St Croix hastings
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by Smokinpiney, Sep 4, 2014.
  1. jtakeman
    The jumper you have placed isn't correct. The wide bar is the common. See pic for where you need to jump for testing.
  2. jtakeman
  3. smoke show
    smoke show
    Pittsfield, Wi
    JT to the rescue!
  4. Smokinpiney
    Smokinpiney
    "South" Jersey
    JT you are the man! Now in the photo you indicated the correct jumper on, the board is actually upside down. For me to try and run it in manual mode would i still jump it as POS 1? That would be like the switch is all the way to the right in the "manual" postition right? Thanks for tracking down that switch for me. Gonna see what i can do about ordering one.
    DexterDay likes this.
  5. jtakeman
    I just marked it the way it was pictured. You need to see what the face plate says for manual and orient the board as it was installed. Then you might need to swap pos 1 and 3. 2 is the middle setting on the switch either way.
  6. Smokinpiney
    Smokinpiney
    "South" Jersey
    oh ok yea i guess it doesn't make a difference if it's upside down or not. Either way i need to jump it like you said. I'll give it a shot in the morning. Thanks again
  7. jtakeman
    ;) No problem!
    I feel useful tonight no matter what the wifey says!! :p
    Smokinpiney and DexterDay like this.
  8. Smokinpiney
    Smokinpiney
    "South" Jersey
    Got two switches on order. In case i screw one up trying to solder it in. :emb:
    imacman, SmokeyTheBear and jtakeman like this.
  9. Rona
    Rona
    southwestern Minn
    DexterDay and Smokinpiney like this.
  10. Smokinpiney
    Smokinpiney
    "South" Jersey
    Jt you were definitely right about the wide bar being the common. Both ways I had it jumped before were still telling the stove it was in t-stat mode. I jumped pos 1 like you said and it finally burned past the 1hr shut down I've been experiencing. That's definitely "manual" mode. Thanks again
  11. krooser
    krooser
    Waupaca, WI
    FYI…. those St Croix's like to have the combustion air intake open the width of a pencil… if you need more air your stove is still plugged.
  12. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Hey you, what ya burning these days?
  13. krooser
    krooser
    Waupaca, WI
    Only bought three bags so far… waiting for my ship to come in. imacman promised me a free load of horse bedding pellets but every bag he sends me looks like they've already been thru the horse!
    SmokeyTheBear likes this.
  14. Smokinpiney
    Smokinpiney
    "South" Jersey
    Yea after trying different settings that's where I found mine burns best. The flame gets pretty wild if it's open any more than that. And gets lazy if I close it just a bit more.
  15. imacman
    imacman
    Denver, NC
    And for free, you expected something different? :rofl: :lol:
  16. jtakeman
    Don't laugh, We have a place in CT. that is making wood stove blocks out of horse poopie. And they are making lots a $$$!!
  17. Rona
    Rona
    southwestern Minn
    If you look at a horses diet its easy to see that it can be done. As a better example consider the Indians and later the pioneers of this country. They purposely had to find and burn buffalo dung as wood was simply not available on the prairies. They also used twisted prairie grass which certain grasses such as switch grass has been made into pellets and burned in modern pellet stoves. A lot of ash but it can be done.
  18. Smokinpiney
    Smokinpiney
    "South" Jersey
    Got the switches in today and rather than try to solder the new switch in, I carefully took just the slide/contactor piece off and snapped it onto the board. It's currently running (in manual I hope) and i'll see what it does after an hour or so. Keeping my fingers crossed! :tears:
    jtakeman and DexterDay like this.
  19. Smokinpiney
    Smokinpiney
    "South" Jersey
    Im still having the 1 hr shut down issue after installing the switch. I read in the manual from eventemp in (which is for models with an older control board) that the stove is set from the factory in "smart stat" mode. To run it in "manual" it refers to removing the factory installed jumper. Could this be a jumper on my board keeping the stove in "smart stat' mode.The black plastic piece is removable Im not having any luck communicating with st croix's tech department.
  20. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Is the switch installed correctly, that is are the switch contacts working exactly like they did when you used the jumper on the busted switch?
