Coming soon...Echo Saw Builds
Discussion in 'Chainsaws and Power Equipment' started by Eggshooterist, Nov 9, 2024.
  1. Eggshooterist
    Eggshooterist
    Erff
    Thanks bud. That sounds like a good winter project.
  2. Eggshooterist
    Eggshooterist
    Erff
    And so it begins... 20250904_102412.jpg 20250904_102459.jpg 20250904_103105.jpg 20250904_103445.jpg 20250904_103452.jpg 20250904_103536.jpg 20250904_103544.jpg
  3. Eggshooterist
    Eggshooterist
    Erff
    Exhaust port is 17.5mm wide. The bore is 36mm. Target width is 23.4mm, which is 65% of bore. Im also aiming for 110° on Exhaust opening.
    Screwloose, T.Jeff Veal and eatonpcat like this.
  4. Eggshooterist
    Eggshooterist
    Erff
    Exhaust and intake roughed in.
  5. Eggshooterist
    Eggshooterist
    Erff
    All ports are at my desired size, shape and degrees. I still need to polish the exhaust port and hand sand the port chamfers. Phone cameras sure make things look like a 5 year old went after it with a rasp. Lol
    20250904_134840.jpg 20250904_134849.jpg 20250904_142118.jpg 20250904_142126.jpg 20250904_142139.jpg 20250904_142144.jpg
  6. T.Jeff Veal
    Looks good, my friend. I'm sure you will get some nice gains from that.
  7. ammoaddict
    ammoaddict
    Granite Falls, NC
    I want to try that one of these days.
  8. Eggshooterist
    Eggshooterist
    Erff
    Find a cs310, 370 or 400 if you want an easy to work on, reasonably priced saw to practice on. I'll try and walk you through what I know best I can. On the phone if you want. I manage without a 90° grinder too.
  9. ammoaddict
    ammoaddict
    Granite Falls, NC
    I have a cs352 i bought new several years ago. Probably only has about 10 tanks through it.
  10. Eggshooterist
    Eggshooterist
    Erff
    Thanks brother. I'm hoping to have it running this weekend.
    eatonpcat, T.Jeff Veal and ammoaddict like this.
  11. Eggshooterist
    Eggshooterist
    Erff
    That's probably pretty similar.
    eatonpcat and T.Jeff Veal like this.
  12. ammoaddict
    ammoaddict
    Granite Falls, NC
    I think it's the exact same as a 310 except a couple cc bigger.
  13. Eggshooterist
    Eggshooterist
    Erff
    Wanna sell the 352? Lol
  14. Eggshooterist
    Eggshooterist
    Erff
    I looked it up. Pretty much identical from the looks of it.
  15. ammoaddict
    ammoaddict
    Granite Falls, NC
    No. I like it pretty well. It's like new.
  16. Eggshooterist
    Eggshooterist
    Erff
    I don't blame you. I wouldn't sell it either. I should have kept my 310, but, it's back home now.
  17. Eggshooterist
    Eggshooterist
    Erff
    Have you done any modifications? A good muffler gutting and the carb limiters removed for proper tune really wake them up.
  18. ammoaddict
    ammoaddict
    Granite Falls, NC
    I drilled the cat out after the first time I ran it because it got so hot. I didn't open it up any but I did remove the limiters.
  19. Eggshooterist
    Eggshooterist
    Erff
    That's a good start.
  20. Eggshooterist
    Eggshooterist
    Erff
    Exhaust port on the cs310 is as polished as it's going to get. Reassembly is underway. 20250906_123357.jpg
