Bluetti AC500 w/B300K battery for our home backup/supplement system install and review
Discussion in 'Everything Else (off topic)' started by jtakeman, Feb 21, 2025.
  1. bogieb
    Smoke haze can definitely affect solar gathering. Yesterday, with not a cloud in the sky but visible smoke haze, my rooftop solar produced 43.3 kwh. The day before, with partly cloudy conditions, I pulled in 45.8 kwh. The difference would have been more except that in the afternoon, I'd say about 2-ish, the the majority of the smoke haze was pushed out.
    IHATEPROPANE and jtakeman like this.
  2. Earl764
    Earl764
    CT
    I’ve been looking at n-type panels that are meant to be better with shading and cloud conditions.
    Have been using the portable panels I initially bought. They work well enough but want to get a panel rated for permanent outdoor installations. Have been positioning my panels in different places in the yard to gauge performance.
    IHATEPROPANE, bogieb and jtakeman like this.
  3. jtakeman
    June stats. Still haven't put up more panels. Taxes were more than expected this year and some of the kitty took a hit. Maybe next month??
  4. jtakeman
    Finally getting some early sun. Over a week with overcast in the am killed the solar. I could barely get 2kw gathered. Yesterday was the first day in more than a week I gained the 4kw+ I was used to getting. Gonna kill the total for July for sure!!
  5. bogieb
    The struggle is real with consistently cloudy skies!
  6. Earl764
    Earl764
    CT
    how much have you played with the panels being in series vs. parallel?
    for my setup the docs read as if parallel was the better choice, but series increased my actual input and general production.
  7. jtakeman
    I have mine in series also. Higher voltage with lower amps than parallel. My wire to the house is long and the higher amps was causing to much heat and I was afraid I was going to burn up the connectors. Plus the MC4 connectors are only rated for 20 amps. Parallel the amps were getting pretty close to 25 amps. Series the amps have been cut in half. I've only seen 12 amps at the peek. A bit less worried about melting components now.
  8. T.Jeff Veal
    Nice engineering
  9. bogieb
    Series is really dependent on circumstances: If one panel will get more shade than another, parallel will keep that shaded panel from dragging down the production. But, if they are next to each other, facing the same way and not over VOC, the series is generally thought of as better from what I've gathered.
  10. jtakeman
    The latest panels have better shade features. With built in diodes that keeps the back flow from the cell in shade from drawing down the others. They also have diodes that can be installed between the panels, Basically an MC4 inline connector with a diode in it.
  11. jtakeman
    We decided it was better to get our new oil tank setup, So we opted to pass on adding more solar panels. But had a good solar month of August. Most likely wait to add more panels next year or try to at least get them purchased sometime after Christmas. Install next spring?
    Lost power twice after thunder storms. Pretty neat having most of the used things backed up and not needing the gas genny. The last outage was pretty close to dragging the gas unit out. I was down to 20% on the batteries and figured in about an hour I would need to get the gas gen connected. Priceless IMHO. We are pretty much sold on this and will be adding more battery storage and possible a larger battery gen too. Seems likely go with a 240V unit if the budget allows.
    Screenshot_20250903-114951.BLUETTI.png Screenshot_20250903-121141.BLUETTI.png
  12. bogieb
    Looks like you are covering about 40% of your electrical needs with just a few panels and that is great. Even though you have the genny, the noise can wear on your nerves so havi9ng a silent power option is really awesome.
  13. bogieb
    Had a guy over yesterday to give me a quote for putting 4 x 320w panels on the roof of my shed. Not the best placement in the world as it is in shade from tress a portion of the day (except winter/spring). That's okay, I'm getting tired of moving those panels around in the garage, I had bought 6 panels but only use two in the yard for charging stations. At least the roof is facing pretty much south, maybe a tick or two towards SSW.
    The panels are not going to be used to power electrical in the shed (it has none, and doesn't need it), but will be another place I can charge stations. This will be especially useful in winter in case of power outage.
