Vehicle Rust Protection
Discussion in 'Everything Else (off topic)' started by lukem, Oct 1, 2026.
  1. lukem
    I've never bothered to do it before. We don't get a whole lot of winter around here anymore but they are GENEROUS with road salt and brine whenever there is even a chance of flakes.
    My old truck had both rocker panels and right rear fender disappear on me because of rust, but all the frame and suspension have nothing more than some light surface rust that you would expect on a 17 year old vehicle.
    As we get closer to winter I'm starting to wonder if I should get some rust protection done on the new truck while it's still clean.
    Any things to avoid? DIY or just pay someone to do it. I don't have a lift and it doesn't sound like it would be anything but slightly miserable to do myself. Just starting to research but looking for any opinions.
    Stephiedoll, Chaz, Screwloose and 5 others like this.
  2. ThomH123
    ThomH123
    East Granby
    I have used both Fluidfilm and Woolwax. Both are good products. There are some good YouTube videos on the process.
    MNWood, Chaz, Screwloose and 4 others like this.
  3. RCBS
    Ain't your new one mostly aluminium? ...the body?
  4. lukem
    Yes, the body is but there's still plenty of steel involved everywhere else.
  5. The Wood Wolverine
    I use rattle cans of FluidFilm on an annual basis. Been working very well for me. Been treating my 03 Tundra and the Lex suv we recently got. I did have the Jeep Wrangler WoolWaxed before we sold it. The guy sprayed it thick. I’d have hated to have to work under there.
    MNWood, Chaz, Screwloose and 5 others like this.
  6. JRHAWK9
    JRHAWK9
    Wisconsin
    If you have it done when the vehicle is new, they have a warranty.
    Krown Rust Control | Protect your vehicle from its worst enemy, rust.
    We just had our 6th yearly application done a couple weeks ago. Have been doing it since the vehicles were new ('21 models). There is ZERO rust underneath. Even the suspension bolts are rust free.
    Nice thing about Krown vs doing it yourself, Krown treats inside all the doors, fenders, rockers, trunk, etc. It's more than just spraying the underside.
    Another good one is Corrosion Free
  7. brenndatomu
    YES!!
    Since I've started with oil spray on my vehicles (none bought new) the only place that has any rust, had it before...and the progress of it has been slowed WAY down! If you get it now, before salt bath, you will prolong the life of the vehicle greatly. And it makes working on the vehicle much easier down the road too...don't have to torch off and replace everything underneath when it's time to work on something.
    I do ours every year, or maybe every other once they have a few years worth of film built up...especially on my truck, which is not a daily driver.
    Our local guy is only $60 and it takes him 10 minutes, so there is no way I'm going to fart around for hours, and get all slimed up doing it diy!
    Fluid Film and Woolwax are the two that I see available commonly around here...seems to run $100-150 (and up) from what I've seen...I see a number of places advertising on FBMP locally. I see most shops offer it in "clear"(amber really) and black.
    Aluminum corrodes once exposed, so while it might last a bit longer than steel, it's not the end all be all solution!
    In some ways it's worse...steel can be cut out n replaced...once aluminum gets comprised, it's very difficult to do much with it, unless caught early.
    Body men hate it for crash repairs too...NOT a very forgiving material! Steel is much easier to work with in that regard.
  8. Ohio dave
    Ohio dave
    Akron, OH
    I get my 2018 truck oil sprayed every fall. Have zero rust on it. Not sure if it's because it's less than 10 years old or its because if the spray but not taking any chances for $80 a year.
  9. lukem
    There aren't many places around here to get it done, but online prices are $400+. Maybe that just the first treatment and follow ups are closer to the prices you guys are posting?
  10. Locust Post
    I bought my own undercoat gun and use corrosion x hd on the frame and such and aviation formula elsewhere
  11. brenndatomu
  12. lukem
    After too much research I decided to go with wool wax. There's a mobile applicator service coming on Wednesday to get her all buttered up for winter.
  13. brenndatomu
    Is that one of those deals where they run your vehicle up on a wedge car hauler trailer to get under it?
    Mind saying what it costs?
  14. lukem
    Not sure how they do it. The video just showed them using ramps.
    It isn't cheap, but there are no places nearby that do it so if I factor in my time and my fuel it is more reasonable.
  15. Screwloose
    We found a wool wax applicator about an hour away. Going to make a appointment soon.
    Gotta be good, in 60+ years I've NEVER once saw rusty sheep.
  16. brenndatomu
    That's baaaaad... :D
  17. yooperdave
    Did ewe get that applicator from a baa baa shop? How much was it? Hope you didn't get fleeced!
  18. lukem
    He came out with ramps but didn't end up using them since my truck sits high enough. Felt bad for the guy doing it on his back on a white rock driveway.
    Nice even coat of sheep grease on everything. Clear in the places you can't see and black on the places you can. Seems like he did a good enough job and said I shouldn't need another application for 3 years.
    I had to run to town after he was done and the little bit of overspray that cooked off the exhaust smoked quite a bit when I parked. Truck smells a little sheepy but not bad.
  19. Screwloose
    It's good stuff for sure. Try washing it out of your hair!! Talk about conditioner ...
    Chvymn99, brenndatomu and eatonpcat like this.
  20. JRHAWK9
    JRHAWK9
    Wisconsin
    Do these small independent places just spray the underneath or do they also spray inside fenders, quarters, rockers, trunk, hood, etc?
    There are pros/cons of wool wax. It is thick, so it resists washout better, however seeing it is so thick it will not creep into edge folds as well as the thinner stuff. Although, if they are just spraying the underneath surface and not spraying into door/rocker/fender cavities that's a moot point.
    FWIW, we pay $140 for each application of Krown. It takes them about 40-50 minutes to do their thing. The underside is just a part of their process.
