thescratchylens Gets Legit
Discussion in 'The Wood Pile' started by thescratchylens, Nov 5, 2023.
  1. Stephiedoll
    Stephiedoll
    Omaha, NE.
    We get mostly stringy ash here.
  2. buZZsaw BRAD
    Horkn, Cash Larue, metalcuttr and 2 others like this.
  3. buZZsaw BRAD
    X2
  4. buZZsaw BRAD
    Green (the variety, not fresh cut) is stringier IME. White ash splits clean for the most part. Of course with most of the ash in encounter being dead its a non issue.
  5. thescratchylens
    thescratchylens
    Rock County, Wisconsin
    Thanks so much. It’s the only one that we could get so even if it had been buttugly…
  6. thescratchylens
    thescratchylens
    Every camera I have ever owned. Every pair of glasses. Even my cornea. My safety glasses, routinely. All either are or have been scratched. It’s a thing with me.
    :whistle:
    Oh - and I did post my dumb mug in that thread. Figured I’d double down here
    :wacky:
  7. thescratchylens
    thescratchylens
    So, this was yesterday:
    We have had what Eric Wanderweg would call a Dead n’ Down “cedar” (read: juniper) junking up the bottom woods since we moved in and yesterday was its date with destiny, that is, Mr. Stihl.
  8. thescratchylens
    thescratchylens
    Time to break out the brand spanking’ new MM. Instructions say the margin of error is 3%, so I’m calling every reading at +3 to be on the safe side. This will be nice wood to use judiciously.
  9. thescratchylens
    thescratchylens
    If there was ever any doubt the wood I cut up-thread is ash (there wasn’t), check this out. Ahem. I said “check” this out. All the cut surfaces started cracking overnight. Amazing.
  10. thescratchylens
    thescratchylens
    Eric Wanderweg gets a hat tip for excellent advice. We’ll wait a bit to burn this since it’s at a “adjusted” 20.5% moisture - plus you can see the outside is still damp. But it’ll be challenging. I’m really curious. Meh it’s too warm out anyways, especially for ash.
  11. thescratchylens
    thescratchylens
    The big surprise? This is red oak (pin, to be specific, I think). Mr. Cottonwood and I felled a few of them back on 10-08. I expected a higher reading on the MM.
    Chvymn99 and brenndatomu like this.
  12. thescratchylens
    thescratchylens
    This oak (I think) has been laying around since we bought the place. I was surprised it’s not drier.
    It’ll get there. Maybe it has a comparatively high reading because it was lying on the ground for all that time before we moved in.
    Well, that’s it for now. Thanks, as always, for reading.
    Chvymn99, Horkn, Stephiedoll and 2 others like this.
  13. Eric Wanderweg
    In my experience dead ash dries fast. Being on the cusp on dry, it shouldn’t take long. A month from now and it’ll be noticeably drier. You can also leave wood inside the room you’re burning in (not too close to the stove/insert) for a couple days prior to burning it. The fire will suck any remaining moisture right out of it.
  14. Canadian border VT
    Save the cedar fir holidays! Wife loves it
  15. thescratchylens
    thescratchylens
    Starting to look like an actual FHC house - except for the T-posts. I couldn’t talk The Wife out of them. IMG_0932.jpeg
    That’s the back of the pile - mulberry and oak. Some pretty small pieces there, but there’s a reason. We have a small insert, only 13” deep. And I wanna be like the grown-ups and load N-S. Means more work and small splits, but ok.
    Chvymn99, Horkn, Stephiedoll and 5 others like this.
  16. thescratchylens
    thescratchylens
    The front of the stacks: IMG_0935.jpeg
    All the ash I cut is split. Time to go get more. Couple days before I’ll be able. It’ll be there.
    Chud, Chvymn99, Horkn and 5 others like this.
  17. Eric Wanderweg
    Nice inventory! Nothing wrong with t-posts, especially for the shorter splits. Trying to crib 13" splits wouldn't work out too hot once your pile got above a couple feet high. What you're doing will work out just fine (and be less effort too). Where I'm at it's too rocky for t-posts, hence the cribbed ends. If I don't crib then I use vertical pallets with 45 degree braces to stack up against, which works but looks wonky IMO. I'm digging your railroad tie/t-post setup :dex:
  18. buZZsaw BRAD
    I have a customer who took a cord of barkless black locust i had bucked to 16" and cut them in half so he could do the same. I now sell him my BL nuggets and shorts.
  19. Stephiedoll
    Stephiedoll
    Omaha, NE.
    Looks good from here. Wood should dry nicely.
    Good work.
  20. thescratchylens
    thescratchylens
    Thanks! It is work, especially getting everything up and running. But we all agree that the reward is so so so worth it.
