What backpack blower should I get
Discussion in 'Chainsaws and Power Equipment' started by cezar, Aug 8, 2023.
  1. cezar
    cezar
    KY
    Preparing for sale.
    Look how abused that poor blower was lol.
    I only run Rec. 90 and Husqvarna mix (I prefer the color)
  2. cezar
    cezar
    KY
    Also this is just the random lines and grommets I pulled out of a box. Who knows, I probably already had the necessary part lol.
  3. cezar
    cezar
    KY
    Welp. I pruned a half mile of driveway and started up the blower and got 100 feet and it bogged out and died. Same issue as before. I ran it 10 mins the other day as a test and it seemed okay but under actual use it's clearly still having the exact same issue. FML.
    Zero (0) bites on my CL ad for the thing so I am well and truly screwed at this point.
    MikeInMa and metalcuttr like this.
  4. cezar
    cezar
    KY
    Okay I have calmed down a little bit. Time to get solutions-oriented. Facts:
    - I can't sell it. There is no market for Stihl here, and given my experience I think I get why
    - Even if I could sell it, it's broken and that would be unethical
    - Stihl does not give a f*** about me and will not be participating in the repair
    So time to roll up my sleeves and eat the time and costs to fix it myself. I note that amazon has knockoff carbs, I don't remember seeing them before but there is a highly-rated replacement carb for $23. It can't possibly be worse than what is in my PoS.
    Question: before I go slap a new carb in this, does anyone know of other fuel-delivery items I should be looking for first? Just to recap, this unit has only seen Rec.90 fuel and high quality mix, and has very few hours on it, so I do not believe there are any ethanol or mixture related problems afoot. Also this issue only occurs when warm.
  5. MikeInMa
    I'm looking to buy a backpack leaf blower. Ma has a sales tax-free weekend in August. Just in time for the autumn leaf drop.
    I'm leaning towards the Stihl BR600 $549.99.
    It'll be from a local dealer that's been around for a long time that services lots of different power tools/brands.
    Sorry to hear about your experience, cezar
    Other than big box stores, there's not many Echo dealers around here. Thought I'd take a look at them anyways. I keep hearing Echo chainsaws are a good value.
  6. T.Jeff Veal
    We have a Stihl backpack blower, I like it, I think it's the BR400.
    ECHO makes o e of the strongest blowers on the market, a bit heavy though.
  7. cezar
    cezar
    KY
    I like my Echo Chainsaw and Echo Trimmer. BTW I had a warranty issue with the trimmer it it took 24 hours start to finish to get the thing fixed.
    Big difference with Echo is you don't NEED a dealer because you can order parts, unlike Stihl.
  8. cezar
    cezar
    KY
    UPDATE UPDATE UPDATE
    Stihl took mercy on me and swapped out the blower with a new unit. But before that they warned me that the tech concluded I was using bad fuel. I told the rep in no uncertain terms that was a load of crap.
    Anyway, got the new blower, tank was totally clear so they didn't test this unit. Oh well. But I added the _same batch_ of fuel as was in the other blower and ran it. Fired right up and ran it up to operating temp for a while and the new blower works totally fine.
    So I guess this story d
  9. eatonpcat
    Great news...But, since you are done with Stihl, what time can I come over and take that new POS off your hands??? LOL
  10. Jeffrey Svoboda
    Jeffrey Svoboda
    Just cause the tech said it had bad gas means next to nothing. They're always looking for the easy way out.
    My dad took his 14 f250 to a local Ford dealer for a driveability issue. They suggested it was bad gas so my dad paid them to drain it and refill. Turns out the truck needed a cylinder head cause of a bad valve.
    Needless to say, I don't think it's anything you did.
  11. Mrxlh
    Mrxlh
    Dat Boot
    The squeaky wheel gets the grease, glad they finally made it right with you!!! Sadly for them the damage is done and another customer gone.
  12. MikeInMa
    Massachusetts has a sales tax free weekend underway.
    A big upgrade from a plug-in leaf blower I've had.
    cezar, eatonpcat, Ron T and 1 other person like this.
  13. cezar
    cezar
    KY
    Ran the BR800 through two full tanks back to back today. Most I've run the first one or its replacement.
    Gotta say. I would like to have about 50% more power. I don't think the Echo would cut it either.
    Really wish there was some sort of engine swap I could do on this.
  14. brenndatomu
    Have huskihl port it...
  15. cezar
    cezar
    KY
    What sort of % increase am I looking at with porting? I always through it would be like 15-20% which I don't feel is worth it.
    40+ percent though and I'm interested....
  16. Jeffrey Svoboda
    Jeffrey Svoboda
    For some reason I thought upgrading the fan system would be where it's at? What's porting going to do? Increase the rpm to get more cfm?
    eatonpcat, brenndatomu and MikeInMa like this.
  17. brenndatomu
    Higher RPM...unless that fan is maxed out already
    eatonpcat and Jeffrey Svoboda like this.
  18. cezar
    cezar
    KY
    I'm sure the fans are designed using CFD on the computer and are at the absolute apex of their physical capability.
  19. Mrxlh
    Mrxlh
    Dat Boot
    30-40% faster in the cut is where most saws come in at after porting. If you don't see an increase in RPM from porting, it will not move any more air…
  20. huskihl
    huskihl
    It’s a 4 mix four stroke, so out of my wheelhouse. But a stock echo or redmax up in the 9000 range will annihilate the BR 800. Seems like that was mentioned earlier in this thread, but I didn’t go back and look.
    RCBS, JD Guy, eatonpcat and 5 others like this.
