Whoops...
Discussion in 'Chainsaws and Power Equipment' started by SKEETER McCLUSKEY, Apr 3, 2018.
  1. Warner
  2. MikeInMa
  3. Warner
    The news article has a very important fact wrong. The whistle should be making noise when filling and stop when the tank is full.
  4. MikeInMa
    The whistle is audible throughout the filling process?
    Still, plug the fill pipe if it isn't removed with the tank.
  5. Warner
    Yes the whistle is telling you 1 that you are filling a tank 2 that it’s not full. If you don’t hear it you shouldn’t keep filling especially not 400 gallons! Lol. I agree that it should have been capped.
  6. Canadian border VT
    I have oil tanks, yes Warner is right as usual; the oil displaces the air in the tank and the second pipe has a whistle on it that air moving through it makes sound.
    Oil fill pipe are 1.5 -2” BIP no tank so it’s loose. Literally just pull it out fill with foam.. I did this several times as NG lines because available
  7. Boogeyman
    Boogeyman
    Central Indiana
    Should anyone in the area be looking for a job as an oil delivery driver, I bet a spot just opened up.
  8. Skier76
    Skier76
    CT and SoVT
    That’s wild that the piping was still in place. Or at the very least, should have been capped. Heck, there’s a tag in our fireplace insert that states a pellet stove was installed and things need to be changed if it was to be used as a fireplace again. (I see it when I pull the stove out for a deep clean)
  9. MikeInMa
    Turns out leaving the fill pipe in place after removing the oil tank, is against Mass state code. The lawyers will have fun with this one.
  10. Skier76
    Skier76
    CT and SoVT
    That’s for sure! And I can only imagine how long it will take to sort things out.
  11. Haftacut
    Haftacut
    Rives Junction, MI
    Not to mention the pain and suffering!
  12. Warner
    IMG_5468.jpeg More things that go bump in the night.
  13. Woodtroll
    Woodtroll
    Mtns of SW VA
    What did it used to be? A tractor or implement tool box?
  14. Warner
    Hydraulic pump/box for an asphalt hot box.
  15. Ward Hoarder
    Ward Hoarder
    West Virginia
    30 mm threaded shaft on our pellet mill decided to snap today. This thing has been a joke since we bought it new. I've put over 40 bearings in the dies drive wheels. Factory says that we are the only person with any issues. Factory said to torque the nut on the shaft to two fingers tight from a 150 pound man. I asked him to get that in writing. Nut is only torqued to 14 - 17 ft. Lbs.
  16. Haftacut
    Haftacut
    Rives Junction, MI
    Sounds beyond frustrating!
  17. brenndatomu
    The way that break tapers to a point in the middle, looks to me like the shaft was bent...that would explain eating all those bearings too.
  18. Screwloose
    The reason it broke is quite fundamental. You cannot use imperial torques on metric threads.
  19. brenndatomu
    So how many kilograms does 150lb man equal? :rofl: :lol:
  20. Woodtroll
    Woodtroll
    Mtns of SW VA
    A two-fingered 150-lb. man, at that! ;)
