Road rebuild
Discussion in 'Everything Else (off topic)' started by MikeInMa, Apr 11, 2026.
  1. Jeffrey Svoboda
    Jeffrey Svoboda
    Looks like they have some A+ operators coming in. Never seen anything like those before. Wonder how much they payed for em.
  2. billb3
    It's good to see them protecting the trees but it also means some heavy duty excavating will be going on.
    Mass DOT should have the plans on their website if it is a state road.
    EODMSgt, metalcuttr, bogieb and 4 others like this.
  3. Woodtroll
    Woodtroll
    Mtns of SW VA
    Looks like they may be standard studs secured with metal strapping, like on bundles of lumber, built on site? Doesn't mean they didn't pay someone a pretty penny to build them, though. ;) At least they're making an effort to take care of the trees. I've never seen that before, either.
  4. Jeffrey Svoboda
    Jeffrey Svoboda
    :thumbs: for the effort. I'd be keeping an eye em and seeing how many got tore up.
    Yeah I didn't look too close at the actual "build quality". I first thought they were built off-site with rope running thru the 2x4s. 5ft, 10ft, 15ft, ect cut to size on site. Couple hundred bucks each.
  5. MikeInMa
    There's project info on the mass.gov site, DOT.
    Not a lot of specific details, nor dates.
    I do have contact information of some people that paid us a visit in '25. I think I'll reach out to them.
  6. MikeInMa
    They showed up with separate 2x4's. Nothing put together ahead of time.
    They'd lean the 2x4's against the trunk. Using a rope with a loop at one end They'd pull it tight to hold them in place whine adjustments were made. A rachet strap came next, removing the rope. Metal bands were wrapped and cinched. Ratchet strap removed and on to the next one.
    They wrapped a big white pine that looks like 20 2x4's were used. I haven't counted yet.
  7. Woodtroll
    Woodtroll
    Mtns of SW VA
    There might be an opportunity for a different kind of wood scrounging when those things come down. They won't be straight anymore, but still...
  8. MikeInMa
    There might even be a loose one here and there.
  9. RCBS
    Did they widen the easement from original? Around here everything is 15' from center *except State routes and they can be 20-60' I think, depending.
  10. brenndatomu
    Hopefully they won't be digging all the roots off the road side of those trees...might kill some of them in the long run...
  11. MikeInMa
    Those are red maples, aside from the one EWP.
    An aborist was here months ago . I kept pointing out rot in the trees and suggested they be taken down. He differed. Oh well.
  12. MikeInMa
    Not that I know of.
    I did come to understand that the double yellow line, isn't necessarily the center of the roadway.
    This is a Ma state highway.
  13. MikeInMa
    Looks like things are about to get serious around here
  14. T.Jeff Veal
  15. MikeInMa
    A bit more activity.....
    New paint on road
    And concrete storm drains showed up.
    I met the foreman on the project the other day. He said he'd try to give us a 2-3 day heads up before major activities that'll affect us.
  16. T.Jeff Veal
    EODMSgt, metalcuttr, Chvymn99 and 2 others like this.
  17. MikeInMa
    They started in earnest this morning
    Digging out a catch basin
    Removed anything stretch of white crushed rock. Next door property
    Looking back. Out garage is there on right through the branches. Used for seasonal storage.
    And scratching up in front of the house
    Chvymn99, Stephiedoll, RCBS and 7 others like this.
  18. MikeInMa
    From the bottom of the stairs, one way then the other
    Chvymn99, Stephiedoll, RCBS and 8 others like this.
  19. T.Jeff Veal
  20. BHags
    BHags
    Massachusetts
    Glad I we don't have any appointments at Milford Hospital for a while
