Enviro Max pot liner in my Omega
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by figor, Jan 4, 2023.
  1. figor
    figor
    Usa
    The port shroud for the igniter on the Omega pot liner fell off and ended up in the ash pit somewhere. It wouldn’t light off anymore I had to manually light it. It was also dumping a lot of pellets out that hole.
    I began pricing a new liner and the cheapest I could find was $179. For some reason the Maxx liners are cheaper. Doesn’t make sense because they have nearly twice as many slots so more work goes into making them. I found one for $89 at Stove Parts 4 Less.
    It came in last night so I put it in this morning. Seems to be working fine even with my home made agitator rod. It lit off within two minutes so same as the original. Flame looks about the same. Maybe even a little more even across the pot.
    I’m just running on low for now. It’s not all that cold out and I thought I’d break it in gently. I’ll see what a high fire looks like later. So far I’m happy I saved some coin.
    I don’t really burn corn, wheat, or nut shells so I wouldn’t think there would really be any issues.
    imacman, wildwest and jtakeman like this.
  2. jtakeman
    I'm about do to order a spare for mine. I've repaired my pot 3 times now. 1once for the shroud breaking off and 2twice for crack's. I've also drilled several .125 holes where ever carbon was building up trying to reduce it. So more holes to me might be betterer!!
    I was thinking the M55 because it uses slots instead of holes. Pretty sure the burn pot grate and burn pot are the same part numbers. Augitator is also the same.
    I was going to go with the after market ag when mine go south. Did you get the after market burn pot liner??
    imacman and wildwest like this.
  3. figor
    figor
    Usa
    I believe it is aftermarket. Perfect fit though. No idea where they are made. They were selling them through Amazon so I suspected China but couldn’t say for certain.
    My Omega liner had slots. Just not near as many as the M55.
    I’ll be kicking her up on high when I get home and see what full burn flames look like.
  4. nailed_nailer
    nailed_nailer
    Cape Cod
    I bought my Aftermarket M-55 agitator rod and burn pot liner from
    Wood Pellet Stove Parts and Grill Replacement Parts
    IIRC I ordered one item from Amazon and one directly from Stove Parts 4 less but they showed up in the same box. Go Figure?
    I think there was a cheaper price on Amazon for one of the items.
    Been about a year and while I don't think the aftermarket parts will last as long as OEM they seem to be working fine.
    Only issue seems to be the pot liner generates really big clinkers. Must be a type of metal (stainless) thing.
    Good Luck,
    ----Nailer----
    imacman and jtakeman like this.
  5. figor
    figor
    Usa
    I like this M55 liner. It seems to burn the pellets that get pushed out to the side of the pot by the agitator much more then the Omega liner does. I’m glad I got it.
    I’m going to try to fab up an igniter shroud to fit the old one. I’ll have it as a spare.
  6. jtakeman
    I'm going to pick one up next month. I need a spare. I'm also going to get another agitator and auger motors to go with my other spares. I can't wait days like I used too.
    I'll likely use the Maxx M pot liner and keep the Omega liner as a spare. I'm hoping the Maxx M liner gets less carbon build up.
    imacman likes this.
  7. figor
    figor
    Usa
    I’m using the omega liner now. Had to soak the maxx liner from the Somersets.
  8. jtakeman
    Still getting lots of carbon build up?
    I drilled a chit load of holes in the Omega liner. I think I even drilled more after these pic's. Hole diameter is the same as the slots width IIRC.
    imacman likes this.
  9. figor
    figor
    Usa
    No build up yet with the Green Supreme pellets. One week in.
    I drilled my pot too but it didn’t help. I’m beginning to think my carbon build up is from the Somerset pellets I always used.
  10. jtakeman
    I finally replaced mine with the after market kit. My liner cracked again after I repaired it. And the burn pot grate fell apart!! Plus the kit was cheaper than buying them in pieces. Saved a bit of $4 with the kit.
    So far so good.
    I put a new agitator in last fall and its already worn out and bent. So I put the one from the kit in as well!! Not to pleased on the AF agitator quality. I may try an oem next time or make my own again. Good excuse for me to buy the tig welder I've been wanting!! Try one out of incanel this time!!
    May also make my own fire grate out of Stainless. But it last much longer than the pig steel one in these kits. Besides the cracks the burn pot is still in usable shape!
    imacman likes this.
