What's on your bench now?
Discussion in 'Chainsaws and Power Equipment' started by Czed, Jun 29, 2020.
  1. Dok440
    Dok440
    NorCal
    The money is flowing! Hate it when things snowball like that. It will be worth it in the end.
  2. Lehman
    Lehman
    Minnesota
    That sucks it doesn’t have spark, hopefully your experience with the aftermarket 2 pc ignition works out better. I’ve tried 2 of them and both failed inside a year.
  3. The Wood Wolverine
    I finally ordered the tank vent for the 346. Guess they really needed that big box. :picard:
    Dok440, Ron T and Eric Wanderweg like this.
  4. The Wood Wolverine
    My son put one on the 281 he got. Zero spark. We went back to the original and it fired right up. Good thing is he didn’t pay for it, came w/ the saw so he (for some reason) thought he’d put on the new part. After my experience with one on my 394, that’s definitely one part I will never stray from OEM. When it did run, it was way down on power. When I put a new original on, felt like a muff mod and BGD was done. And it only lasted about a year and a half before it quit.
    Eric Wanderweg likes this.
  5. Eric Wanderweg
    My plan is to try the AM just to get it running, then keep my eyes open for a used OEM. There weren’t any on eBay last time I checked (unless I wanted to spend the coin on another entire saw carcass, which I did not)
  6. Lehman
    Lehman
    Minnesota
    Probably had the timing off internally, I had one other aftermarket coil I had to advance pretty far to get it to run like it should. Stihl ms 361 all done with that coil also after 3 coils on same saw, ended up sticking a ms 441 coil on it and no problems now 3-4 years later.
  7. The Wood Wolverine
    Exactly what I thought after the change, timing way off. :yes:
  8. Eric Wanderweg
    Stuff happened, long story short now I’m going to run a… let’s say “unbranded” velocity stack.
    Eggshooterist likes this.
  9. buzz-saw
    buzz-saw
    Ct.
    Looks like you have been hanging out with eggshooterest , LOL.
    The home of " Everything gets a velocity stack"
    That fancy adapter must be some of your work.
  10. Eric Wanderweg
    I may have sought his counsel about velocity stacks earlier this week :whistle: Delrin is easy for me to come by and should hold up.
    Eggshooterist and Ron T like this.
  11. Eggshooterist
    Eggshooterist
    Erff
    Lol. We may or may not have had a private conversation...or 3.
    Ron T likes this.
  12. Eggshooterist
    Eggshooterist
    Erff
    Is it a straight shot down the i.d. or did you put taper down to the carb throat size? Assuming you machined it yourself.
  13. Eric Wanderweg
    It’s got a slight taper in it from where it mounts to the carburetor elbow, up to the I.D. of the filter. It all matches up reasonably well.
  14. buzz-saw
    buzz-saw
    Ct.
    Aweesome.
    Did you turn him on to DDM too. LOL
  15. buzz-saw
    buzz-saw
    Ct.
    Well you went directly to the source.
    Love the Delrin myself , I make a lot of parts from it and it is plentiful at my work. Not to mention it is super easy to machine.
    Eggshooterist and Eric Wanderweg like this.
  16. Eric Wanderweg
    I wonder if there’s a market for this? Converting new fine thread clutches to coarse thread. The original clutch on the 61 was very questionable, so this is cheap insurance.
    Czed and Eggshooterist like this.
  17. Eggshooterist
    Eggshooterist
    Erff
    I told him about it, yes. Lol
  18. Eggshooterist
    Eggshooterist
    Erff
    Excellent.
  19. Eric Wanderweg
    The 61/272 is mostly complete. I got it fired up but didn’t run it too long, because there’s no bar oil in it. I’m waiting to get the correct oil cap. With the older side cover and steel chain brake I didn’t have the space to use a decomp. Once that ring seats it should be fun to pull over :cool:
  20. Eggshooterist
    Eggshooterist
    Erff
    Don't forget to oil the filter.
