If it doesn’t split, it was meant to be art
Discussion in 'The Wood Pile' started by chunez, Jun 9, 2023.
  1. chunez
    chunez
    WI
    I’m sure these will crack but hopefully can salvage some larger pieces
    C5152ADA-B15C-4AEF-BFD3-2A1ED10E102D.jpeg 91460609-0825-4862-886D-ADFC951B7E94.jpeg
  2. buZZsaw BRAD
    With grain that twisty i end up noodling them into "splits" unless you like twisty splits.
    Pretty grain though.
  3. Eric Wanderweg
    If you paint the ends they *might* not crack.
  4. chunez
    chunez
    WI
    Picking up anchorseal tomorrow. Unless you think that’s overpriced BS and latex paint works just fine?
    Screwloose, metalcuttr, Chaz and 3 others like this.
  5. buZZsaw BRAD
    Calling buzz-saw. He has used both
  6. buzz-saw
    buzz-saw
    Ct.
    Either one works , I have had good results with just latex paint.
    Still no guarantee they wont crack regardless of what you use but it does improve the odds.
  7. The Wood Wolverine
    If you’re serious about minimizing splits/cracks, go with the good stuff. I’ve used a ton of latex and it helps but I read and I’m told AnchorSeal is the gold standard.
    Screwloose, metalcuttr, Chaz and 2 others like this.
  8. Warner
    Just spitballing here but I think I’d put each in a contractor trash bag and open for a bit on a rotating schedule. Ain’t never tried it tho.
    Screwloose and Jeffrey Svoboda like this.
