General chainsaw questions, answers and helpful info for all.
Discussion in 'Chainsaws and Power Equipment' started by NYH1, Aug 25, 2026.
  1. NYH1
    NYH1
    Central New York
    I'll go first.
    1st- back in 2018 we did the transfer slot mod. to our 365X-TORQ. Before we did it, I bought a DTI-20K Tachometer so we could adjust the carb. All the info I found said the max RPM was 13,300. I always set it at 13,000±. I checked it this afternoon and it was at 13,000± so I left it.
    2nd- on my 346XP 50cc version, I found the max RPM was 14,100. I always set it at 13,800±. Today it was only at 12,500±. I turned the high side screw all the way clockwise until I ran out of adjustment and now, I can only get 13,300. It runs and cuts great. Not sure what to do next.
    The low battery indicator on the tach came on so, I'm gonna get a new battery tomorrow and check them both again. Does what I'm doing sound right?
    Thanks, NYH1.
  2. buZZsaw BRAD
    Go cut some wood? :whistle:
  3. buZZsaw BRAD
    T.Jeff Veal, Screwloose and NYH1 like this.
  4. The Wood Wolverine
    It might very well be time to replace the diaphragm in the carb and give it a thorough cleaning. Has that ever been done? Fuel lines and filter + air filter condition can contribute as well.
  5. NYH1
    NYH1
    Central New York
    Other than air filters and spark plugs it hasn't needed anything yet. Next time I go to the dealer, I'll mention the diaphragm and see what he says.
    Thanks again, NYH1.
  6. NYH1
    NYH1
    Central New York
    I changed the battery in the tach. Ran it with and without the air filter, it ran the same both ways, 12,500±. I removed the red limiter tab on the H side and turned the screw a tiny bit clockwise, and it went to 13,800±. I went and made a few cuts in a small 4-inch log and then a really big log. It seemed fine. I checked it when I was done and it was still at 13,800±.
    Unless anyone thinks I should do or try something else, I gonna leave it and check it every once in a while, as the weather gets colder, which I always do anyways.
    I appreciate all the replies, NYH1!
  7. buZZsaw BRAD
    I just realized I my reply was within your text. Heres what I said
    All kidding aside if the saw runs and cuts okay, I'd leave well enough alone.
    I've tried adjusting carbs from scratch per mfrs. specifications and end up practically launching the saw into the woods after 15 minutes.
    Along came mtronic Stihls to my saw hoard and the end of the carb problems...or so I thought. They can be finicky in the hot weather. Wont hot start at times.
  8. RCBS
    The first iteration of Swedish lectric carbs I bought had some issues. Had to spend additional $150 on an updated carb/'puter to get it right. I just bought my second Atuner ten years later last December which is so far GTG. I have one saw that constantly fights me on adjustment. Was gonna sell it but when it's on tune it runs so dammed good. Seems every time I get it out it needs some screw turning where my others are all fine year round unless I have them out in sub zero weather.
  9. NYH1
    NYH1
    Central New York
    I just like to keep them running as well as they can. I don't get too carried away doing it though. I don't adjust the carb every time I run them like some guys do.
    That's why I use a tach. I'm not good at doing it by sound.
    I like Autotune and M-Tronic saws. We had a few minor issues with my son's CS2258 (2015 model). The dealer took care of it and it's been great ever since. We haven't had any issue with our MS400C.
  10. buZZsaw BRAD
    My 400 gave me problems back in Spring when it was hot. I learned to keep it running or put in the shade as full sun seemed to make it hotter?
    My 361 took over for most of the Summer cutting.
  11. NYH1
    NYH1
    Central New York
    Our 400 had hot starting issues at first. The more we used it, the better it seemed to get. No issues lately. Hopefully the same happens for yours.
    NYH1.
  12. tamarack
    tamarack
    paulina oregon
    Those 361's are certainly 1 of the toughest saws around !!
  13. RCBS
    Here's a good one...
    Older coworker...he's a burner and has been for a long while. Comes to me yesterday asking about his clutch cover on his Rancher 460. Said he had a problem with his original not being able to get it back on the saw. He took it up the street to a sister company of the one I work for to have them look at it. Their end solution was to remove the spring in the brake assembly (I have an old saw that is this way because it ate the two replacements I put into it). 460 owner ordered a new complete aftermarket clutch cover in the mean time while using the saw without a brake. New cover is delivered, won't go onto the saw. I already know what the issue is, probably in both cases. Brake band is 'on' while cover is off. On these Huskys the solution is to remove the brake flag/handle and use it to rotate the spring assembly to 'off'. I feel like I have cheated before with my 550 and was basically able to hold the brake coupler together enough to get it to rotate. I was not able to cheat with his 460. No biggie....3 minute job. Tomorrow I will show him how to deal with this problem if he encounters again. He likely did not need a new cover.
    TLDR; If your clutch cover won't go back on the saw correctly, your brake is likely engaged and will need to be disengaged somehow to go back onto the saw.
  14. Highbeam
    Highbeam
    I think some saws don't do the four stroking thing as much as others when you are trying to tune the high jet. They just run smoothly faster and faster the leaner you go at max throttle. Smooth the whole time. So using a tach is the only thing you can do.
    I would think that with a worn diaphragm or clogged jets that there would be a lack of fuel and an overly lean condition. Not an over rich condition.
  15. NYH1
    NYH1
    Central New York
    I've never been able to tune a saw by sound, so I have to use a tach.
    Yeah, good point. It's running great now. I'll keep a eye on it. I'm gonna get a carb rebuild kit and all the fuel lines over the winter.
  16. NYH1
    NYH1
    Central New York
    A guy my son worked with gave him a Husky 345. Looks to be in nice shape. I'm gonna mess with it in a while. Can't go wrong with free stuff!
    NYH1.
  17. NYH1
    NYH1
    Central New York
    I think it needs a oil pump. It's not getting oil and the teeth on the pump are worn down pretty good.
    NYH1.
  18. NYH1
    NYH1
    Central New York
  19. The Wood Wolverine
    Free is usually good, lol. That is a little brother to my favorite of all the plastic homeowner saws (350). There are 3 major known issues that need addressed to keep it reliable. First is the muffler bolts. They are prone to loosen and leak hot exhaust gasses directly on the case, melting it. Best fix is a muffler bracket off a 346 w/ one of the “ears” cut off. I’ll find a pic.. Second is the plastic intake clamp. If that saw has one, look into getting a metal replacement. Third is the cylinder riser bolts (on the 350). Since the 345 doesn’t have that riser, I’m not certain that those bolts are still an issue but.. if you want to tinker, fast forward this video to the 24 minute mark to see where they are located. On the 350, I could remove one at a time w/o removing the entire gas tank, then I used red loctite on the threads and retighten. Cheap insurance to prevent one or more potentially coming loose allowing an air leak. The 345 cylinder has the riser cast in.
    This pic(not mine) shows the 346 bracket to prevent the muffin from coming loose.
    Chaz, brenndatomu, RCBS and 4 others like this.
  20. Canadian border VT
