30% faster I bet.
  18. fox9988
    fox9988
    NW Arkansas 72717
    I tried about everything to get permanent marker off a white plastic name tag recently; gas, glass cleaner, degreasers, surface cleaners, oven cleaner, etc.
    Nothing worked.
    Then I tried some Gojo with pumice hand cleaner, it wiped right off, completely.
    Not sure it would work on saw plastic.....
  19. CTYank
    CTYank
    CT Panhandle
    Or Dolmar PS-5105. Pro saw with fer-real power for price of 291, with both new. A no-brainer.
  20. WeldrDave
    My mod is real easy. Some others go to much more extreme. The mod I did kept it reasonably quiet and gave it more power than it had, I was happy :cool:
    Chvymn99 likes this.
