What backpack blower should I get
Discussion in 'Chainsaws and Power Equipment' started by cezar, Aug 8, 2023.
  1. FarmerJ
    FarmerJ
    Minnesota
    If you got a 3230, you should be able to be the big bad wolf on the little pigs house of brick
  2. cezar
    cezar
    KY
    I should think so. Absolute unit of a tractor. Way more than I need. Actually I made a deal to buy a restored 3000. I mean R E S T O R E D. Stickers still on all four tires, just beautiful, but the seller had some minor mechanical issues and I needed a tractor yesterday so I made a deal on the diesel 3230 instead. The one that got away. Anyway, the 3230 is great. I'm on 10 acres and it is massive overkill for my needs. Very fun to operate as well.
    Back to the blower. I've run a tank through it. Thoughts:
    - This is the weirdest 2t I've ever run. It really revs like a 4t. Internet rumors seem to imply it's some sort of odd hybrid. I would believe it.
    - The exhaust smells fantastic. has that tuned dirtbike aroma. My chainsaw doesn't smell like this.
    - This thing is the absolute bare minimum. I'm still surprised at how... adequate it is. Really this is top of the line?
    - But, it does everything I need it to, perfectly. And it hums away in a very confidence-inspiring manner.
    So far no regrets.
    metalcuttr and Stephiedoll like this.
  3. cezar
    cezar
    KY
    BTW just curious does anybody know the price of that PTO blower?
    metalcuttr likes this.
  4. Skier76
    Skier76
    CT and SoVT
    Our town in VT has something like that. It’s quite a blower! They use it in the fall to clear out the sides of the dirt roads of leaves and debris. There may be a video on my channel below of it passing by the house.
    metalcuttr, eatonpcat and FarmerJ like this.
  5. g60gti
    g60gti
    NY West
    Nice blower. I’m on the hunt myself. I’ve been finding out since moving to some land that the advice of buying as big as possible is solid advice. Looking at husky 580.
    metalcuttr and eatonpcat like this.
  6. MasterMech
    They make 3pt versions of the Buffalo! And yes, they are very expensive. But unbeatable for power/HP and relatively quiet.
  7. MasterMech
    I used to run one on a golf course. I think it was the KB4. It was self-powered (Koher 27HP) and it was the bees knees. Just hook it to a golf cart, fire it up, and go clear the course. Could do all the fairways, bunkers, and greens in 2-3 hours depending on how heavy the leaf cover was. 1 man, 1 cart, 1 blower. Someone should write a song like that. :whistle::rofl: :lol: It rendered our Little Wonder wheel-blowers useless, and the big centrifugal blower we mounted on a 30hp tractor only came out for the peak of leaf season. It was only marginally stronger than the Buffalo and it took everything the tractor had to get it to PTO speed. Truth be told, I think it only moved more leaves because the tractor was slower and the discharge could be set right down on the ground. A good operator on the Buffalo could work circles around it. Never really had problems with that Kohler either. Those engines loved to run under a heavy load like that for hours on end.
    metalcuttr, JD Guy and Skier76 like this.
  8. cezar
    cezar
    KY
    Just starting to get the fall leaf accumulation, did about an hour of blowing today.
    Anyone have thoughts on tuning? Are these things gtg from the factory or is there a little headroom? What about break-in? I've run two tanks through it so far.
  9. MasterMech
    Unlike a saw, tune a blower for max RPM once it's been warmed up. Favor the rich side but not so much that you lose RPMSs. You won't hurt it running it wide-open. Blowers always put a steady, heavy load on the engine. Engines like that.
  10. cezar
    cezar
    KY
    Should I get a tach or just tune by ear?
  11. Dunmyer mowing llc
    Dunmyer mowing llc
    I'm a landscaper for a living, and I think the Stihl br600 is the best all around blower. It's not the strongest, but to me it's the most comfortable and 600s seek to have few problems than 800s
    Chud, FarmerJ and metalcuttr like this.
  12. cezar
    cezar
    KY
    Had an interesting experience with the 800x today. I was clearing leaves and stopped to add gas, and when I fired it back up it had significantly more power than it ever has. I'd estimate it had another 30% and was actually pushing me back a bit which it has never done. Same gas can (motomix).
    Very strange. I found the power barely adequate before and now it feels great. Time will tell if this is the new normal or what.
    eatonpcat, Chud and metalcuttr like this.
  13. MasterMech
    They were/are a winner for commercial users. This is the machine that pretty much made 5hp wheel blowers obsolete.