    Yes, it would be cheaper to do myself, but I don't do heights and as I've mentioned many times, I'm a whole lot better at taking apart than putting together :D.
  14. jtakeman
    Me 2 bb, I rather keep my feet on the ground. I will job out the panels we might put up on the west side of the garage roof. That side is a big nope for me!!
    Sounds like a good plan!! :)
  15. bogieb
    So, I did a thing yesterday. More correctly, I had a thing done. Spring of 2024 I had bought 6 x 320w solar panels figuring I would put a garage or car port up and have at least 4 of them installed. Well, the carport hasn't happened. I'm tired of moving panels around in my garage and my shed roof faces south and I was looking all summer for someone who would install a small job (that was qualified and had insurance). I finally found someone :)
    I did have a unique install as I wanted each panel to run its own connection. That way I can hook up 2 or more stations at once, or use the max power coming in for each station connector (most of my stations have 2 x 500w PV ports so if a panel is pulling in 300w - I can take advantage of it all). I also have Bluetti stations, along with my Eco Flow stations. The Bluetti's have a unique plug into the station, so I needed the connections to be easily changed out. If by chance, I want to roll one of my big stations out there, I can run extensions for a 2S2P set up (or a 3S and leave the forth panel for another station).
    Connection on the east side with power station. I do need to get some stands to make it neater and add storage underneath.
    Close up for connection on west side (yes, the panel is lower on this side than the east side - for my own reasons).
    Stats of input at 3:45 pm when the sun is already to the far west so sun angle isn't great, but the panels are pulling in a good amount. Regardless, still pulling in more than the 220w folding panels at this time of day.
    Finished on the outside
    I've already taken in the folding panels (the 2 on the right). Those are not meant to stay outside 24/7, but that is what I did with them since spring of 2024 (except winter). I couldn't take those down fast enough. The two panels on the left, are the same as the ones I put on the shed and I will leave them out there for now.
    Burnin Since 1991 and jtakeman like this.
  16. bogieb
    Had a guy over last night to do an estimate for installing a manual transfer switch for using my battery stations in case of power outage. I have two EF Delta Pros, and four 2,048wh power stations that could be hooked up to the transfer station instead of moving them all over the place. Only need the two pellet stoves and the fridge on it. Has 6 circuits so I added a couple more for lights (basement, bath and living room).
    I'm supplying the transfer switch and all cables, so it is basically his time and expertise that I'm paying for. Accepted the quote this morning so now waiting for him to set a date.
  17. jtakeman
    That should make it much easier on you and the back. :)
    How's the new shed panel array working for you?
  18. bogieb
    It would be great if it weren't too cold to charge anything. I need to make an insulated box of some sort. Plus, it has been very dark and cloudy since the beginning of November - which is par for the course. I didn't expect anything for winter really, but it worked well during fall.
  19. bogieb
    Transfer switch installed and tested wtih a Delta Pro yesterday :yes: It has 6 switches, which are about 3 switches more than I need (but don't have to use, so that is okay). Put both pellet stoves and the fridge on the MTS.
    • The outlet that the P43 is run from also happens to be on the same circuit as the stair light, so that is excellent for safety reasons.
    • The P61a circuit also holds the combi-boiler and nothing else (that outlet was intentionally installed for the stove on its own circuit).
    • Not sure what is attached to the fridge circuit - during winter I can put everything in the garage or shed anyway, so it is not a critical circuit in my mind.
    The other 3 circuits are for non-critical but nice-to-have lights - 1 downstairs and 2 upstairs. I have no idea what additional things are attached to those since I don't care and those are unlikely to be used anyway. I have sevearl battery operated LED lights that I would use instead of hooking them up to battery stations.
  20. Earl764
    Earl764
    CT
    I have a similar setup. My favorite part is being able to hook power up in the middle of the night in terrible weather and not having to go outside.
    T.Jeff Veal, bogieb, jtakeman and 3 others like this.
