cleaning up the ashes, are you doing this too?
Discussion in 'The Wood Pile' started by Spirch, Nov 17, 2025.
  1. ThomH123
    ThomH123
    East Granby
    I have when they get excessive. I use a fryolater basket. It does let soot into the room so
    I need to be careful.
    RichE23ACR, SimonHS, MikeInMa and 6 others like this.
  2. In the Pines
    In the Pines
    I'll leave any charcoal if it's worth the time, and I leave a little ash to cover up the plate where I dump the ash into the pan.
    Just trying to keep any air from entering from that area and add some "insulation" I guess?
    Brick is showing otherwise, it's just allows maximum time before needing to empty again.
    Does anyone keep their ash bucket full in the winter to treat ice?
    I do and if I don't need it, I just go dump it when it's time to clean out again and fill it back up.
    Edit to add, I also have a dog and I don't use it where she is. I use it mainly at the end to middle of driveway since I am lazy and don't clean the entire driveway. (and it's not necessary imo)
    So the packed down stuff does get dicey at times.
  3. Jeffrey Svoboda
    Jeffrey Svoboda
    I use something like this to store ash in. Usually dump it once in the spring. Then I don't have to worry about catching the woods on fire if I empty a warm stove.
    www.amazon.com/31-Gallon-Galvanized-Steel-Trash-Pre-Galvanized/dp/B07RXGDS9V/ref=asc_df_B07RXGDS9V?tag=bngsmtphsnus-20&linkCode=df0&hvadid=80058309938566&hvnetw=s&hvqmt=e&hvbmt=be&hvdev=m&hvlocint=&hvlocphy=104241&hvtargid=pla-4583657844476684&psc=1
  4. Dakota Hoarder
    Dakota Hoarder
    Sioux Falls, SD
    I like to rake the coals out when I can especially when I have a hot stove and don’t want to completely restart the fire, but need to get some ash out. Unfortunately I don’t have a very good ash rake and can’t find one.
    Spirch where did you get your “ash rake”?
  5. Jeffrey Svoboda
    Jeffrey Svoboda
    Interesting.... You're burning Coles! Where would one obtain these "Coles" and how many BTU should one expect. I would kinda think they would just put the fire out with all the "juices". :D
  6. Eric VW
    Years ago, I devised this hood to clamp on to the stove, and the setup has a hole on the other side to allow the 2” shop vac hose to plug into the back… works pretty gooder at managing fines that want to take flight when depositing ashes into the steel bucket (tight fitting lid just out of frame). I use a “fine dust” yellow bag in the shop vac, but I really only use this setup when the stove is dead cold.
    I’ve had that shovel since the start (circa 2012) but just recently took it to the drill press for a little Swiss cheese treatment, and it works just as good for scooping ash as it does sifting with a couple of jolts to separate ash from larger coals.
  7. FTG-05
    FTG-05
    TN
    I get it all, I don't discriminate:
  8. Canadian border VT
    I dump on a snow bank in a hole made for them
    snowbank are notoriously difficult to burn :cool:
  9. MikeInMa
    My cooled ashes go to my SIL and mixed in with compost for her garden.
    I she's had enough, then like I do with my excess compost, using a long handled shovel, it gets broadcast around the yard.
  10. Spirch
    Spirch
    Canada
    dollar store, nothing fancy :whistle:
  11. John D
    John D
    Syracuse ny
    As others have said when the ashes get to much I just shovel out about half of the and keep burning but then again one my stove is lit we burn constantly till the season ends
  12. lukem
    All the ash and charcoal fall down into the secondary burn chamber on my boiler, and nothing survives in there (maybe a big nail or screw, but that's about it). I can burn a cord of wood and end up with about maybe 2 gallons of fine powdery ash.
  13. cezar
    cezar
    KY
    Ash goes into ash bucket.
    When bucket fills up, I let it sit a week, and then dump into a trash bag and it goes into the trash for pickup.
    I don't sift or filter, when the burn chamber fills up everything goes.
  14. metalcuttr
    metalcuttr
    western WA
    I made a rake. I rake the coals forward and push the ashes back like many others. Usually at morning restart. When I am cleaning the ashes from the stove when they build up, I push them to the back of the cold stove and give them a good spray with the Wif's ironing mister. A couple of spritzes during the process kills the fly ash! I spray the top of the ash in the bucket also before whisking it to the garage. bats3enter.jpg bats4.jpg
  15. Erik B
    Erik B
    Western Wisconsin
    The ashes I take out of the stove go to my neighbor who has a long driveway.
  16. cezar
    cezar
    KY
    Hey nice rake
  17. blacktail
    blacktail
    PNW
    I leave big chunks in the stove, but I'm not spending any time or effort to sort my ashes for what might give me 2 minutes of heat. It all gets sprinkled on the mossy parts of my lawn.
  18. Scotty Overkill
    I actually sift out the coals from the ash and build a valley in the middle of the stove (mountain of ash on either side), pile the good coals in the middle and re-start my next fire by laying the next batch of wood across the valley of coals. Also, if you encounter a warm or mild day after a cold night where you don't want to reload, simply pull those ashes over your hot coals by several inches and they'll hold almost a full 24hrs or more to start your next fire. I think an ash sifter shovel is a must-have at the stove or fireplace, makes re-starts and re-fires a breeze.
    JDU, MikeInMa, buZZsaw BRAD and 7 others like this.
  19. metalcuttr
    metalcuttr
    western WA
    There is satisfaction to be gained from starting a new fire from leftover coals. Something to do with continuity of life, birth from the ashes, the phoenix and all that philosophical stuff!:fire:
  20. Chud
    Chud
    Yesterday I put a big split of cherry on some hot coals and it instantly burst into flame. I sort out hot coals with my bare hands. jk I couldn’t pass up an opportunity to get in a Nashville jab. Yes I sort/save coals with shovel finesse or a gloved hand.
    JDU, MikeInMa, sms4life and 8 others like this.
