What DA buffer to buy? Who's got buffing experience?
Discussion in 'The DIY Room' started by Horkn, Jun 5, 2026.
  1. Horkn
    Ok. I bought compound to buff my gelcoat on my fiberglass boat. There's a 8-10" wide black stripe on the top hull that fades and needs buffing on a 25' boat. Pretty much the rest of the boat is white and looks great. Which DA buffer should I buy? I hear good things about the harbor freight buffers especially for not pro/ daily use.
    They have a couple different models.
    5.7 Amp, 6 in., 8 mm Short-Throw Random Orbit DA Polisher/Sander https://share.google/ouOy4jcn5kUveBTfZ
    And then. 7.5 Amp, 6 in., 20 mm Long-Throw Random Orbit DA Polisher
    https://share.google/nrN4HE4RjFDiH09oL
    Will the 5.7 amp one be up to the task? Or should I spring the extra $$ for the 7.5 amp one? It's a 6" buffing head in the kit I bought.
    TIA
  2. Jeffrey Svoboda
    Jeffrey Svoboda
    For some reason harbor freight website doesn't fully load for me but it looks like they have a link to an answer for you question?
    brenndatomu, Horkn and T.Jeff Veal like this.
  3. JRHAWK9
    JRHAWK9
    Wisconsin
    I have a Rupes Bigfoot Mille LK900E and really like it. It's forced rotation. Makes quicker work out of things vs random orbital.
    It's not cheap though.
    RUPES Bigfoot LK900E Mille Gear Driven Dual Action Polisher
    I've got an old Porter Cable DA random orbital polisher from the mid 2000's sitting in my closet that resembles the products you are looking at from that garbage tool place. It works fine, but it's nowhere near the tool the Rupes is. The Rupes is MUCH smoother and just a much better piece. My Porter Cable can vibrate seeing it's random orbital and cause my hand to go numb after awhile.
  4. Horkn
    Hmm. Here's the 5.7 amp ",short throw" one that's on sale thru tomorrow
    https://www.harborfreight.com/57-amp-6-in-8-mm-short-throw-random-orbit-da-polishersander-64528.html
    And the slightly more expensive one.
    7.5 Amp, 6 in., 20 mm Long-Throw Random Orbit DA Polisher https://share.google/DAjB1f4OLK97bPSYM
    What's the difference between the ⁶ and 20 mm stroke as far as polishing
    I don't need any crazy expensive buffer. This should be a once a year, maybe longer interval after I ceramic topcoat it.
  5. Jeffrey Svoboda
    Jeffrey Svoboda
    Logically thinking I would guess that the longer stroke should work better/faster in open areas but might be tough to run tight up against an edge of sorts. A slow speed rotational buffer would be best but can do some damage if you're not paying attention while still learning to use it. I'm pretty sure I've seen guys use an angled 1/2" drill before.
  6. JRHAWK9
    JRHAWK9
    Wisconsin
    In theory the longer strokes can correct paint faster. But they don't always rotate in that manner seeing it's not forced rotation. It will "randomly" do it when it feels like and if you have a larger pad or apply pressure it may not rotate much at all. The longer the stroke the higher the chance it won't rotate the full stroke.
  7. The Wood Wolverine
    I really like my Griots. I have the G9.
    The shop I work at now has a guy that runs a detail business there. He has several brands, I’ve tried em and let me tell you.. (just my .02, not trying to be disrespectful to anyone), the horror freight ones aren’t closely compared to a “good” brand premium one. Night and day difference. If you’re only going to use it once, every 3-4 years then I can see getting the cheapest one possible. He never used the Griots and liked it enough to order the 3&4” one for small radius and motorcycles. Haven’t tried it yet but I sure will soon.
    The G9 is one that if you push too hard, it will not continue to cut. The 21 I believe keeps going no matter how hard you push. Being it was my first foray into random orbitals, I went conservative and I’m still completely satisfied.
    Couple random pics of our vehicles that I’ve done. Their products work well too.
    Blue CRV
    Buy once cry once. I’m at a point in my life where I can’t tolerate crappy cheap tools.
  8. Horkn
    While I like buying quality tools, this is such a small bit of gelcoat that needs to be freshened up. It's just the top black stripe on both sides. The bottom stripes are fine. 68170d41-f1ed-4ff5-a126-a66e3e9ee82b-54662dbf-cd2f-4932-a401-e2e416f6e817~2.jpg
    I'll buy the one that's on sale and I'll see how it works out.
    I bought the skwol gelcoat restoration and the ceramic topcoat as well as pads to do the job. This is really good stuff.
  9. JRHAWK9
    JRHAWK9
    Wisconsin
    Blue Firehawk....
    German Menzerna polishes
    My factory paint doesn't have much for orange peel, you can see some in the OEM paint on your CRV. Nothing you can do about that other than block sand it and then polish it back out. That's a lot of work though and you risk the chance of sanding through the clearcoat. LOL
  10. Horkn
    Ok, did a bit more research. The 80 buck one from HF is more of a rupes clone. I'm getting that one. I don't plan on using it much.
    I'll do the grease mod and the backing plate mod if I deem it too vibey.
  11. JRHAWK9
    JRHAWK9
    Wisconsin
    That was my impression when I saw the photo of that one. The Rupes LHR15 they compare it to is also a random orbital and not forced rotation.
    I figured the cheap stuff would double as a hand numbness tool.
  12. Horkn
    Apparently with a couple of updates it's totally useable for hours on end. The good news is that I might have the job completed in 20 minutes a side.
  13. The Wood Wolverine
    CRV got rear ended/totaled over a year ago and I agree, last thing I'd want on any vehicle is to go through clear. Eager to work on my motorcyces with this:
    I had zero previous experience when I bought mine so I went with their products. The guy at the shop enlightened me on some he thought were very good. 2 names I remember are Sonax and 3M. I'll try his before I buy something different. Your pic is
  14. brenndatomu
    Agreed...my old boss was a master detailer, he made buffing look so easy (and maybe gelcoat is harder to screw up?) but I quickly found out a buffer in the hands of a newb can burn 2 stage paint (clear coat) in a heartbeat!
  15. Horkn
    I did the black stripes on the top of my boat on Friday am before going out on the boat with friends on Friday. I used the 80 dollar harbor freight buffer with the nice ultraviolet buffer pad, and the skwol 1 step oxidation remover and the skwol ceramic topcoat sealant. It turned out really well.
  16. Horkn
    I touched up the boat again today with the skwol 1 step oxidation remover and the ceramic sealer.
    Got a couple of pics, but I need to resize them.
    The bauer 20 mm throw DA buffer works pretty well, not even modded.
