Chain for HARD wood
Discussion in 'Chainsaws and Power Equipment' started by lukem, Oct 18, 2014.
  1. GRIZ
    GRIZ
    I cut that type locus what is best for that I been using the yellow tab chain like was on my saw when I sent it to you. I got it back thanks:handshake:
    mdavlee likes this.
  2. mdavlee
    mdavlee
    33rm
    GRIZ likes this.
  3. nate
    nate Banned
    Palmer, AK
    All I run now is semi chisel. I got tired of full chisel hardly lasting. Little dirt in the bark or some punky junk in the log and it's done, while semi chisel lasts and lasts.
    CTYank, SquareFile and mdavlee like this.
  4. lukem
    I gave it a go with some semi chisel and it didn't help much.
    The chain doesn't look dull (has a glint on the cutter) and doesn't feel dull with a file (grabby when dull...slick when sharp) but it is still making as much dust as it does chips.
    After a couple cart loads the chain will need touched up but nothing terrible.
    milleo, Drvn4wood, basod and 4 others like this.
  5. Shawn Curry
    Shawn Curry
    Western NY
    I was seeing some sparks while cutting the old barkless locust I've been hauling lately. Thought it was probably from the dirt that accumulated under the bark. Tried wiping down the logs before I cut them, but I didn't get it all off.
    On the bright side, I got some practice using my new set of hand files! Touched up the rakers on a couple pre-hand-file loops, and I was back to large chips again! I have an el cheapo electric chain grinder I've been using up until now. Keeps them sharp, but after a few sharpenings, I end up with dust instead of chips.
    GRIZ likes this.
  6. mdavlee
    mdavlee
    If you see glint on the cutter it's dull. Should be a clean crisp edge.
    CTYank, splitoak and GRIZ like this.
  7. lukem
    Right...has no glint. Not dull...I guess I could have worded better above.
    mdavlee likes this.
  8. splitoak
    splitoak
    jefferson co wv
    Cmon luke I want some pics of that hedge..
  9. lukem
    Theres a cart load pictured above. Usually it is neon yellow when fresh cut and turns dark orange later. This stuff is already orange.
    WKEND LUMBERJAK likes this.
  10. fox9988
    fox9988
    NW Arkansas 72717
    The loaded cart pic disappeared. I saw it last night, now only a ? mark.
    I've been getting a lot of "bad gateway" errors, may be related.?
  11. lukem
    I can still see it.
    Medic!
  12. Hedgerow
    Hedgerow
    SW Missouri
    Yes.. Bad Gateway 3 times today... Weird...
  13. Chvymn99
    B
    Website issues according to The Grizz.... Due to volume.... He made a bulletin on it... FYI...
  14. HDRock
    clemsonfor and DexterDay like this.
  15. Hedgerow
    Hedgerow
    SW Missouri
    Looks like an LPX chain but ground at an angle more suited to a ripping chain...
    Should be pretty durable..
  16. HDRock
    it has some kind of heavy duty chrome plating applied too
    Hedgerow and PullinMyPoulan like this.