    They were a big step up in ergonomics from the previous BR400/420/420 Magnums. Much better straps and cushions. Relatively quiet for the power, and not nearly as thirsty as a two-stroke with equivalent power.
    The power available from a backpack these days is crazy, the BR800 is heavier than a 600 but I know several crews around here that break out 800's for heavy clean-ups, while running the 600's for day-to-day work.
    Early BR600's had issues - mostly operator induced, but there were a few I can place squarely on Stihl's shoulders. The fuel pickup on early models was inadequate and would gasp for air if the operator leaned over with less than about 30% of fuel remaining in the tank. VERY early models had fatigue issues with the exhaust valve stems and the stem and/or keeper would let go, dropping the valve with catastrophic results. I wish I had saved one of those pistons, I had one with the valve inverted and driven into the piston crown. Stuck up out of the piston like a daisy. :thumbs: They also were susceptible to operators over speeding the engines (this would aggravate the valve stem issue or even cause the engine to slip valve guides) by obstructing airflow through the blower. Either by blocking the tube outlet against the ground and/or deep in a debris pile, or obstructing the intake screen. I had one customer that was PO'd after the third blower in his fleet failed. Discovered that his helper was taking off his hoodie in the afternoons and tied it to the blower handle, letting it hang down the right side where it blocked 40% of the inlet screen.
    I can't believe it but the BR600 is nearly two decades old at this point. That must mean I'm .... (horror movie music) middle-aged.... (screams). :rofl: :lol:
    JD Guy, Dunmyer mowing llc and Chud like this.
  14. sirbuildalot
    sirbuildalot
    Mass
    I bought my Husqvarna 580BTS back in late 2016, so like 7 years now. Hard to believe it's been that long. I really like it. It's essentially a Redmax 8500. Very strong, about 77cc. Plenty of power for my 1+ acre lawn that is surrounded by mature Oaks, and Hickories that drop tons of big nuts.
    This is my daughter using it on my neighbors yard.
    eatonpcat likes this.
  15. cezar
    cezar
    KY
    ARGHHHHHHHHHHHHHHHHHHHH
    My br800 died on me today.....right after I walked a quarter mile of driveway dropping branches with my pruner.
    Ran fine for 20 minutes or so like normal and then suddenly started bogging hard, getting worse and worse. Took it back to the garage and had a tinker. YT said valves are an issue on these. Had to modify a feeler gauge to check the valve adjustment and it was WAY out. Like 30-40 thou when the spec is 10. I only have twenty hours on this thing so it had to have been set way wrong from the factory. Not a good start. Pulled the spark plug and it was black black black. Cleaned it up and put everything back together since there are no carb adjustments on this thing.
    Same problem. What else should I check? I do not suspect fuel or fuel contamination; I'm running fresh Rec.90 with husqy 2-stroke mix. My saws are running the fuel fine.
    Filter is due for a change but does not appear clogged.
    And how do I get the limiter caps off the carb? They are just little pins not like what I'm seeing on YT.
    RCBS and eatonpcat like this.
  16. RCBS
    If you can get past the limiter caps, here is the 'standard setting' for the needles.
    cezar likes this.
  17. cezar
    cezar
    KY
    That's exactly what the limiter caps look like. little hex head pin thinggies.
    RCBS likes this.
  18. cezar
    cezar
    KY
    Couple more data points, went and did a test run:
    - Starts, runs, idles completely normal
    - Runs normal for about 1-2 minutes at full throttle and then noticeably starts to fall off
    - While this bogging is occurring under full throttle I tried hitting the primer; killed the engine
    - Also tried opening the gas cap while this is happening to rule out vent issues. no change
    - If you keep the throttle pegged it will waver back and forth between normal-ish and almost dying, and if you go long enough at full throttle it will die completely.
    ** - If you add some choke while bogging the revs pick right back up **
    So. Fuel delivery problem? But HOW. this thing is brand new and I use extremely high quality gas.
  19. Jeffrey Svoboda
    Jeffrey Svoboda
    It's not getting enough fuel one way or another. Less air and the rpms pick up proves this. That's assuming your choke just blocks some of the intake air.
    Kinda weird that it runs good until the engine is warm. Makes me think that it isn't plugged jets. Problem would always happen then. Maybe a fuel pump issue.
    I know my pickup hose/filter in the tank got outta position once and it wouldn't run. Can't remember the specifics though. Probably not your problem but easy enough to verify the filter hose is routed correctly in the tank.
    Eggshooterist likes this.
  20. Mrxlh
    Mrxlh
    Dat Boot
    I purchased the Echo PB 580T last year and it has met all of my expectations.
    RCBS and Eggshooterist like this.
