Adding log lift to Huskee splitter?
Discussion in 'Chainsaws and Power Equipment' started by Michigander, Apr 12, 2026.
  1. Michigander
    Michigander
    Macomb Michigan
    I have a 22 ton Huskee splitter. Bought new in 2014. I thought about adding a log lift to it. Saw one made by rugged made. But it’s not in stock. Would this be a good idea or am I opening a can of worms trying to do this? I process around 3-4 cords of wood for personal use. So a new expensive splitter with a lift is out of the question. Thanks in advance.
  2. Michigander
    Michigander
    Macomb Michigan
    This is what I was looking at
  3. jmb6420
    jmb6420
    Grand lake, Oklahoma
    I've got a northern tool 37T splitter and have been considering that exact option for a couple of years. I just never pulled the trigger. If you do it, keep us informed. I'm getting older and lifting those rounds gets harder every year. Splitting vertical hurts my back.
    My name is Mike, and I'm a hoarder in Ok.
    Lopi Endeavor and Republic 1250
  4. T.Jeff Veal
  5. jmb6420
    jmb6420
    Also, you would need to purchase a valve for the splitter that has power beyond. That is assuming that your current valve doesn't have power beyond. Or you could engineer a diverter valve and plumb the power and return lines back into the system.
  6. Michigander
    Michigander
    Macomb Michigan
    Thanks for the replies. I read some good reviews on the rugged made one. But I’m hoping someone on here has done it. I don’t know much at all about hydraulics. But I’ve done my share of turning wrenches, fabricating and welding too.
  7. jmb6420
    jmb6420
    I'm hoping too. Following for more info.
  8. brenndatomu
    If you can fabricate/weld, then I'd just make one...no extra hydraulics needed...lots of examples of log lifts out there using mechanical advantage (linkage/long bar) or a cable/pulleys powered by the splitter cylinder...that's the route I took...works great.
    Hey buddy, will you give me a lift?
    Stinny, metalcuttr, Chvymn99 and 4 others like this.
  9. Michigander
    Michigander
    Macomb Michigan
    That is another good option. Thanks for the link.
  10. Butcher
    Butcher
    With my 22 ton husky when I split rounds that are to big to pickup I just pull the lunch pin and tip the beam up to vertical and bust them up. But that's just me.
  11. Michigander
    Michigander
    Macomb Michigan
    Yea I’m just not a fan of it. It’s very uncomfortable for me.
  12. isaaccarlson
    isaaccarlson
    Colfax, WI
    Do yo have a table on the splitter? I would put a work table at the top of the list. I’m not talking about a little bar or small grate, I’m talking about a real 3 ft table. I built one for my splitter and it made a world of difference. No more bending over to pick up splits or chunks. If I can’t lift a round, it gets noodled or two of us lift it or the bobcat gets used.
  13. Michigander
    Michigander
    Macomb Michigan
    That’s a good idea. I only have a small grate. It helps, but bigger would be better.
  14. isaaccarlson
    isaaccarlson
    Colfax, WI
    I am able to stage rounds on mine. It speeds things up when unloading the truck or trailer. One person can stack rounds on the table and I can roll them into place.
  15. MNWood
    MNWood
    Coon Rapids Minnesota
    Can you share a photo? I'd like to see what you built.
    John D, eatonpcat, sms4life and 4 others like this.
