More expansion work at our plant.
Discussion in 'Everything Else (off topic)' started by T.Jeff Veal, Apr 17, 2024.
  1. T.Jeff Veal
  2. T.Jeff Veal
  3. T.Jeff Veal
    Came back to work Thursday night after our days off. We've had dry weather, so work is getting done.
    Lot more anchors have been installed 20250919_010900.jpg Started another section of anchors today... 20250920_033305.jpg
    They have the big fan and mill set on the middle slab... 20250920_033017.jpg
    A lot of memories were made here where this slab is...
    It was our old foreman shack, lol...Ot was there when I started in '89, I don't know how old it was. Over the years, I have received work orders and given work orders in that building. 20250920_040348.jpg
    Not sure what will be going in that spot.
  4. T.Jeff Veal
    Area where the calciner will be built, got all the anchors cut down to below slab grade.
    More steel structure has been added, they will soon add steel decking on the levels where concrete will be poured... 20250925_132013.jpg
  5. Screwloose
    What is the roots blower for?
  6. T.Jeff Veal
    We use those with a fuller pumps to move our kaolin clays to different silos.
    All our products are in powder form, we don't run any slurries
  7. brenndatomu
    We get lime deliveries at work...the trucks all have PTO powered roots blowers to pressurize the trailer, which blows the powder into the storage tower.
    Once in the tower it's gravity fed from there on.
  8. T.Jeff Veal
    Yep, we get deliveries like that too. Also, ise same set up to unload railcars
    Screwloose, eatonpcat and brenndatomu like this.
  9. T.Jeff Veal
    After returning from our Ohio trip, came back to work and saw they had gotten the caps on the anchors and poured the concrete floors. 20251017_193449.jpg
    They have dug out and started installing more of the smaller anchors to the right of the calciner pad... 20251017_193544.jpg
  10. T.Jeff Veal
    Looks like all the anchors have been installed now. Small pad for rebar has been poured on the calciner spot. 20251025_083944.jpg
  11. T.Jeff Veal
    Looks like concrete will be poured for the main calciner pad soon, got forms, rebar and conduit in. 20251030_191505.jpg
  12. T.Jeff Veal
    Steel crew has been here a couple days, putting more pieces of the puzzle together... 20251104_085727.jpg
    Boogeyman, MikeInMa, Chvymn99 and 7 others like this.
  13. T.Jeff Veal
  14. T.Jeff Veal
    Off 4 days, come back and they have gotten 2 more tanks set and added more structure above them... 20251116_020455.jpg
  15. T.Jeff Veal
    They built the roof for the MCC room, I guess you could set a tractor on top to work on it...looks like 8 orn10" I-beam and channel iron... 20251119_045223.jpg 20251119_045313.jpg
    Got the rebar and bolts set to hold the calciner building part of the pad done... 20251119_050118.jpg
  16. T.Jeff Veal
    I believe the main structure is done. They are installing the sections of the dust collectors today. 20251208_090217.jpg
  17. T.Jeff Veal
    Got both dust collectors installed on top of main structure, handrails and steps 20251213_010642.jpg
  18. eatonpcat
    The contractor looks like he keeps the jobsite nice and neat, Keep the pictures coming Jeff!
  19. brenndatomu
    Agreed...but almost have to keep it organized with putting together that 1 million piece jigsaw puzzle!
    Screwloose, T.Jeff Veal and eatonpcat like this.
  20. eatonpcat
    I have been on much bigger projects that have been much messier!
