St Croix hastings
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by Smokinpiney, Sep 4, 2014.
  1. DexterDay
    Once you run it through the cleaner. Start a thread with the name in the title (helps us with Searches, both for us and new people who are gonna search out this model).
    Then we will help with any other problems that arise :thumbs:
    Congrats again! That's a nice unit for a nice price! !
    Smokinpiney, will711 and 343amc like this.
  2. Gary_602z
    Gary_602z
    Lake Odessa, Michigan
    Guy obviously wasn't on the 3 year plan for having dry pellets!:D
    Gary
    wildwest and Smokinpiney like this.
  3. don2222
    don2222
    Salem NH
    Hello
    St. Croix uses the old SAE 841 oilite bronze auger bearings that can get black and gummy inside. So pull that out and clean it up well and you should be fine. You can even upgrade it to a nylon bearing too!
    Click pic to enlarge.
  4. Smokinpiney
    Smokinpiney
    "South" Jersey
    Don, is that the bearing that's in the plate near the motor? Or is there another bearing im not seeing?
    fishingpol likes this.
  5. Smokinpiney
    Smokinpiney
    "South" Jersey
    Well today I had a few minutes after work so I wheeled the stove out in front of the shop and started to blow it out. Holy cow, the inside of this thing is dirty! I seriously doubt if he cleaned it at all. I hit it with air for 20mins or so and there's still ash coming out :eek:.
    I have to order the combustion blower gaskets, auger gasket and versa grate shaft gasket. I'm going to try and weld the worn versa grate pieces and grind them down to spec. If it works, great and if not I'll just order them.
    wildwest, 343amc and DexterDay like this.
  6. DexterDay
    You definitely have your work cut out for you on this one!! But we have faith in you! With what you already know and your mechanical ability? You should be just fine.
    The most important thing about a pellet stove to remember, is its like a engine. Except it's a very finicky engine. It's air/fuel ratio runs on a very fine line. To little air and you get the Gunk that he had left you. To much air and the stove can possibly damage the pot and blow good heat out the exhaust (if it flows through the system to fast and doesn't get a good "Heat Exchange")
    Your doing a great job so far! Keep it up! !
    Smokinpiney and imacman like this.
  7. Smokinpiney
    Smokinpiney
    "South" Jersey
    Thanks dex. I knew i was getting a project with this stove so im ready for whatever it's gonna throw at me. Any recommendations for online parts sources? Cheapest i've found is at pellet stove parts 4 less.
    jtakeman likes this.
  8. DexterDay
    I have not bought parts in a while.
    Maybe start a thread? Asking where others shop? I order direct with my Pellet furnace and my new Enerzone is under a Manufacturer warranty.
  9. jtakeman
    What iv'e done is google the part number and see what pops up. Another tip is ebay has a few dealers that sell reasonable. Of couple of them ST Croix parts at a decent price.
    Tip: I usually google stove brand and part number so you get accurate hits to your search.
  10. wildwest
    Please excuse the newbie question: 3 year plan on pellets is a funny? Or is it real?
    DexterDay likes this.
  11. DexterDay
    That is a funny :)
    But a lot try to stay ahead. Helps to buy at prices you like. If the prices are high? Then skip that year, or only buy on sale.
  12. krooser
    krooser
    Waupaca, WI
    Don't forget to clean out BEHIND the firebox….
    savemoney and DexterDay like this.
  13. Rona
    Rona
    southwestern Minn
    Most of the St Croix stoves have the same bends and angles inside the stove where the smoke and exh follows the path to the outside exh pipe. There might be a small hole on each side of the burning pot. You can insert a old flex choke cable inside the hole with the other end inserted into a small drill.. This will rattle around and loosen a lot of gunk and soot. Then using a rubber mallet smack the back side of the stove which loosens more soot and junk. I have pictures of a Auborn cut in half that shows the inside of the stove and where it plugs up. I could e-mail them if needed. St Croix recommended burning their stove hot at least once every couple of days to prevent it from plugging up. The usual scenario was it worked fine the first season then the second season it just wouldn't produce as much heat as it did when new. The third season was worse. After these stoves had been in use for 3 years St Croix sent out fliers describing where to drill two holes and how to get the insides clean like I described.
    wildwest, DexterDay and SmokeyTheBear like this.
  14. jtakeman
    Welcome Rona! Glad you found the group.
  15. Rona
    Rona
    southwestern Minn
    Yeah I am glad to find it. Its almost like sitting down at a local cafe for coffee with old friends. Looking at member list I see several names I recognize. I googled IBC to see if there was any life there and somehow found this website. Looks like a good place to learn more.
    Smokinpiney, DexterDay and smoke show like this.
  16. will711
    will711
    Pocono Mts.
    Glad that you found us Rona :thumbs: Always nice to have another pellet head on board .
  17. DexterDay
    Glad to see you again Rona..
    I remember the two holes you just described. Actually, you sent me the pics via email over a year ago.. They are on my PC, but I may be able to drag them up. I completely forgot about them, until I read your post! Great info :)
    Welcome to FHC!
  18. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    'bout time you got here Rona.
  19. Rona
    Rona
    southwestern Minn
    Just got through stacking 2 ton of Indeck pellets bought on sale for 3.99 a bag. 8 will be returned as they had gotten wet and you could feel the bag had solid portions. This is a small but important advantage for unloading and stacking by hand. Indeck has more ash then I like but it has a consistant length rather then some brands that are simply to long to fit in the slots of the feeder wheel on a Bixby.
  20. imacman
    imacman
    Denver, NC
    Welcome Rona!
