Pallet woodshed build
Discussion in 'The Wood Pile' started by Steve, Oct 22, 2026.
  1. Steve
    Steve
    Pefferlaw, ON
    I recently married a gal with a ½ acre property, a great little Vermont Castings woodstove and a dwindling supply of CSS poplar stored in a ramshackle wood shed. Time to fix that! I added what I had scrounged in the past few years and what had landed on the property after a major ice storm 1-½ years ago. Together we have about 2 full cords of shoulder and winter wood. But the aberration of a wood shed needed to be torn down and re-built. I am pretty frugal and have a few sources of pallets available, so I planned this:
  2. Steve
    Steve
    Pefferlaw, ON
    I am air nailing the pallets together and reinforcing them with 2x3' and 2x4's inside. The top two are the outside walls, the third one down will be the centre wall and the bottom two will be the roof. The floor deck is made of 6 pallets and is 12'x 80". They are all 48"x40" pallets.
  3. Steve
    Steve
    Pefferlaw, ON
    For a foundation I used Pylex helical piles. The middle supports are shallow deck blocks cause our septic bed lines run underneath the shed and I didn't want to risk cutting into a line.
  4. buZZsaw BRAD
    Great repurpose. :thumbs: Just me mind full as the pallets age even if well protected. They do break easily if you step in the wrong place.
    Be sure to post pics as the build progresses.
  5. rainking63
    rainking63
    Old Lyme, CT
    Sounds like your batting a thousand. Mazeltov and can't wait to see the final build.
  6. Steve
    Steve
    Pefferlaw, ON
    Thanks rainking63 She's one in a thousand too.
  7. Steve
    Steve
    Pefferlaw, ON
    Here are the beams and blocking mounted on the posts and blocks:
  8. Steve
    Steve
    Pefferlaw, ON
    Lugging the floor deck into place. Bit of a struggle, I'm 5' 4" and a walloping 154 lbs.
  9. Steve
    Steve
    Pefferlaw, ON
    At the tipping point:
    Timberdog, RCBS, metalcuttr and 11 others like this.
  10. Steve
    Steve
    Pefferlaw, ON
    Made it. In place and locked down:
  11. Steve
    Steve
    Pefferlaw, ON
    Adding top & bottom plates to the pre built walls:
    Timberdog, RCBS, metalcuttr and 6 others like this.
  12. Steve
    Steve
    Pefferlaw, ON
    West wall ready to lift into place:
    Timberdog, RCBS, metalcuttr and 8 others like this.
  13. Steve
    Steve
    Pefferlaw, ON
  14. Steve
    Steve
    Pefferlaw, ON
    Two remaining walls in place and secured:
    Timberdog, RCBS, metalcuttr and 17 others like this.
  15. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    Looking really good. I love watching shed builds. I have another one in the works, but can’t post pictures. And it’s been “ in the works” for several months now. Always a drawn out process for me.
  16. buZZsaw BRAD
    Seems we never build them big enough. Guess we have a wood hoarding problem! :emb: :rofl: :lol: :woodsign:
    Will it be an extension of your existing one?
  17. The Wood Wolverine
  18. Eric Wanderweg
    Looks great :salute: You're really inspiring me to build something similar at my own house moving forward. I like the "modular build" construction style a lot. It's efficient and inexpensive.
  19. Canadian border VT
    Great build, if your around any new build areas scarf some advantech they cut off flooring and apply it to floor works well. Your 154 pounds might not break pallets but my 225 does
    metalcuttr, Steve, WeldrDave and 4 others like this.
  20. Sandhillbilly
    Sandhillbilly
    Not an extension but another one of similar design.
