Can't be to careful in this endeavor folks. Warning... You can guess
Discussion in 'The Wood Pile' started by moresnow, Dec 4, 2023.
  1. Screwloose
    I've had cuts that look like hamburger that don't bleed and others more like a paper cut that just gushed.
    Glad he's basically okay, could have been deadly.
  2. isaaccarlson
    isaaccarlson
    Colfax, WI
    I'm just glad he's ok. That could have easily ended very differently, and in 999,999 out a million, it would have. He is a very lucky fellow.
    He should buy a lottery ticket and go to the casino...
  3. buZZsaw BRAD
    I wonder how sharp or dull the saw was when that happened? Shouldnt have to force a saw any newbies reading this.
  4. T.Jeff Veal
    Maybe he's been reading the Karma Sutra...:whistle::whistle::zip::picard::picard:
  5. T.Jeff Veal
    Glad he will heal up ok. He was very lucky
  6. saskwoodburner
    saskwoodburner
    How's that expression go, something along the lines of "If you're gonna be stupid, you better be tough"
  7. Timberdog
    Timberdog
    Az
    Yeah, if you aren’t careful that firewood could have cost him an arm and a leg…well, or at least a leg. I hope it heals up ok.
  8. Elm-er Fudd
    Elm-er Fudd
    Kansas
    There’s quite a few videos on you tube demonstrating that chap’s won’t stop an electric/battery saw. Hope he is healing well.
    Screwloose and T.Jeff Veal like this.
  9. Chud
    Chud
    I had not seen any electric saw vs chaps videos so I checked Utube and the first one in my search shows the chaps stopping the e saw instantly.
  10. isaaccarlson
    isaaccarlson
    Colfax, WI
    I have seen a few different videos where they test different saws on chaps. It seems to depend on how the saw hits, the brand of chaps, and the power of the saw.
    Either way, there is less damage with chaps on vs off.
    Screwloose, Timberdog, Chud and 5 others like this.
  11. Erik B
    Erik B
    Western Wisconsin
    Is there any difference between a battery chainsaw vs chaps and a corded chainsaw vs chaps? I thought I heard the corded chainsaw has more torque and the material in chaps won't stop it. I could be wrong.
  12. Rickyblazin
    Rickyblazin
    Pottstown PA
    The makita corded saw i have has a safety pin on the trigger soon as you let go the saw stops so i i think chaps would definitely benefit you with makita corded saw
    buZZsaw BRAD and Screwloose like this.
  13. Timberdog
    Timberdog
    Az
    I don’t care. I still wear them. There is also quite a few videos showing they DO minimize damage. And NONE showing they cause more damage. If you don’t want to wear them don’t. I’m into risk reduction. It’s fine if you’re not. It’s your body. Value it as you wish.
  14. Eggshooterist
    Eggshooterist
    Erff
    I have chaps. Hate them but wear them on occasion. Those pictures have me looking at some quality chainsaw pants. Something I'll actually put on.
  15. brenndatomu
    Did you see walts bib overalls with built in chaps?
  16. Eggshooterist
    Eggshooterist
    Erff
    I did. Its a great idea if you like bibs. Once I wear out my bibs I'm not getting more. I'm not a fan of them.
    Screwloose, walt and brenndatomu like this.
  17. ammoaddict
    ammoaddict
    Granite Falls, NC
    Same here. If I'm going to cut some brush for a few minutes after work I rarely take the time to put them on. If I'm going to cut for a couple hours on Saturday, I do. But as bad as my back has gotten, I doubt I could cut for an hour.
  18. Eggshooterist
    Eggshooterist
    Erff
    I do the same despite knowing the brush is probably when we need them the most. Easier to get tangled and trip or stumble.
  19. Timberdog
    Timberdog
    Az
    It’s important to remember chaps are not steel plating. The purpose of chaps is to reduce the severity of an injury. It’s an inch long gash that might need 3 or 4 stitches vs. plunging it into your flesh three inches deep where it severs an artery and you bleed out alone in the forest.
  20. Timberdog
    Timberdog
    Az
