  1. jtakeman
    These turkeys might be trying to move in with the chickens? They have been here on and off all summer, But first we have seen them perch on the chicken coup!! Also a lil pic of our resident pigeon georgie(on the right) who's a chonkie one!!
    IHATEPROPANE, Earl764, Dpopps and 5 others like this.
  2. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Brunswick stew on the hove even, slurp.
  3. bogieb
    First snow that has stuck this season.
  4. jtakeman
    We have had 2 storms so far, Both were merely coatings and didn't last once the sun come up. Did need to sand the walkway and the town spread some stuff on the roadway. Just enough to make a mess!!
  5. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Those guards be useless here the Brunswick stew would laugh at you JT.
  6. StEarl
    StEarl
    millinocket, maine
    Hello all.
    I feel bad i only come in when i have a question, BUT...
    I think (hope?) i know what the problem is, (cheap t-couple is junk) but i thought i'd run it by everyone to see if anyone has seen this before.
    So, i bought a spare thermocouple to have on hand this year,and i got it off of Amazon.
    Got the yellow light tody and installed the new spare.
    Stove recognized it was there, and filled the pot.
    Only thing is it didn't then give the signal to the control box to continue once it was hot.
    I've ordered a new one from a place i've used before, and i expect it will work, as the stove was working fine before the yellow light today.
    I thought maybe i didn't have far enough over the pot, but after moving it out a bit, still no go.
    Happy thanksgiving to everyone, and i hope you are all well and happy.
  7. jtakeman
    They work just fine here. Of coarse I had to tinker with them as I must mod everything!! :p
  8. StEarl
    StEarl
    millinocket, maine
    Could be reverse polarity, i'm reading.
    I assumed this would not be the case since i didn't get the earthsense one.
    But i'm going to try just swapping the wires.
  9. StEarl
    StEarl
    millinocket, maine
    Yep.
    smh
    Helga's 15th winter, and going strong.
    This season's stash.
    https://www.youtube.com/shorts/SWT3gj6WyvE
  10. bogieb
    Glad you got that figured out. Seems a lot of stuff is reverse polarity nowadays. I say "a lot" only because I never used to hear of this issue and now I hear it on a regular basis in the solar world. If a replacement (and/or off-brand) isn't working electrically, then the first thing to check is polarity.
  11. StEarl
    StEarl
    millinocket, maine
    Thanks.
    It's so disheartening having to turn the forced air oil on.
    IHATEPROPANE, imacman, bogieb and 3 others like this.
  12. jtakeman
    What's oil going for in your area?
    IHATEPROPANE, imacman, bogieb and 2 others like this.
  13. StEarl
    StEarl
    millinocket, maine
    I don't really know at this point.
    We had 100 gallons in the tank, and maybe two years back we got another 100 just to have a nice back up on hand.
    $3.39 /gal seems to be what's stuck in my head.
    If we had baseboad oil, it would be a lot nicer.
    Even the short time i had the oil on yesterday had me missing the steady heat the stove gives.
    Ours really is just emergency use if we need a part for the stove we don't have.
    But i have pretty much everything except a control box on hand.
    Snap discs would also need to be ordered.
    It would be nice if both those items never failed.So far so good.
    Room air blower was making noises a couple of years ago, but has settled down.
    I do have a spare on hand though as well.
  14. imacman
    imacman
    Denver, NC
    Using the zip code from my last house in NY, COD Oil is quoting $3.39 up to 300 Gal.
    IHATEPROPANE, Dpopps, bogieb and 4 others like this.
  15. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    For croaked dinosaurs and Bears that is too damm much for croaked Bacteria even more so.
    IHATEPROPANE, Dpopps, bogieb and 3 others like this.
  16. jtakeman
    Geez even. Luckily my nearest is still at $2.83/gallon as long as I order 150 gallons.
    So that's $849 for 300 gallons compared to the $1026(with delivery) we just paid for 3 tons pellets. (100 gallons = approx 1 ton of pellets). Pellets aren't the bargain they used to be! Meh!!
  17. Earl764
    Earl764
    CT
    I do not miss the monthly $700+ oil bills.
  18. imacman
    imacman
    Denver, NC
    According to the fuel cost calculator, your about a wash between the two at those prices:
  19. jtakeman
    If you don't count the sleppin and cleaning. I wanna say the furnace is a bit higher than 78%, 82, And IIRC pellet stove was 76%. If it makes much difference?
    Like I said 100 gallons equal right around 1 ton of pellets. Most likely cause the pellet eater heats both upstairs and the basement where the furnace heat more upstairs.
    IHATEPROPANE, Dpopps, imacman and 3 others like this.
  20. bogieb
    HHO is averaging $3.70/gal here according to the latest report. More expensive per BTU than pellets
    Pellets are cheap per BTU compared to oil, and what is up with the cordwood prices - the only things more expensive than cordwood are resistance and propane (which is always the case)
