I messed up my wood splitter today
Discussion in 'Chainsaws and Power Equipment' started by SD Steve, Oct 1, 2023.
  1. brenndatomu
    I've done both...it has to be put in sparingly in a car tire though, so it would likely only work on a very small slow leak, and did for me, didn't really cause balance issues either...but that wouldn't work on a car with TPS.
    And I haven't had an ATV tire without slime in 40 years! (except maybe for the flips) it saves a lot of tire leak headaches!
    Screwloose, T.Jeff Veal and Ronaldo like this.
  2. Screwloose
    Innertubes ????
    What about a trauma kit? Anti harpoon armor? Blood stop bandages?
  3. MAF143
    MAF143
    North Central OH
    I've been temped to wonder over into the Amish / Mennonite communities near here to see if I could find some metal front wheels for Fergy, but I'm sure I wouldn't like it for the occasional jaunts down the road...
    I have 4 spare tubes in the shed. I borrow my neighbors tire spoons and he laughs at me every time cuz he knows what I did...
  4. brenndatomu
    Foam filled...
    eatonpcat and T.Jeff Veal like this.
  5. MAF143
    MAF143
    North Central OH
    I have a foam filled tire on my wheelbarrow. I HATE it!!! With a big heavy load on, it feels like it's half flat. I'll replace it with a good old inflatable when I get around to it, they roll so much better with a load.
  6. brenndatomu
    Big difference between a "cheap" store bought foam filled wheelbarrow tire and a professionally filled tire from the local shop...and I know you guys have a shop out that way that does it because we used them at the mill...just don't recall the name of the place...and those would hold up to 125k lbs on 4 tires, so I know the front end of the Massey would be nothing. They have different densities and fill rates based on load and speed.
  7. MAF143
    MAF143
    North Central OH
    Yeah, that cheapo tire is probably optimal for Jane homeowner who's large load is leaves or twigs... I'll have to look into the real foam. Thanks for the tip.
  8. brenndatomu
    I wanna say check with Forklift Tire in Mansfield, that might be the place...if not they probably know where
  9. SD Steve
    SD Steve
    South Dakota
    Part is on order for my splitter!
  10. SD Steve
    SD Steve
    South Dakota
    I thought you meant Mansfield South Dakota.....
    I was going to say...."there's nothing in Mansfield..."
    It's just about 40 houses, a post office and a bar. And I bet 25%-50% of the houses are empty
  11. brenndatomu
    Mansfield Ohio...population at least 1000 times your Mansfield...
    Ron T, metalcuttr, eatonpcat and 2 others like this.
  12. brenndatomu
    Whatcha gettin? :binoculars:
  13. SD Steve
    SD Steve
    South Dakota
    It's the fitting between the actuator and the ram....
  14. brenndatomu
  15. Warner
    I borrowed an MTD splitter before I got mine. The stamped log rippers are a poor design. Lots of room for improvement there.
  16. brenndatomu
    I think this log went right over top of them...:hair:
    eatonpcat, T.Jeff Veal and metalcuttr like this.
  17. Warner
    Like I said lots of room for improvement
  18. chris
    every couple years i get a sticker. when i stick them they are really stuck. sledge hammer 8# is my go to tool. one time had one stuck , went for hammer was half way back and it let go. Glad I wasn't right there.
  19. SD Steve
    SD Steve
    South Dakota
    Yep, it missed them
  20. SD Steve
    SD Steve
    South Dakota
    20231031_180109.jpg She's fixed......ready to split!!!
    I ran it back and forth few times, looking good, ready to start crushin'
