How would you fell this?
Discussion in 'The Sawyer Room' started by FarmerJ, Sep 14, 2024.
  1. stuckinthemuck
    stuckinthemuck
    And put a ratchet strap around the base of the tree about a foot above your cut. So if it was to barber chair on you, the ratchet strap would hold it together.
    brenndatomu and MikeInMa like this.
  2. stuckinthemuck
    stuckinthemuck
    I’m such a fan of the Maasdam that I bought two more kits. Just arrived with the UPS man 30 mins ago. :ups:
    metalcuttr, EODMSgt, FarmerJ and 3 others like this.
  3. FarmerJ
    FarmerJ
    Minnesota
    Source?
  4. MikeInMa
    EODMSgt, FarmerJ and brenndatomu like this.
  5. stuckinthemuck
    stuckinthemuck
    I buy my stuff from Wesspur.
    EODMSgt and FarmerJ like this.
  6. stuckinthemuck
    stuckinthemuck
    So to further elaborate on the Maasdam, I recently took down the tree in the picture.. Yes. The lean was as bad as it looks.
    I did a very open face cut. Idea was to maintain a hinge as long as possible.
    I tied off with two ropes in the big crotch that was 2/3 of the way up the tree. This is when I already had started pulling
    This is the view from the first pull point.
    This is from the second pull point. If the rope started to rub on that tree, I planned to put a pulley on the rope and pull it away from the tree to prevent friction damage.
    As you can see, the back cut opened up quite a bit and the hinge allowed it to stay attached.
    And here is the resulting stump when it finally came down.
    Woodwidow, MAF143, Chvymn99 and 7 others like this.
