Coming soon...Echo Saw Builds
Discussion in 'Chainsaws and Power Equipment' started by Eggshooterist, Nov 9, 2024.
  1. MAF143
    MAF143
    North Central OH
    Have you tried trimming the edges of the choke and throttle blades along with thinning the shafts / screw streamlining?
    I changed out the screws on my 288 clone carb to brass so I could peen them easier than steel screws (used loc-tite also). Then taped over the hi nozzle, low speed holes in the venturi, and any other open holes in the carb to keep shavings out. Then I went after it with the carbide burrs to get a smoother flow at WOT. I didn't do any b-4 / after timed cuts on just this mod, but I can't imagine it didn't help. There were LOTs of other mods to this saw. Flow, flow, and flow seem to be the major theme to performance.
  2. Eggshooterist
    Eggshooterist
    Erff
    I know that's an upgrade some do. I haven't tried it yet myself.
    T.Jeff Veal, MAF143 and eatonpcat like this.
  3. MAF143
    MAF143
    North Central OH
    It wasn't hard to do, but it was time consuming. I used that saw as a learning experience, along with all the others I've worked on. I'm still a rookie at building saws but it's fun learning new stuff.
  4. Eggshooterist
    Eggshooterist
    Erff
    Im far from an expert lol. Ive done 13 or 14 saws now. All my own but one I did for a buddy.
    T.Jeff Veal, eatonpcat and MAF143 like this.
  5. MAF143
    MAF143
    North Central OH
    Lucky Buddy...
  6. Eggshooterist
    Eggshooterist
    Erff
    It ran better than stock so he was happy. :handshake:
  7. Eggshooterist
    Eggshooterist
    Erff
    CS310 is finished.
  8. eatonpcat
    Fits perfect now, nice job!
    T.Jeff Veal and Eggshooterist like this.
  9. Eggshooterist
    Eggshooterist
    Erff
    Franks mang
    eatonpcat and T.Jeff Veal like this.
  10. Eggshooterist
    Eggshooterist
    Erff
    Now im fresh out of echo saws to work on until I decide to get those minty 315's running correctly.
  11. Eggshooterist
    Eggshooterist
    Erff
    eatonpcat, ammoaddict and T.Jeff Veal like this.
  12. Eggshooterist
    Eggshooterist
    Erff
  13. Eggshooterist
    Eggshooterist
    Erff
  14. Eggshooterist
    Eggshooterist
    Erff
    The saw is an absolute gas hog now lol. Like nothing I've ever seen in a saw. I can probably get 3-4 tanks of gas to one oil tank refill now. I guess my hackery went to far. It will make a great tractor saw for the occasional quick cut.
  15. ammoaddict
    ammoaddict
    Granite Falls, NC
  16. T.Jeff Veal
    Yep, it will eat more gas since porting and bigger carb.
    I was shocked how much the XS029 ate with the 039 jug on it...but it sure cut good.
    eatonpcat and Eggshooterist like this.
  17. Eggshooterist
    Eggshooterist
    Erff
    Thank you brother.
    I think its a great candidate to try RC car Nitro fuel in. Its over carbed so theres plenty of room to adjust for the extra fuel needed.
    I just went and counted jet turns...1/8 out from closed on the H and 5/8 out from closed on the L. Yeah, it will probably flow nitro fuel.
    T.Jeff Veal and eatonpcat like this.
  18. Eggshooterist
    Eggshooterist
    Erff
    This isn't normal ported saw gas hoggery. All my others still run out about the same time as the fuel. Usually the fuel a bit before the oil. Not this little dude. Lol. I crossed a line somewhere and made it a small cc toy vs a usable wood cutting tool. But,I'm 100% good with it. I went into this with the goal of getting the maximum power, I know how to get, without having a custom expansion chamber made or custom machine work to tighten the squish and rebore the bearing pockets.
    ammoaddict, T.Jeff Veal and eatonpcat like this.
  19. Eggshooterist
    Eggshooterist
    Erff
  20. MAF143
    MAF143
    North Central OH
    why that's a cute little fella, 'cept he's so angry... and throwing stuff at your feet...
