Snowmobile Trailer
Discussion in 'Chainsaws and Power Equipment' started by Skier76, Aug 20, 2022.
  1. Muskoka Guy
    Muskoka Guy
    SevernBridge, Muskoka, Ontario
    for what it cost and your time I would replace all the wiring, start fresh.
    Warner likes this.
  2. Canadian border VT
    Skier76 check with manufacturer about raising tire size. They want those trailers belly heavy
    Skier76 and brenndatomu like this.
  3. brenndatomu
    I put slightly larger tires on one and the tires would rub the bottom of the deck when hitting a bump while heavily loaded... I had to install urethane bump stops because it would actually make the tires smoke n squeal a little...I'm sure I was overweight though too...hauling 5 yards of mulch (short drive on side roads)
    Skier76 likes this.
  4. Canadian border VT
    Mulch helps with center of gravity..
    snowmobile do not
  5. brenndatomu
    Oh I dunno... I had it heaped up pretty high :whistle::D
    Skier76 likes this.
  6. Skier76
    Skier76
    CT and SoVT
    That’s a good point. Ironically, I reached out the manufacturer awhile back. They stated they unfortunately don’t have anything on file for this particular trailer.
    Going to a 10” would raise the overall height 1”. I measured and I’ll have enough clearance to the deck; even if the suspension bottoms out.
    So “in theory”….this should work just fine. But again…in theory. ; )
  7. Skier76
    Skier76
    CT and SoVT
    Found a deal I could not pass on. 3 tires/wheels; two lightly used one brand new: $100 on FB Marketplace. These are the same size that are on the trailer now, so “stock” height as far as I know.
    As you can see, the current tires/whee setup could use replacing. I may pick up some new lug nuts as well. Current crusty ones may clash with those newer wheels. ; )
    New tires and wheels:
    Stephiedoll and buZZsaw BRAD like this.
  8. Skier76
    Skier76
    CT and SoVT
    Ended up selling the trailer. Aside from one trip around the neighborhood this summer, it hadn’t left the yard in a year. It was a fun project fixing it up. Before selling, I pulled the hubs, wire wheeled, primed, enamel painted them, packed the bearings and installed new dust caps.
    I put the trailer on Marketplace over a weekend. Monday morning, I got a message at work from a guy asking about it. Agreed on a price and he picked it up a few days later. He rides some older Ski-Doos with his kids and this is just what needed. Glad it went to a good home!
    Currently on the hunt for a decent 5x8 utility trailer.
  9. Canadian border VT
    Get a 5x10 instead much betterer
    Horkn, Skier76 and buZZsaw BRAD like this.
  10. Skier76
    Skier76
    CT and SoVT
    I was thinking about that! However, storage space is an issue. Trying to keep it on the smaller size.
    Horkn and buZZsaw BRAD like this.
