60” Gravely Zero Turn - Thinking Used?
Discussion in 'Chainsaws and Power Equipment' started by wiguy, Apr 30, 2026.
  1. JD Guy
    JD Guy
    Upstate SC
    You done good :thumbs:
  2. Horkn
    Great deal. I think the hours were inflated by the owner leaving the key on. The high hours and dead battery scream that the key was left on a number of times. ZTHD has the zt-3100 fully serviceable drives like I got on my Kubota I picked up a couple of weeks ago. That's a Kawasaki v twin. Check under the cowling as those like to get clippings and such stuck and then they overheat many times causing valve guide walk out and then low to no compression. That's definitely not a 2017 or newer, as it's the old body/ chassis style Gravely. For $500, even if it actually has 2700 hrs on it, it's hard to go wrong. How are the drives do they both drive straight when at full speed? Any leaks? How is the color of the hydro fluid? Any idea when they were last serviced?
  3. Skier76
    Skier76
    CT and SoVT
    I don’t want to assume…I have a feeling those spindles will be ok. Worse case, they may need a bit of grease.
    I had an older (1980’s) Bunton walk behind that I bought around 2005 that had the original spindles. They eventually crapped out, but had A LOT of hours on them.
  4. wiguy
    wiguy
    Wisconsin
    She thought they had more paperwork, some maintenance history & such. I still have some things to go through, didn’t find anything yet. Yes, the 2700 hours seems high, maybe the key was on, never thought of that as contributing, maybe.
    Here’s the model & serial number. It does drive fine & straight, I’ll get to the hydro fluid soon. Even if I don’t do the spindles, I at least want to check them better. This mower like many have the sealed spindles, no grease zerks. That’s an issue with varying opinions.
  5. Horkn
    Yeah that's a 2013 gravely ztHD 60" that's definitely a Kawasaki, and probably a 24 HP FR730V.
    jmb6420, Screwloose, Ronaldo and 3 others like this.
  6. wiguy
    wiguy
    Wisconsin
    Thanks, so 2013 model. I still have some evaluation to do. Somewhat related is a relative that mentioned offering up a new zero turn Cub Cadet that he may not want to keep. He said it was likely more mower than he needs. He did get it for a good price, and would still cost me over $2500.
    I really don’t need that mower, it appears.
    jmb6420, Screwloose, Horkn and 2 others like this.
  7. jmb6420
    jmb6420
    Grand lake, Oklahoma
    I'd take that 2013 Gravely over a brand new Cub Cadet.
    My name is Mike, and I'm a hoarder in Ok.
    Lopi Endeavor and Republic 1250
    eatonpcat, Screwloose, wiguy and 5 others like this.
  8. Horkn
    I would too
  9. wiguy
    wiguy
    Wisconsin
    Been working on the mower some, the hour meter settled back on 710, maybe that’s a more accurate hour count. That would make more sense.
    The blades were so-so, not to old but buggered up. There was plenty of good blade left, sharpened all 3. One spindle was bad, worn, out of round, making noise. I found the replacement locally, put on. I need the pulley above, ordered from fleabay. I checked the hydro fluid some, newer filters in place, 15w-50 syn motor oil. I’ll wait on the change a bit.
    The big thing today was a new Milwaukee 1/2” impact driver from H.D. I’m kinda older school with tools, usually a breaker bar with a cheater pipe can get the job done. These blade bolts were giving me serious fits. I only got one off with my conventional methods, breaker with a 4 foot pipe, serious leverage. I gotta say, the impact was more than night & day difference. I used my older Cub Cadet today to mow, once started, worked fine.
    jmb6420, Horkn, eatonpcat and 4 others like this.
  10. Ronaldo
    Ronaldo
    A 1/2 drive impact is one of the tools that I thought to be a luxury. Now that I have one, I will not be without. If it died tomorrow, I would replace asap.
    Horkn, jmb6420, wiguy and 2 others like this.
  11. Will C
    Will C
    New York
    Having my 1/2” impact wrench for mower blades alone justified the cost!
    JD Guy, Screwloose, eatonpcat and 5 others like this.
