Hickory Dickery Dock
Discussion in 'The Wood Pile' started by T.Jeff Veal, May 26, 2024.
  1. buZZsaw BRAD
    Looking good Jeff. Im curious as to how much space you have between rows?
  2. T.Jeff Veal
    None, but it dries...we ran the big 42" fan on it for a while. It won't be used for a couple years, at least...I hope...planning on this being personal stash.
  3. Canadian border VT
    In your heat in the summer; it’s like being in an easy bake oven.. it will dry
  4. T.Jeff Veal
    Wednesday evening we got 5-6 more logs from the pile that we recently brought home...
    I started Thursday morning splitting while Miz Carol was doing errands in town...she made it back and helped with the last rounds...
    Then the stacking fun began...set the last row at the edge of the shed, and filled the gap behind it with ugly splits... 1000016252.jpg
    Should be close to 5 cords there...
    RCBS, Boogeyman, SimonHS and 11 others like this.
  5. Chud
    Chud
    There’s room for 8 more splits on top. Might be worth discussing during your annual performance review with your stacker. :thumbs:
  6. T.Jeff Veal
    I'll have that conversation with me, myself & I...lol...Miz Carol was handing it to me while I was on the ladder...
    I thought air needed to blow across the top and the saw blade was fighting me.
  7. T.Jeff Veal
    Time for a thread bump...
    We had started splitting other wood and had kinda forgotten/covered up 2 more trailer loads of hickory logs from Hurricane Helene. We cut a couple to finish a load and saw the borers were under the bark, time to process it.
    This pile was closest to the splitter...left side is pile 20251105_195100.jpg
    We got a small pile of rounds cut, log pile is on the right 20251105_195108.jpg
    What we had left from orginal pile.
    When I had a day off, we got the smaller logs left from that pile bucked, then started on the other load... 20251111_151215.jpg 20251111_153425.jpg 20251111_161127.jpg
    This made a nice pile of Blue Samson fodder... 20251111_170220.jpg 20251111_170233.jpg
    We split a good bit Wednesday and an hour Thursday afternoon...
    The mound of splits...we will stack it in the 2 cord shed behind it, planning on adding boards above the pallets so we can stack to roof... 20251113_160701.jpg
  8. JDU
    JDU
    Perry County, PA
    Good work, nice looking pile of splits. I also noticed how green your tree foliage still is in the pictures this late in November.
  9. T.Jeff Veal
    Some trees have already lost all their leaves, some are still hanging on. We had our first hard freeze Monday night
  10. buZZsaw BRAD
    Thats a lotta hickory. :jaw:
    Yeah the borers can make a mess of it that's for sure. Funny how some of my hickory doesn't get touched by them and others a lot. Wonder if they prefer one species over another? Pignut and shagbark in my stacks here.
    Will you stack bark on splits separate from heartwood or just mix them? I split off the bark when I make up smoker bundles.
  11. buZZsaw BRAD
    Ive simply crib stacked when I run out of end support in a rack.
    brenndatomu, jo191145, John D and 4 others like this.
  12. T.Jeff Veal
    It will all be stacked together. I want the sheds to look like this when full...and we have about 40 more rounds to split of the older logs.
    And more hickory mixed in on newer loads to sort out
  13. T.Jeff Veal
    I counted the rounds this morning, 37 left. Got those split.
    Pile in now complete. I did raise the conveyor again. Got equipment moved and trash/bark cleaned up.
    Glad this was seen and not found with the saw... 20251115_102549.jpg 20251115_102555.jpg
    The mountain of splits, need to get some measurements...any guesses on how much is there??? 20251115_123148.jpg 20251115_123229.jpg
    Maybe we won't have to stack it all if Chud thinks some might be restaurant quality...just a short drive down here... 20251115_094758.jpg
  14. The Wood Wolverine
  15. Chud
    Chud
    Definitely restaurant quality perfect splits. If you were 4hrs away I would haul it away for sure. My Hickory supply is running low.
  16. T.Jeff Veal
    I took a better picture of the hickory pile this morning without the splitter and conveyor in the way. Outside pallet to pallet is about 16'. 20251116_062427.jpg
    Ron T, WinonaRail, MikeInMa and 12 others like this.
  17. T.Jeff Veal
    We started stacking the hickory in the shed behind the pile this morning. Added some boards above the pallets so we could stack full to the roof. 20251117_113740.jpg
    3 - 18" rows deep, 66" high and 93" long = 1.49 cords
    Should be enough to fill right side...
  18. T.Jeff Veal
    We got the rest of the pile stacked this morning, we were close , my guess was off about 1/4 cord... 20251119_113808.jpg
    We have some newer hickory than will finish up this shed. About 2.75 cords on 2 trailer loads of logs..
  19. RCBS
    I can smell this picture.
  20. Cavtrooper
    Cavtrooper
    I need friends like yours!
