G288 build
Discussion in 'Chainsaws and Power Equipment' started by MAF143, Mar 12, 2024.
  1. MAF143
    MAF143
    North Central OH
    Thanks for the feedback all...
    Even if I did put the ring in correctly (which I still believe) I'm certainly guilty of buying a cheap lightweight piston that I took even more meat off of looking for more performance. I'm still a rookie at this and learning from the generous folks on the blogs about saws. I sometimes have to learn things the hard way too...
    Like I said above though, I'll still probably hit many parts with the spinny thing...
    :dremel:
  2. MAF143
    MAF143
    North Central OH
    I did work on a saw a couple years ago that had been running just fine. The owner wanted a muffler mod and I took the jug off to do a quick exhaust port clean up and widen. The ring fell out in two pieces when I pulled the cylinder. The crack was luckily not near a port. I would have thought it would have been not running, but I even made a couple test cuts with it myself before taking it apart.
    That was a lucky one!
  3. Eggshooterist
    Eggshooterist
    Erff
    Its how you learn and, you didn't ruin a quality oem saw in the process. Don't beat yourself up.
  4. MAF143
    MAF143
    North Central OH
    I'm OK... I'm just trying to be honest and open as I can be about both the good and the bad while adding a little of my brand of humor to it. I figure if I'm learning something I might as well share the info. The good side of this was that this saw has run great and gave me 2 years of fun firewood cutting. The downside is that maybe the cheapest, lightest piston might be OK in the short term. But if you don't like to open up saws and work on them, stick to higher quality stuff.
    I had less than 300 bucks in this saw and had fun building it, learned a lot building it, and had fun using it.
    If the bottom end flushes out OK, I think I can get by with a meteor / caber combo for under $45. Yes, I'm still a tightwad...
  5. The Wood Wolverine
    :handshake:
    With that level of carnage, I'd say you did great if a new piston and ring gets it running again. I cheaped out on 2 pistons since starting to work on saws. First was my dad's old Husky 50. It still has the Golf piston in it. Truthfully, I don't run it much so I couldn't judge honestly. The other was a Little Red Barn slug for a closed port 55 (if I remember right), I had no other choice. Aside from those 2, I've been through probably a dozen Meteors. They're all I'll use aftermarket wise. Wolf Creek has a sale code (firewood season), I just got one for the 281 @ $39.98 shipped.
  6. MAF143
    MAF143
    North Central OH
    I had some time this evening to clean the saw up and get ready for the new piston. Wishful thinking on my part. When I took a good look in the cylinder and cleaned the oily mess out of it, I noticed what I had hoped was some transfer, BUT... it's not. The cylinder is a paperweight. several nail catching scratches look to be through the plating. The casting looks cracked in both transfer tunnels.
    Flywheel side
  7. MAF143
    MAF143
    North Central OH
    I already have bearings, seals, gaskets and new O-ring for the bar oil pump so I'll take it down and replace all that stuff and get that bottom end clean while I'm waiting on a cylinder. Not sure what I'll go with yet, but I missed out on a flash sale of an OEM cylinder and piston kit the other day when I ordered just the piston... I should've jumped on that.
    While I've got the case halves apart, I'll pop the bar studs out and flatten the mating surface to the bar cuz it seems to not seal the oil passage to the bar very well.
  8. Eggshooterist
    Eggshooterist
    Erff
    What saw is this a clone of? 288 Husqvarna is my assumption.
  9. Eric Wanderweg
    Looks like there’s a couple OEM on eBay.
    This Mahle one with the damaged fins:
    OEM Husqvarna Cylinder, Decomp Port, 54ZN13, REFURBISHED, Models 288 281 181 | eBay
    This Kolbenschmidt one in Canada with no decomp:
    288xp Used OEM Cylinder And Meteor Piston | eBay
    Maybe my man card should be revoked but I wouldn’t want to try pulling my 288 over without a decomp. I had it out yesterday for the first time in months and forgot how it was to get it going, especially with the base gasket delete.
    Now you’ve got me nervous about the cylinder on my 61/272. I bought the cylinder thinking it was a meteor but it’s a knockoff of even that. Since I built that saw, I did get an OEM 272 cylinder but have yet to put it on. I should just swap that out before something catastrophic happens.
  10. Eggshooterist
    Eggshooterist
    Erff
    metalcuttr, MAF143, John D and 3 others like this.
  11. Eggshooterist
    Eggshooterist
    Erff
    I would definitely swap sooner than later.
  12. Jeffrey Svoboda
    Jeffrey Svoboda
    Not sure if it helps but I was scrolling eBay tonight and came across this. Made me think of this thread.
    On second look, I see the fins look to be smashed off.
    metalcuttr, MAF143, John D and 2 others like this.
  13. MAF143
    MAF143
    North Central OH
    I've checked all those out. I've got a couple leads I'm chasing over on OPE also. I've got a couple other saws for buddies I need to get done also, so I'm not in a huge rush needing this one right away. We have had several blow downs here in the last couple storms, but here at our place I can handle everything with the 357 and 362CM easily enough. I can always use the neighbor's 660 I built for him any time I need a big saw.
  14. MAF143
    MAF143
    North Central OH
    I've had lots going on with other stuff for a while. I've finally dedicated some evening time to getting this saw back together with an OEM jug with a Meteor piston. The jug already had the base and squish cut. I tweaked the squish cut a little and worked the exhaust, intake and lower xfers last evening. I need to throw it back on the case and check where those ended up but I'm targeting 160* duration in, 160* duration ex, 19* blowdown, and .020" squish. I want to try a little bit shorter blowdown this time since the "frowning" piston at the exhaust port should be dropping cylinder pressure a little faster right as it cracks open.
    I still need to hit the upper transfers and finish getting the intake floor a touch flatter and more even. Once I have it all where I want it, I'll chamfer everything. Now that I've seen first hand what a hung ring at WOT does, I'm not wanting to repeat that anytime soon.
    I did split the case and put in all new SKF bearings and new seals to clean and junk out of there. The one bearing was a little more "catchy" once I got it out even after cleaning it good. Glad I split the case.
  15. MAF143
    MAF143
    North Central OH
    Got the cylinder finished and back on, vac and pressure tested. I checked the numbers after getting the jug on and they came in right where I want them.
    Intake 161* duration
    exhaust 160* duration
    blowdown at 19*
    Squish at .023"
    I'm hoping to have some time this weekend to get a tank or two of fuel through it in break-in mode. I'd like to have it back in shape for the 32" bar for an upcoming tree job, not to mention all the firewood I'm behind on...
  16. The Wood Wolverine
    I wouldn’t wanna be slinging big saws around in this heat. Hopefully you have some shade to work in.
    :dennis:
    metalcuttr, eatonpcat, MAF143 and 2 others like this.
  17. MAF143
    MAF143
    North Central OH
    Plenty of shade out in the woods here.
  18. eatonpcat
    No worries, Monte will be wearing his blue jacket...It is ventilated!
  19. MAF143
    MAF143
    North Central OH
    Finally, I can do some heat cycles, but no cutting till a new chain catcher gets here. I forgot that I used this one on a saw I fixed for a nephew's buddy. I never let a saw go out the door here without a chain catcher on it. I figure if they've thrown a chain enough to destroy a catcher, then chances are they can throw it again and I don't want to ever hear of someone getting hurt because I didn't put a simple safety device in place on a saw I fixed.
    https://youtube.com/shorts/gTtLqOrkv7A
  20. Eric Wanderweg
    Sounds just like my OEM 288 :yes: Always a good feeling to pull one back from the gates of death.
