Looking for a new stove
Discussion in 'Modern EPA Stoves and Fireplaces' started by SpeedShop64, Aug 13, 2023.
  1. SpeedShop64
    SpeedShop64
    Upstate, NY
    I'm currently heating my home with a Fisher Grandpabear in the basement. My house is 1950 sq ft including the basement and main floor. I have vents in the floor to the basement and also leave the basement door open. The Fisher does a great job at heating the entire house, too good of a job actually. However the stove is just too big for my house. I'm looking for something a little smaller that will have decent burn times and be more efficient on wood consumption. I'm new to EPA style stoves. I understand they require low moisture content wood. That is not a problem for me. I'm currently 5 years ahead on my split and stacked wood. I appreciate any input.
    Fred
    Chaz, T.Jeff Veal, savemoney and 5 others like this.
  2. brenndatomu
    Hi Fred...what brand, or type of stove are you looking at?
    Price range? Cat stove, or non?
    Chaz, T.Jeff Veal, savemoney and 3 others like this.
  3. SpeedShop64
    SpeedShop64
    Upstate, NY
    I’m unsure of which brand to look at. Is there any benefits of a cat Vs non cat stove in terms of burning performance? I’m completely new to EPA style stoves so I have a lot to learn. I would like to have a stove that has long burn times and will leave a good bed of coals. I’d say $2500 would probably be the high end of what I’d like to pay.
    Chaz, RGrant, T.Jeff Veal and 4 others like this.
  4. brenndatomu
    Cat stoves are known for their "low n slow" capabilities...which means a lot longer burn time if you can actually heat your house that way...which since you are heating from the basement, a cat stove is not going to be as beneficial since the stove would have to be pushed a lil harder.
    Basement heating also means you'll need a lil bigger stove than you would otherwise since there is some heat loss to the lower level before it can get upstairs...also, modern stoves have an "insulated" firebox, so that they can burn clean, the heat is largely transferred through the stove top, whereas your old Fisher transfers heat more so through the whole stove (which means they can heat better with just hot coals in the firebox than a modern stove can.
    Which with all that said, if you buy the right stove you should still be able to save some on wood usage, and certainly will see a cleaner chimney too!
    SBI makes a nice selection of basic steel stoves that are made in Canada and are known to be good stoves for the money...I'd stay away from "off shore" stoves...which it can be hard to determine sometimes, some companies really jump through a lot of hoops to make it seem like their stuff is made a lil closer to home.
    Here is the website for what is basically the SBI company store.
    Wood, Pellet and Camp Stoves
  5. wildwest
    Dennis, Backwoods Savage , may I ask how many sq ft you heat with your stove? It radiates heat if I stood next to it, right? We're going with a cat stove to hopefully extend the burn time of lodgepole pine and extend the 2 am restoking. What are your thoughts?
  6. wildwest
    Consider your chimney, ours was straight up and out the clay chimney, tried a little EPA insert (non cat) , I didn't like having to remove the tubes and baffle when sweeping the chimney. Have a new set up coming soon with a cleanout on the main pipe elevation. Might have kept the little EPA with secondary burn tubes but it was too small for our needs. There are a lot of members here with an Englander NC30 that is a big stove with secondary burners and are quite happy with them.
  7. brenndatomu
    His stove is not in the basement, so totally different scenarios.
    You guys should be fine as long as you are not going with a tiny stove...or your heat load is insane.
    Chaz, T.Jeff Veal, wildwest and 2 others like this.
  8. Backwoods Savage
    Certainly less than 1900 sq ft!
    However, contrary to what Dave believes, a cat stove would definitely be a good choice for Fred. Low and slow does not mean less heat!! It means more heat from the wood you are burning, so long as it is dry. Also, if heating from a basement (which is usually not a good idea in my opinion), would it matter if heat comes from the top or sides? In addition, with our cat stove heat does come from all over the stove.
