More expansion work at our plant.
Discussion in 'Everything Else (off topic)' started by T.Jeff Veal, Apr 17, 2024.
  1. T.Jeff Veal
    They have the big base pad poured for the 2 silos now Screenshot_20260628_080338_Gallery.jpg
    SimonHS, RCBS, Screwloose and 7 others like this.
  2. T.Jeff Veal
    The calciner hearths are coming along fine. Only 3 more to lay and then the top 20260727_202450.jpg
    SimonHS, RCBS, Screwloose and 5 others like this.
  3. T.Jeff Veal
    Last hearth is done, finish up the wall, and then the top. 20260816_205852.jpg
  4. T.Jeff Veal
    Had a chance to check out the progress on the new calciner.
    They have gotten the top bricks laid, now a poured mix goes over that ,even with toop of steel shell...hole in the middle is top of center shaft. 20260829_090608.jpg 20260829_090626.jpg
    Getting gas and combustion air lines ran and hooked up to the burners 20260829_091129.jpg
    SimonHS, RCBS, brenndatomu and 6 others like this.
  5. brenndatomu
    I can't even imagine what that cost to build these days...o_O
  6. T.Jeff Veal
    Me either. All that stainless...
    Keep buying that good paint...Sherwin Williams, Benjamin Moore, Glidden, Ace Royal, PPG...
  7. T.Jeff Veal
    Got a chance to check on progress of kiln build.
    Big damper to control pressure and combustion gases. Also see the casting inside big pipe. 20260903_021941.jpg
    A good view of the center shaft with arms and rakes attached. Note the openings, top hearth clay falls through center, bottom hearth clay falls through the outside holes. That's the way clay moves through the kiln. 20260903_021629.jpg
    Screwloose, SimonHS, RCBS and 6 others like this.
  8. T.Jeff Veal
    The tanks came in for the pad in post #142 above. They got them installed Monday and Tuesday.
    Backing the trailer in with tank. Rear steering sure makes it easier 20260928_134208.jpg
    I noticed the front of the crane moving a bit...Wonder if he had any pucker factor going on...I zoomed in on the front outrigger pad... 20260928_140950.jpg
    Trailer gone, now time to start standing it up... 20260928_141208.jpg 20260928_141353.jpg 20260928_141535.jpg
    After taking the bottom braces and lifting plates off, time to lift it up and over to the pad... 20260928_143107.jpg
    Sure didn't look that tall on the trailer, but it's up there... 20260930_005417.jpg
    Another good :usa::usa::usa::usa:built product. Hauled over 1100 miles from WI to GA... 20260930_005523.jpg
  9. Erik B
    Erik B
    Western Wisconsin
    T.Jeff Veal Where in WI is that tank made?:handshake:
  10. T.Jeff Veal
    Looks like Rothschild, WI
  11. Erik B
    Erik B
    Western Wisconsin
    I have driven past that town a number of times when I was still working. I usually had to go to Wausau when I passed Rothschild.
  12. T.Jeff Veal
    Well, guess they just changed the tag. Different tank, same company.
    Woodwidow, eatonpcat, Erik B and 2 others like this.
