Tree service wood processing?
Discussion in 'The Wood Pile' started by Lennyzx11, Mar 23, 2023.
  1. Lennyzx11
    Lennyzx11
    Bennington Vermont USA
    After working a load of tree service cuts yesterday,
    What’s you guys best way to work them to standard lengths?
    I mean from the random 20-40” cuts that are too short to work on my sawbuck or on a timberjack.
    I ended up just grinding through it on the ground holding with my foot and rolling them to get the bottom cut.
    But the bar/chain may have gotten nervous a couple times getting close to the gravel I admit.
    Curious what others may be doing as this way is a PITA.
  2. Ohio dave
    Ohio dave
    Akron, OH
    I do alot of chain sharpening/replacement do to hitting dirt cutting tree service to length
  3. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    I often times put em in my splitter crossways and use it as a vice to hold it as I cut it to my length. Kinda slow and inefficient, but safer than using my foot. ( although I do that too sometimes) Especially if you don’t have to take much off.
  4. Backwoods Savage
    You could try putting them in the splitter crossways so you are cutting up off the ground. Splitter will hold them tight.
    WoodPirate, gwoods71 and WinonaRail like this.
  5. billb3
    If you plan on having a lot of them you could make a cutting table.
    If alone I've used my foot or on some more logs.
    I've had a partner hold them on a stump/splitting block.
  6. WinonaRail
    WinonaRail
    Indiana, US
    Depends on the situation. If stacked so you can reach, I cut what's on top or try yo pull it within reach. Smaller stuff I may throw on a pallet (mind where the nails are). My whole wood yard is covered in 2"-4" of wood chips so no risk of hitting gravel.
  7. FarmerJ
    FarmerJ
    Minnesota
    I built a bucking table and loaded them onto it. Saves bending over so much.
    ECACD160-F600-4485-9AB0-B3F6B8ECD98B.jpeg 2794753A-B561-44C1-933E-B5CB363F7D1E.jpeg
    Let’s me load it with the skid steer and unload it too.
  8. The Wood Wolverine
    Couple years ago I cleared a lot for a friend to build a house. In an effort to speed up progress, I brought home poles in length. I ended up buying one of these:
    Lot clearing score.
    Was able to gang sticks together when possible. It worked great. Might work for you as well.
  9. buZZsaw BRAD
    PITA but i more or less do the same. Does wonders for the back. Ive refused many a score due to that. Im tired of having multiple cords of shorts, cookies etc on hand.
    Have a piece of 3/4 plywood, osb, advantech etc. handy and roll logs onto that to save the chain. Ive been known to slide a two by underneath as well where the log will be bucked. Many years of experience has me always watching the nose of the bar when bucking logs on the ground.
  10. Skier76
    Skier76
    CT and SoVT
    That’s cool device. What’s it called?
  11. Lennyzx11
    Lennyzx11
    I’ve gotten some ideas to try from the group replies on this thread. Thank you!
    Wood wolverine’s holder looks like it would work. The chain fastening is safer than my foot. Pondering adding something homemade to one end of my sawbuck to hold short pieces with a strap/chain. Loading one at a time seems inefficient though. Maybe both ends for two at a time.
    FarmerJs bucking table was what I was thinking of when I wrote this.
    I did try holding the pieces on the splitter but I have metal catch tables on each side that would be under the first cut.
    The pallet idea seems workable. Lay a bunch of pallets down and lay a hand full of pieces on them and cut a bunch. Stack three or four pallets may ease the ol back pains.
    Currently my method is to make about 10 cuts at a time then split onto the catch table of the splitter. Then stack to the pile.
    10 rounds quartered/halved at a time is about all the catch table will hold at once.
    I just brought in another pickup bed load last night so I’ll try the pallet idea first. I cut them (pallets) up for kindling anyway.
  12. Krackle_959
    Krackle_959
    Coastal Maine
    I cheat and use the thumb on the mini excavator to hold them. I also use it to move big rounds around the splitter, my wife thought I was crazy for using the mini to move wood around, until I showed her how to use it to load the dump trailer. Its now the best thing ever as she doesn't have to pick up the wood by hand to load the trailer.
  13. The Wood Wolverine
    Skier76 likes this.
  14. jrider
    jrider
    I cut tree service wood almost exclusively so I get all sorts of shapes and sizes. I benefit from having a tractor with forks on it which helps but those pieces that only need to be cut once can be time consuming. I love it when my guy drops off 15+ footers.
  15. Lennyzx11
    Lennyzx11
    Yeah, I’ve got forks and a grapple. You’re right about the one cuts taking more time.
    WoodPirate, jrider and buZZsaw BRAD like this.
  16. Pricey106
    Pricey106
    Northeast PA
    I have gotten alot of tree service off cuts. Anything under 26" long, I split then stack into my cutting rack, including limb wood. Over that, I will use my splitter like a vise, if they are manageable diameter, like under 12". 20170929_170024.jpg
  17. Skier76
    Skier76
    CT and SoVT
    Thanks! I had never seen one of those before!
    buZZsaw BRAD and WoodPirate like this.
