Costs and Profit for $1534 a Cord Firewood?
Discussion in 'The Wood Pile' started by JDU, Jun 24, 2024.
  1. Chud
    Chud
    The new McMansion neighborhoods around here have outdoor patios/kitchens with fire pits I think they either don’t use them or buy bundles from grocery and home improvement stores. I tried to get some business but it didn’t pan out. I also suspect they are not the types to want large amount's of wood cluttering their bougie patio’s. Bugs smell and grubby white bearded dudes delivering the wood to their lonely botoxed brides. :thumbs:
  2. JDU
    JDU
    Perry County, PA
    Nice. A lot of work. So mind me asking what you sell those bundles for to the convenience stores and then what do they charge?
    And, I think you live in a much higher cost of living area than me.
    brenndatomu, Sandhillbilly and John D like this.
  3. chris
    pet store supply place i visit has about 2 cords worth out in front of store. no pilfering protection at all. $8.99 ea.75 cuft. Kiln treated isn't real hard to do, metal shed some insulation board, heat source, couple vents. for certification got rig a way verify time and temps. True wood kiln is not so much heat as to de-humidification- combination of both- that's where things get pricey. Insulated and semi sealed building/ container large enough for purposes. automatic controls for cycles. furnace of some type that can be controlled. Vapor emanating from wood is some what corrosive so most commercial units are stainless steel lined, auto venting and intakes. An old refrigerated truck box is a ideal candidate if you can find one at a reasonable cost. A 20 ft sea can works but a one trip unit is pricy. (unless you have an in somewhere to beat the middle man) ( one would think a 10 ft unit would be cheaper but they are priced at and sometimes more than the 20 ft.) in the summer here a closed up box gets pretty hot inside ( like your car) late fall through spring is when additional heat is needed.
    brenndatomu and John D like this.
  4. buZZsaw BRAD
    Do I look lonely? :startled:Im sure she'd like some of your wood! :whistle:
  5. brenndatomu
    She looks plastic...and scary! :startled:
    John D, sms4life and buZZsaw BRAD like this.
  6. chris
    Botox and plastic surgery gone way wrong. this what nightmares are made of.
    buZZsaw BRAD, John D and JDU like this.
