Does Heat Affect Mtronics in a Stihl?
Discussion in 'Chainsaws and Power Equipment' started by buZZsaw BRAD, May 12, 2023.
  1. stuckinthemuck
    stuckinthemuck
    You are correct. M is for M-tronic. You can go to the Stihl manual website and see the different models. The 261 and 261C are one manual. The 261C-M is a separate manual. Same goes for numerous other saws. Just so happens that currently all Mtronic pro saws are also Comfort saws.
    https://www.stihlusa.com/manuals/
  2. buZZsaw BRAD
    Wasnt aware of them being available with the Q designation. There's an older 036 with the quick stop on FBM in my area.
  3. firewoodbuckenman
    firewoodbuckenman
    Colorado Springs Co
    Empty out the gas and replace it with Stihl canned gas see what it does when you start it, then run it through the Calb. treatment.
  4. buZZsaw BRAD
    One other confusing thing is some of the homeowner level saws have the C designation too. 211c, 251c etc. My understanding was this was for the tool free chain adjuster.
  5. stuckinthemuck
    stuckinthemuck
    There are several comfort features. The chain adjuster is one of them. It is hard to find a place that they actually nail down what comfort features are available. This is about the best I have found to highlight a few of them.
    Comfort features
  6. stuckinthemuck
    stuckinthemuck
    I think one issue is if they were to put all of the applicable letters on the pull start cover, some saws could end up with a good portion of the alphabet on there. I think it can also be like many things in that some items are considered features until they are made standard “options”. Think about shoulder harnesses on seatbelts in cars. At one time, they were an option for anyone who wanted added safety. But now, they are pretty much standard on most new vehicles. I don’t know enough about the quick stop feature to know if it’s standard or not right now. But I wouldn’t be surprised if, for liability purposes, they included it on every saw.
  7. buZZsaw BRAD
    I know the MS290 had a model with the Q feature. Met a guy who owned one. It can get confusing at times. :picard:
  8. buZZsaw BRAD
    My new to me Ms400 acted up in the heat yesterday. Wouldn't hot start. I opened gas cap several times. Got it to start again finally but wouldn't run. Frustrated and heat exhausted in the sun I quit. Ill have to check the hot/cold flap under the cover. It started 45 minutes later at storage. Think I'll just let it idle at the cut today.
  9. huskihl
    huskihl
    It’s likely from running winter fuel. In another couple weeks they will switch to the summer fuel and problems will go away
  10. Screwloose
    As huskihl says it's just a case of the vapors making her constipated.
    I remember the old carburetor car days when a warm early spring day meant cars stalling in traffic jams throughout Chicago.
    I have a case garden tractor that has fits like a teenage girl until the fuel is changed.
  11. buZZsaw BRAD
    I took off the shroud cover and switched carb intake to Summer. I left the saw running for the most part today and had the 462 for back up.
  12. buZZsaw BRAD
    Maybe use some mulberries as fuel? :eek: :D :whistle:
  13. huskihl
    huskihl
    People move that slide a little bit too much. It should be in the summer position unless your carburetor is freezing up in the winter. Every bit of air that comes through that window to heat the carburetor could be cooling the engine
  14. buZZsaw BRAD
    400 was a bit problematic again. I left it running while not using. It ran out of gas and it wouldn't start even though id did fire and idle for a few seconds. Starved for gas when I hit the throttle. Switched to the 462 for a bit. It did start a few minutes later. Kept it in the shade as it was mid 80's here today.
  15. Barcroftb
    Barcroftb
    The Mitten
    Have you done anything to address the winter gas issue?:sherlock:
  16. buZZsaw BRAD
    I honestly didn't know there was a difference until mentioned in this thread.
    I use Stihl silver bottle 40:1 with 93 octane. Made this batch last week. Bought the six pack of bottles last month at local reputable OPE dealer.
  17. huskihl
    huskihl
    I mentioned it 3 years ago as well. Try higher octane or get some gas from a different vendor
  18. buZZsaw BRAD
    Ok my bad. I thought you were referring to the Stihl mix is Summer/Winter like some bar oils are.
  19. huskihl
    huskihl
    No. The fuel
  20. Barcroftb
    Barcroftb
    The Mitten
    Might also be time to consider doing something about this as well:binoculars:
