St Croix hastings
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by Smokinpiney, Sep 4, 2014.
  1. Smokinpiney
    Smokinpiney
    "South" Jersey
    Yep, I installed the switch in the position where the contact would jump to the same bars I had I jumped to in manual.
  2. jtakeman
    Looks like the board you have is an older unit. The control board doesn't match whats in the manual from the web site. I'm digging to see if there is an older manual kickin around, But I think the jumpers on the back are different programs(feed rates).
    When it shuts down is it flashing one of the heat indicator led lights?
  3. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    If the switch is doing exactly what the jumper did then it should act exactly the same as the jumper assuming you have good connections and no solder bridges, as jtakeman says that doesn't exactly match the manuals online.
    That controller looks like mine to some degree and if it sort of is the same those jumpered pins select cycle timings.
  4. jtakeman
    I found this in a 2009 control board manual. Its what I thought, They are for the feed rates.
    I'd have a dig through this manual to see what it might have to help ya. The PDF is too large, You'll have to download from link posted.
    https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=15&cad=rja&uact=8&ved=0CDYQFjAEOAo&url=http://www.ncsg.org/wcmedia/documents/InstallationManuals/Digital_Control_Board_Service_Manual-2009.pdf&ei=OHI0VOzVPNegyATe24GgDQ&usg=AFQjCNGFw6gu_ntipj3gHrcQz7w1uYoldw&bvm=bv.76943099,d.b2U
  5. Smokinpiney
    Smokinpiney
    "South" Jersey
    Thanks guys for clearing up what those jumpers are for. I've had it with this thing for tonight. I'll work on it again tomorrow and see what i can figure out. Thanks for that manual jt. It's got alot more info than the one's i've found.
    jtakeman likes this.
  6. Smokinpiney
    Smokinpiney
    "South" Jersey
    Wellllll, i discovered one more clogged area in the stove. Don't know how i missed this one but i honestly thought it was supposed to be there. I tried to pull the ash clean out rod the other day and noticed that the grate wouldn't budge. I kept looking at the screw that attaches the shaker plate to the clean out plate thinking i had something in wrong because it seemed like the screw was stopping it from moving. When i first started cleaning this stove out i reached below the ignitor to check for ash buildup but it felt like a wall below it and i thought nothing of it. When i originally pulled the versagrate rod it looked like some type of hard insulation inside the hole that the rod went through. Turns out that "wall" i felt and the "insulation" i saw was a solid block of ash! o_O I had to break it apart with a screwdriver. Now the ash cleanout works just fine :emb:
    Here's the culprit
  7. imacman
    imacman
    Denver, NC
    WOW
  8. Rona
    Rona
    southwestern Minn
    Reminds me of myself a few times. Operator error rears its ugly head.
  9. jtakeman
    Holy shiznits, Are those bio bricks?
    wildwest and Smokinpiney like this.
  10. slvrblkk
    slvrblkk
    Northampton, PA
    Lol...I thought the same thing!
    jtakeman and wildwest like this.
  11. DexterDay
    That stuff is like "petrified wood" (ash) lol..
    Hard as a brick!!
  12. krooser
    krooser
    Waupaca, WI
    Times two...
  13. krooser
    krooser
    Waupaca, WI
    I'm trying to figure out a way for my toilet to supply fuel to my stove every time I flush...
    imacman, jtakeman and wildwest like this.
  14. Smokinpiney
    Smokinpiney
    "South" Jersey
    Pretty much! I'm not kidding when i say the entire area in front of the burn pot was jammed solid with that stuff. It felt like part of the stove. A few of those pieces were actually tough to break apart.
  15. jtakeman
    Eeeeeeeewwwwww! o_O
    :picard:
  16. Rona
    Rona
    southwestern Minn
    You could run a line from the senate and the whitehouse and have fuel for the rest of your life.
  17. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    You need to pass it through decontamination first or you might catch something.
    eatonpcat likes this.
  18. Birddog91
    Birddog91
    Lakes Region NH/Connecticut
    That's amazing that someone could not spend even a hour a year to do some cleaning. Looks like you are going to have a smooth runner by the time you are done!!
  19. savemoney
    Don't know how I missed this thread, but it has been a very interesting read. Smokinpiney you got a good deal and my money is on you getting that stove up and running the way it was intended. Pellet stoves are not for the plug and play crowd. Once you get through this you will be another experienced pellet stove owner ready to help the next guy.
    krooser used to have a saying in his signature that was something about the majority of pellet stove issues being related to a dirty stove. That saying stuck with me. It is so true.
    Smokinpiney likes this.
  20. krooser
    krooser
    Waupaca, WI
    85% of all stove problems are caused by dirty stoves… just like women"….
    eatonpcat, imacman and mithesaint like this.
