pelpro pp60 anybody have one?
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by Pallet Pete, Oct 5, 2014.
  1. DexterDay
    If you are gonna run "up" the inside of your wall, then 2" is good for most pipe.. But you will want to follow the pipe manufacturers guidelines on clearance to combustibles. Simpson Pellet vent pro is only 1" clearance to combustibles. And I thought you needed 12" with pellet vent pro, but I would have to look.
    So whatever brand venting you go with? Follow their guidelines.
    I am a fan of Selkirk DT (Direct Temp) venting. That's what's on my stove upstairs. It has the exhaust and OAK air all in one pipe. It's also a 6" pipe (looks like wood stove pipe. It has a 4" vent in the middle and the outer 2" is for the outside air to travel in (it preheats the incoming air) :)
    Pallet Pete likes this.
  2. Pallet Pete
    Pallet Pete Moderator
    Ovid
    Its in good shape except for some minor surface rust that I need to fix. It was left in the garage this year and did rust a little. Overall its an easy cleanup! I fired it and let it go for a little while and it worked great no issues at all! I can't wait to hook it up…. DexterDay Is the light rust something usual in the burn pot or is that just due to setting in the garage? I checked all the info and it was built 12/22/13 and sold 2/17/2014.
    KIMG0168.jpg KIMG0170.jpg KIMG0171.jpg KIMG0173.jpg KIMG0174.jpg KIMG0176.jpg KIMG0179.jpg
  3. jtakeman
    For $400 clams, I think you did rather well.
    Once the heat gets to the metals, Any moisture contact will result in rusty spots. Being in the garage certainly didn't help matters!
  4. Pallet Pete
    Ovid
    Thanks bro! It all literally wipes off the stove too I just hit it lightly with a wire brush and BAM no more rust.:D
    343amc and jtakeman like this.
  5. DexterDay
    The rust on the inside is not a big deal. The rust on the outside can be cured with some Stove Bright Satin black paint.
    The big thing with a pellet stove is the fuel to air ratio. You want to make sure the burn pot is seated properly and all gaskets are good and seal tight. If there is a big gap in the burn pot and burn pot receptacle, you lose some air that would normally be used for combustion. So make sure the pot is in correctly and there is no big gaps.
    imacman and Pallet Pete like this.
  6. 343amc
    343amc
    Northeast Lower Michigan
    Too bad it says "Hi" on the temperature selector instead of 11. I always wanted a pellet stove that goes to 11. :)
    At four bills, I think you did pretty good.
  7. Pallet Pete
    Ovid
    Thanks brother... Hey check your PM's too.:thumbs:
  8. Gary_602z
    Gary_602z
    Lake Odessa, Michigan
    Hey Pete you gonna try to make use of some pallets to make pellets?:rofl: :lol:
    Gary
    DexterDay and Pallet Pete like this.
  9. Lousyweather
    Lousyweather
    it really looks pretty good.....its metal, can be cleaned up, very easily in this case.......I think ya did well......
  10. schoondog
    schoondog
    Dutchess County N.Y.
    I think you are going to save alot more than the $400 on oil. Feed it some good pellets and enjoy.
    Doggy
  11. Pallet Pete
    Ovid
    Getting the stove cleaned up!
  12. savemoney
    Good luck Pete with your pellet stove. You have proven yourself as a competent DIY man, so I'm sure you will be able to work with that unit. You will be surprise how much that stove depends on being clean in order to put out heat. Please don't stock up on pellets until you burn a few different brands. Some stoves can be very pellet picky. With that unit, something like firesides with a low ash content would be a good place to start. Around here, our local HD carries them. Dexter is spot on with his knowledge about how stoves work. Jay is the most knowledgeable reference for pellet performances.
    We love our stove. I learned a lot from others on here. In my case, I had to learn as much about what not to do as I did to lean what to do. Hope your install goes smoothly.
    DexterDay likes this.
  13. DexterDay
    Buying in hulk is only a good idea when a pellet is proven, as Larry stated. Sticking with known brands that preform well will help, but it's always best to know what your stove "likes". I have learned over the years to buy something that can eat anything. The Enerzone and it's design can push any pellet through it (it was designed to run very, Very high ash content pellets) and my furnace in the basement is self cleaning and doesn't care if you feed it dog food :)
    But it's always best to run at least 2-3 bags (a couple days of burning). That way you know the amount of ash (and time) your gonna need cleaning it. Some pellets burn very clean and can leave the pot clean for days (depends on the unit and it's airflow), while others will plug up the pot within 8-10 hours and need daily attention.
    My Enerzone can go a ton easily (I was very close last season to a Ton, but Christmas came and I HAD to clean the stove/per the wife's instructions) without touching it. Just add fuel and let it eat pellets. :dex: I really love that stove! I owe Fyrebug BIG TIME! !
  14. Pallet Pete
    Ovid
  15. eatonpcat
    Looks great...
  16. Pallet Pete
    Ovid
    Thanks! I bought a bunch of 2" air grinder stripping wheels from HF and cleaned everything I could then hit it with 1200 paint from Menards. While we where there we noticed they sell this stove! $995 for our model and it's rated up to 1650sq ft on the sale tag... Our downstairs is 1000 sq ft. Wonder if it will do better than we thought? I can't wait to see... The manual says 1750sq ft soooo.
  17. Pallet Pete
    Ovid
    By the way that means I have $427 into it and it looks like new! We found a wall thimble at Menards for $45 and a 90 degree bend for $15. That should be all we need to finish! That means for less than $500 we will have a like new stove albeit a little small I think....:thumbs::drunk:
  18. Pallet Pete
    Ovid
    DexterDay I am going to follow your advice and weld half circle tubes to set on the heat plate above the fire right where the holes are for the heat to come out. Ok ok kinda following your advice lol... Hopefully more mass equals more heat.
    jtakeman and eatonpcat like this.
  19. jtakeman
    Really don't need to weld them. We found just placing aluminum extrusions on the surface has acted like a heat sink. Which has helped the convection fan pull more heat out of the stove.
    I'd experiment with different shapes and sizes before you make it permanent. ;)
  20. Pallet Pete
    Ovid
    They will set on the plate but not be attached. I'll I have is about 7' of c channel to use... I may go to the scrap yard and look though for circle tubes. The tubes will be tacked on top with a small piece of metal just to hold position and not move out of place. Basically I can pull 4 screws lift the top and pick them out as one piece...
    Do you have a pick of the aluminum you used and how?
