Hey buddy, will you give me a lift?
Discussion in 'Chainsaws and Power Equipment' started by brenndatomu, Jul 23, 2023.
  1. brenndatomu
    Sounds spendy...and fast.
  2. brenndatomu
    I think I am gonna go ahead and sell my Champion 23 ton splitter...I have a guy at work that is looking for one and is interested in it, so the timing is right.
    Also think I am going to order the new cylinder with 3/4" ports and a 1/2" larger ram diameter...that'll help speed things up even more, and allow me to sell the old cylinder to offset some cost. $70 just in shipping for that beast though! Oh well, it looks to be a direct replacement, only with a couple upgrades, so :yes:
  3. FarmerJ
    FarmerJ
    Minnesota
    I’ve got a meeting Monday to make a splitter with an 18” cylinder like I want.
    for a boxwedge, 4-way and a 6-way and a log lift.
  4. brenndatomu
    So I'm measuring up the hydraulic tank on this Huskee 22T splittah, and its only ~4.95 gallons, if its full to the top, and they only call for to be about 2/3 full!
    I'm thinking I need to add some additional storage for a 16 GPM pump! On the hunt for a small squarish hydraulic tank (or something that could be made into one) that isn't going to break the bank...:makeitrain"
    Found a 10 gallon tank that is reasonable, but that is physically too big...
    Horkn, T.Jeff Veal, Chaz and 2 others like this.
  5. Warner
    Throw an old beer keg under there!
    Horkn, T.Jeff Veal, Chaz and 3 others like this.
  6. brenndatomu
    I was thinking of an old portable air tank, or LP tank...would really prefer something square/rectangle though...open for suggestions...its will have to go where the engine/pump used to be
    Horkn, T.Jeff Veal, Casper and 3 others like this.
  7. MasterMech
    But the beer keg (half keg?) would look waaaay cooler. :rofl: :lol::cool:
    Horkn, JD Guy, T.Jeff Veal and 5 others like this.
  8. TurboDiesel
    Subbed.
    Enjoying this thread !
    Horkn, T.Jeff Veal, Chvymn99 and 3 others like this.
  9. brenndatomu
    Well, guess I am committed now, boss man came n picked up the Champion 23T this morning...its all :axe: until I get the new one done! :startled: :rofl: :lol:
  10. brenndatomu
    Well I'll be dipped...this thing has tapered roller bearings in the wheels! They not in very good shape, but still, wasn't expecting that!
  11. Stephiedoll
    Stephiedoll
    Omaha, NE.
    More power.jpg I recommend MORE POWER!
    Marvin, Horkn, eatonpcat and 3 others like this.
  12. brenndatomu
    I can't remember, were you upsizing the pump too?
    Horkn, eatonpcat, T.Jeff Veal and 2 others like this.
  13. Casper
    Casper
    HGR in Euclid might be a good source...
    Used Hydraulic Tank For Sale
    Horkn, eatonpcat, Screwloose and 2 others like this.
  14. Stephiedoll
    Stephiedoll
    Omaha, NE.
    No, just didn't like the air filter set-up on the display 11HP motor. Boxed ones may have been different, but for the $50.00 or so difference I felt like it was worth it. Also had a 20% off coupon. I have thought about it, and some said that I should, but didn't want to go down the rabbit hole as you know what happens then. Bigger hoses, better cylinder and valve, the list goes on. I use the 30-ton anyway and Edwin doesn't mind how slow it is.
  15. brenndatomu
    I do know about that, yes! :picard: :rofl: :lol:
    Horkn, eatonpcat, Stephiedoll and 2 others like this.
  16. MasterMech
    If it came with a ball-hitch coupler, that's almost mandatory. Anything less on those small tires (NHS rating?) is just asking for trouble, even towing at sub-30MPH speeds. Tapered rollers are so ubiquitous in the trailer industry, prob not much to be saved by skimping here.
  17. brenndatomu
    Many (most?) newer splitters (chinese made?) have bushings from what I hear...
  18. MasterMech
    Should have a pin/clevis style hitch then to discourage high-speed towing. But that's just the engineer in me talking. I wouldn't be surprised, just disappointed, to see the visible things like the coupler remain higher-spec, and the invisible things get downgraded.
    Horkn, Stephiedoll, eatonpcat and 2 others like this.
  19. The Wood Wolverine
    Now I'm going to have to tear into my splitters wheel bearings just to see what's in there. :rolleyes:
  20. brenndatomu
    :whistle:
    Might not hurt anyways...mine look like they didn't have much grease and got kinda rusty crunchy...more grease would have probably prevented that. Found a set of 4 bearings/races and 2 seals for $25 shipped...oh, and 2 new cotter pins and hub caps too.
    Horkn, MasterMech, eatonpcat and 3 others like this.