    The best I can say of our stove (Woodstock Fireview) is that we always had problems trying to heat our home until we got the Fireview. Now we keep our home around 80 degrees all winter and burn 50% or less the amount of wood. We also rarely clean the chimney because the stove burns so clean. This year we will be going onto our 17th year with this stove and still love it.
    Good luck Fred, and I would also highly recommend an Ideal Steel from Woodstock.
    Stephiedoll, Chaz, RGrant and 6 others like this.
  9. CoachSchaller
    CoachSchaller
    Southeast Michigan
    another vote for an Ideal Steel, but I am biased...
  10. brenndatomu
    It's not contrary to what I believe...I said less heat to the house (main level) not from the wood (which means the load lasts longer, but that means nothing if you are heating from the basement and aren't making enough heat to warm the main floor to the level that you prefer)
    It depends on the house as far as how well basement heating works...some (mine) it works very poorly, some it works perfectly.
  11. Canadian border VT
    In my opinion; and certainly not as old and wise as Dennis. Heating from basement can be difficult; depending on climate, if basements walls insulted and how well air moves in your house..
    so many people blame stove when 8” poured concrete has R value of 1.1
  12. Warner
    If you do get a new stove I’d keep the old one just incase….My Drolet HT3000 thread
    I have an drolet HT 3000 I’d give you a deal on.
    Chaz, T.Jeff Veal, Chvymn99 and 3 others like this.
  13. brenndatomu
    I wondered when you'd check in here... :handshake:
    Chaz, T.Jeff Veal, Chvymn99 and 2 others like this.
  14. Backwoods Savage
    How would you get less heat to the house? Even if, as you stated, all the heat came from the stovetop, would that heat not react the same as if it came from lower? If a (cat) stove can heat the room it is in, why would it work differently in a basement vs first floor? If it could not heat the level it is in, why would anyone install it on the main floor vs a basement?
    Sorry, I am not trying to stir things up here but just trying to make sense of it and I agree, I am not too smart sometimes.
  15. Monadnock Monster
    Monadnock Monster
    If I were in your situation, I'd be looking at either Woodstock or Blaze King. Both seem to get great reviews as far as quality, and length of burn.
  16. SpeedShop64
    SpeedShop64
    Upstate, NY
    I've heated with a coal stove in the basement then replaced it with the Fisher. I have zero issues with heating from the basement. If I maintain 75-80 in the basement the main level will be around 70-75. The issue with the Fisher is the stove is too large for how small my house is. If I try and keep my stove pipe temp at 300-400 the basement will be 90 degrees. I'd be a lot happier with a lower but longer burn rate. Do EPA stoves require an induction blower? I'm curious what happens when the power goes out.
  17. brenndatomu
    Because when heating from the basement, it serves itself first...if you are trying to run a cat stove on low in the basement, most of your heat will go to the earth, not the second level of the home...YMMV as I said earlier, some homes work better than others when heating from the basement, most don't, mine does not work well at all, hence why I installed the wood fired forced air furnace...that heats the whole house easily, and evenly.
    spotted owl, Chaz, RGrant and 4 others like this.
  18. brenndatomu
    I'm not saying a cat stove won't work here, just that you'd better not expect to get 18 hour load times running on 1 (or less) all the time (unless maybe in the shoulder season)
    Cat stoves can make just as much heat as any other, but will also use just as much fuel too (as long as we are talking about a similar size stove, that is well designed, and run properly)
    Where cat stoves shine is where they can be run at a fairly low burn rate.
  19. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    blaze king for the win!!!:salute:
    ReelFaster, spotted owl, Chaz and 2 others like this.
  20. Highbeam
    Highbeam
    I have both cat and noncat. Only the cat stove has the ability to burn lower with longer burn times and be clean burning. I like the ability to choose heat output, and the directly related burn time, to match the conditions in a house stove.
    My non cat is easier to run and has a prettier fire view but it chews through wood and gets short burn times since it has to run hot in order to run clean. Not great in a house but great in a big cold shop.
    No fan is required for any woodstove. Power outage is no problem.
    Basement heating sounds ideal for a wood furnace. Would that work for you? Even a couple of new ducts or run ductless!
