The big push
Discussion in 'The Wood Pile' started by RCBS, Feb 6, 2023.
  1. RCBS
    Worked on dirt bike trail today. Had an off last Thursday. Pretty good one for no faster than I was going. Went back and mellowed out the spot a little today. Lost rear wheel down the slope and couldn't hold the bike. Flopped to the down hill side and smooshed my left radiator pretty good. It was much narrower with a little ledge before, this is during the fix.
    Dug out some flat rocks and other small junk on different parts of trail trying to make nicer.
    After an hour and half I got the weedeater out which doesn't make much for pictures. Although while doing a fence, I found this baby bird doing his best to stay super still until the danger passed.
    Some of you might find this neat. Pictures aren't great, but snuck onto a job site after work Friday to be nosy. River locks had a major slip issue and there has been ongoing work to correct. Just leisure craft these days, no commercial traffic. Appears they have used one side to push the other. Disclaimer....I'm not an engineer. LOL. I have helped tend these locks when a friend used to have the job. Double chamber with sluce gates.
    Just something I find intriguing.
    Dok440, Skier76, Sirchopsalot and 3 others like this.
  2. RCBS
    Crap day Saturday. Rained steady until about 2:30. Decided to call a lid on working in the woods and washed the dirtbike instead.
    Yesterday I wanted to finish up some splitting and do some stacking. Worked on a few rounds and then busted some uglies that have been laying around.
    Stacked the red maple that will be given away.
    A-holes
    Need to get these moved.
    Y'all might get a kick out of this. Some of my coworkers being creative in finding a way to trim the canal bank behind our building. lol
  3. RCBS
    So I was minding my own business shopping for a carburetor on Amazon last night and I happen to notice an item that has been just hanging out in my cart was discounted 19%. I told myself 'no more 50cc saws, you got plenty'. Yeah I broke that. This one probably will stay in the box for a while. The Echo 501 is doing just fine. I just couldn't pass this up.
    Chaz, Stephiedoll, Dok440 and 3 others like this.
  4. RCBS
    Also did some weedeating yesterday. This bank is my nemesis.
    Chaz, Dok440, KSPlainsman and 4 others like this.
  5. RCBS
    Weather just as nice as you could ask for.
    Consolidated and 'stacked' more A-hole pieces. Nearly a cord there now.
    Also finally* got the big tree pulled over to the neighbors house.
    These rounds are from 16' up the trunk.
    Got a new tool in the mail also.
  6. RCBS
    Deer been hitting the mineral lick hard past few weeks.
    Raked and graded my woodyard. The laves hold moisture so they needed to go.
    Worked on main trail a little. Always somewhere needing attention.
    A new piece of dirtbike trail being born.
    And what an established one looks like.
  7. RCBS
    Was fairly worn out yesterday. Hit it pretty hard previous three days. Decided to wash buggy after doing some more maintenance on the main trails yesterday. It looked haggard with a whole winters worth of dirt on it. Drove over to the local spray bays. It was impulsive so I didn't have any scrubbing tools or cleaning agents, just water. Looking better.
    While taking a leisure ride around the property, already in lounging mode in shorts I run into this stupid pair of Aspens. Quick work with the 501 Echo and I was back to cruising.
    Almost all trails have been groomed now. The one above obviously still needs attention. It's a wet one and have been waiting for it to dry up.
    Chaz, KSPlainsman, eatonpcat and 3 others like this.
  8. RCBS
    Sharpened 4 chains yesterday for my 50cc saws. I continue to have issues with the Husqvarna Xcut chains. Been using Pferd files for more than a decade and they've always been excellent. For whatever reason, they do not want to cut on the X chains. I even tried a brand new out of box file and got the same results. It just won't let the file cut smoothly. Super snaggy and grabby. I tried differing angles of attack and even tried taking extra gullet out. Decidely still not a fan. I have a 3/8 X chain that need sharpened also...will see if it gives me the same problem. I have only run into this on rare occasion with Oregon products. Overhardened cutter links or something? Fairly frustrating.
    Chaz likes this.
  9. eatonpcat
    Nice cleanup on the SXS and especially on the property! Your land is beautiful
    Chaz, Dok440 and RCBS like this.
  10. The Wood Wolverine
    Send em my way and I'll "hook" you up... :D
  11. RCBS
    Thank You. Always trying to make it better/nicer. That 'little' chunk of forest means a whole lot to me.
    Chaz, buZZsaw BRAD and eatonpcat like this.
  12. RCBS
    I didn't mention...I snapped a file trying to sharpen one. Yep, that snaggy. Likely operator error, but I have no idea why those chains would be different from any others as far as sharpening goes. I managed 3 oregons same file with no issues.
  13. The Wood Wolverine
    Grinder makes quick work of it.
  14. RCBS
    I'd prolly hurt myself with those. lol
    I have always low key wanted to get a chain from The Chainsaw Guy after he works it over on his Silvey machine. Unknown if a 'west coast' grind would work well for me or not.
    Chaz likes this.
  15. buZZsaw BRAD
    Ive had chains with extra hard teeth. So much so i bought a diamond file for when i encounter it. Usually just the leading edge. Few strokes and a normal file works fine after.
    Chaz likes this.
  16. RCBS
    Worked on some of the last few needing attention. Started branch trimming campaign also. Good day to be hiding in the shade.
    Found some fresh meat. Right beside the trail.
    Got taken for a boat ride yesterday. Checking out the under reconstruction bridge project.
  17. RCBS
    I'm big enough to admit it. lol I'm a big dummy!
    So I *have an 18 volt makita 10" chainsaw that I keep in the buggy for quick chops and whatnot. Went to get it out of the bed over weekend....not there. Just the scabbard and batteries. "Oh ok, I know where I left it..." Nope. "Maybe that other spot..." Nope. Spent almost two hours rummaging around in the woods at various places I *thought I had used it. Had to admit stupidity.
    Thinking on it a bit I figured out how to make it reappear. I bought another one. LMAO It's become a staple in my toolbag and I have I think 7 batteries for it that fit nothing else I own. Looking forwards to finding it in the last place I'd expect to sometime in the future. It may be under a pile of brush or worse yet, under a pile of leaves and sticks that I shoved with the tractor.
    Hi, I'm RCBS and this is *one of my Big Dummy moments.
  18. brenndatomu
    I'd leave it under the pile to burn...:picard:
    RCBS likes this.
  19. RCBS
    I don't burn the piles in the woods. Yep, seems like an odd problem to have. What can I say? I'm a busy and mobile fellow. I may use that saw 15-20 times in one day, for a few seconds at a time at different spots. I know I jumped out and cut something, set it down to manage whatever I was doing then just hopped back in the buggy and took off. Literally dozens of possible locations. It may be found, it may not be. I'm ok with it either way. The old one paid for itself just killing vines.
    I must be working too hard. lol
  20. Dok440
    Dok440
    NorCal
    Sometimes that's the only way to find things. BTDT way too many times!
    Chaz, Stephiedoll, RCBS and 1 other person like this.
