Hey buddy, will you give me a lift?
Discussion in 'Chainsaws and Power Equipment' started by brenndatomu, Jul 23, 2023.
  1. walt
    walt
    north central ohio
    Nice job Dave , I am anxious to see it operate. I appreciate the fact you put alot of design thought into this splitter , you were thinking outside the box. I do that alot sometimes things work and sometimes they dont
    Chaz, Horkn, eatonpcat and 6 others like this.
  2. brenndatomu
    A little point of interest...(maybe :rofl: :lol:) I'm not sure if I mentioned it before, but I was really trying to keep the expenses on this project down, so I tried to make do with what I had on hand as much as possible, even though I did end up buying a new cylinder, and added a hydraulic tank that I wasn't planning on.
    I had to buy very little steel for this, I had some 3" channel iron that got used in a number of places. (support leg for one)
    The angle iron that makes up the side rails of the lift were the frame for the bars that the former owner of my place had put over the the garage windows after some punks (likely an inside job) broke in and stole her Simplicity lawn tractors...I removed the bars when I did my garage addition last year and had glass block windows put in.
    The frame of the log rack on the operators side was formerly a rack on my dads old custom built work truck bed.
    The 1/2" square bars on said log rack were the actual bars over the garage windows.
    The tubing on the log lift was recycled from the frame of a wind damaged trampoline that was going into the dumpster at work.
    And yooperdave will appreciate this one, the platform that the engine/pump are now mounted on was formerly the optional-but-included pedestal base of my inlaws Englander NC30 stove! I hacked that up and used the ~1/8" steel in quite a few places.
    The rest of the steel I either had laying around, or bought from the scrap hopper at work (for cheap!)
  3. yooperdave
    Ha ha! The two pedestals I had (nc-13 and then nc-30) ended up the way of the scrapyard for pennies on the dollar.
    Lets admit it. Legs look a lot better than pedestals. :whistle:
    T.Jeff Veal, Chaz, Horkn and 4 others like this.
  4. brenndatomu
    Yes sir!
    Guess that means we don't like "flat bottom grills" :whistle: :D :picard: :rofl: :lol:
    T.Jeff Veal, Chaz, Horkn and 6 others like this.
  5. Screwloose
    I can see that pressure switch being quite handy, sort of a blow and go operation.
    Project is really coming together!
    T.Jeff Veal, Chaz, Horkn and 5 others like this.
  6. eatonpcat
    Looks great Dave!!
    Chaz, Screwloose, Horkn and 4 others like this.
  7. brenndatomu
    Pressure switch? You mean the old compressor switch? I'm planning on that being my on/off switch for the motor.
    Thanks!
    T.Jeff Veal, Chaz, Horkn and 2 others like this.
  8. brenndatomu
    Was hoping to get my hydraulic lines made up this week or weekend, but ended up with some sort of a GI bug on Friday, and apparently all the laying around didn't agree with my back, so now I'm trying to work that out...it's kinda weird though, this time is a lil different than what I usually deal with... :pain: I tell ya what, this gettin old stuff...:picard: :BrianK:
    T.Jeff Veal, Chaz, JD Guy and 8 others like this.
  9. Screwloose
    Always something ain't it!
    T.Jeff Veal, Horkn, Chaz and 3 others like this.
  10. brenndatomu
    She has hydraulic lines! :yes:
    Was dark by the time I got home, so no pics...y'all probably have a pretty good idea what log splitter hydraulic lines look like anyways ;) :rofl: :lol:
    I left all my fittings loose so that we could turn them to the best position to make the lines lay nicely, so now I need to seal the threads and tighten everything down...getting close to the maiden voyage! :thumbs:
    T.Jeff Veal, Horkn, Chaz and 7 others like this.
  11. BC Doug Fir
    BC Doug Fir
    Cariboo BC
    F0356EA8-6BD0-4959-9BAD-332F4BDEF67D.jpeg FC7D9345-67B7-4D4F-8A3A-A5AF788F3554.jpeg This one worked pretty good
    Horkn, Marvin, eatonpcat and 2 others like this.
  12. brenndatomu
    Horkn, Chaz, Screwloose and 6 others like this.
  13. The Wood Wolverine
    Well shoot, maybe it’s time for me to pull the trigger on that new pump. I was lookin’ at another website and theirs was approaching $200. Are these ruggedmade good quality?
    Horkn, Chaz, Screwloose and 1 other person like this.
  14. brenndatomu
    I'm about to find out, that's where I got mine, just paid $50 more...their splitters are supposed to be better than the box/farm store stuff that most of us run...and the parts they sell are supposedly the same stuff they use to build splitters with.
    But I really suspect 95% of the log splitter pumps out there come from the same factory anymore.
    With a 10hp engine you could actually pull this 19 GPM pump. 19 GPM Hydraulic Log Splitter 2 Stage Gear Pump, Faster replacement for 16 gpm | eBay
  15. brenndatomu
    I think you have a pretty big cylinder on that machine (5"?)...the easiest way to speed things up dramatically would be a cylinder swap...the one I just pulled off my build would be a bolt on mod on your machine...or this one, this is what I used, it has 3/4" ports and a 2.25" ram (faster return stroke) that cylinder would almost cut your cycle time in half. (or should anyways, as long as the pump is actually making 16GPM) https://ruggedmade.com/welded-log-s...d-od-1-5-rod-end-5-rod-bolt-clevis-mount.html
    Horkn, Chaz, Screwloose and 2 others like this.
  16. JRHAWK9
    JRHAWK9
    Wisconsin
    Just don't do this!
    A buddy just sent me this. This is 2 weeks post surgery. He got his finger in the way of a splitter helping a buddy split wood.
    That is a pin holding the bones together to heal. It will be removed once healed.
    When it first happened he captioned these photos with, "apparently I'm not as good with this whole wood splitting thing as you are". LOL He said the finger was just hanging.
  17. brenndatomu
    Wow! :bug:
    That's just, uh...not good! Well, it's good that they were able patch/pin him back together though!
    That's the only thing that gives me any pause about building a fast splitter, is the greater chance of injury (maybe?) heck, I've had a close call or two with "slow" ones! :picard:​
    T.Jeff Veal, Haftacut, Horkn and 4 others like this.
  18. Chud
    Chud
    My learning curve was painful.
  19. BC Doug Fir
    BC Doug Fir
    Cariboo BC
    Ya should never stick your finger anywhere ya wouldn’t stick your d***
  20. Canadian border VT
    10 vs 1 but this site is family friendly so I will stop
